Axpert settings vir Pylontech 3.5 kw
5 hours ago, Beat said:
You are very lucky to have them so close together!
My first two packs (LEOCH) came with some 26 cycles difference. I added another pack some months later and the fourth one year later. The actual cycle counts are: 429, 403, 320, 65. So what?
Yes, they have some little differences in behavior that show up at low SOC, but at full charge they equalize themselves.
An advantage might be that they will not reach end of live all together at the same time. LEOCH claims the guaranteed number of cycles with 100% discharge be 3500. Design live span 20 years.
My Pylontechs are in use for 28 months al installed on the same day. Cycles 313, 293, 295. Seems to be normal.
  • Replies 81
  • Views 55.3k
  • Chris Hobson
    Chris Hobson
    Hi Kobus  have a look in the download section there is a Axpert Guide I wrote a year or so ago (it needs updating). With a 3.5kW Pylontech the max charging rate is 37A. Since the Axpert can
  • Looking at this old post, I just want to share how to correctly set the DIP ADD switches on Pylon low-voltage batteries: A ) If you have just one group of Pylon bricks, keep all the DIP swit
  • SOLUTION: So this was all part of confusion on my part. After reading the pylontech setup manual again,  i've changed ADD dip switches to 0000 on master and slave battery. This change has en
18 hours ago, Coulomb said:
My understanding is that with that sort of set-up (which I'm not familiar with), the Pi will send commands to the inverters to over-ride any battery related settings you make. I have no idea if it will optimise the maximum current by setting one inverter to a different current limit than the others. In the general case with n inverters and m battery modules, that could be rather tricky. So maybe it just sets all the inverters to use the same maximum charge current.
So basically: I don't think you have to worry about it.
Thx, i'll rather make sure about the settings as i still need to set the inverter to User
OK, but even so, the Pi is probably sending commands to change (override) the battery related settings. So setting them yourself could well be pointless.
Hi colleagues i have a question about icc cable for rpi4. I can't buy it from icc because they don't ship to my country. That's why I need a scheme. I would take the new us3000 c using rj45 (no more rj11) and I guess for rpi I need a regular usb to rs232 or ?? does anyone have a schematic? or isn't it that simple ?
  • 9 months later...
I am installing a Sunsynk Sun 8K Hybrid inverter with 4 x Giter 5.04 Kwh lithium ion batteries. Do anybody have experience of this? I am not sure if I have the dip readings correct. The system kick out when loaded more than 2 kva
On 2022/11/17 at 7:00 PM, Amathuba Pro said:
I am installing a Sunsynk Sun 8K Hybrid inverter with...
Hi, and welcome to the forum.
This thread is about Axpert inverters and the settings to use with Pylontech batteries. Sunsynk inverters are very different. You would be better off reposting your question in a new post with "Sunsync" in the title, or respond to another thread that pertains to Sunsync inverters.
  • 1 year later...
Hello all,
I'm a French user from Guadeloupe and I very interesting for all information about setup correctly.
I have 3 inverter wks evo circle 5600 va (MKS2-5600 in Solar Assistant), 18 PV 400 watt (1 string of 12 and 1 string of 6 PV on inverter 1 and 2, the number 3 have no pv yet) et 3 Pylontech US5000
Thanks and sorry for my poor English
My setup is:
The Max Grid charge current is 2 A because I have the F08 fault
