Best Toaster for Solar System.
Hi All,
Anyone got some recommendations on the next low watt, useable toaster? I usually use the toaster before the sun rises so I don’t want to use too much of City Power or my batteries. Don’t wanna use the Toaster, pool, washing machine, Geyser also at the same time.
any ideas?
12 minutes ago, Raiden2912 said:
Hi All,
any ideas?
In order to have enough heat to toast the bread I think the only option would be a single slice toaster if one needs only 1 slice.
1 hour ago, Raiden2912 said:
Hi All,
any ideas?
2 slice toaster. Uses less than a microwave.20240218_071310.thumb.jpg.6ca117b77f67efbfb8936a2a992a44c5.jpg
I suspect lower power toasters will be like low power geyser elements. They get the job done, but slowly.
What they do offer is a lower peak draw, which is handy when one is current limited.
