BSL 7kwh
Item: 1 x BSL 7kwh Lithium Ion Battery
Age : Brand New
Price : R25000
Payment Method : EFT
Warranty : 10 years
Packaging : Sealed
Condition : Brand New
Reason : Upgraded
Shipping : Collect in Midrand
15 hours ago, Kalahari Meerkat said:
may be able to say whether the Axpert MKS4 5.6 can, via CANbus or RS485 talk to the BSL BMS...
It depends what protocol it talks. An advertisement says it's compatible with ~20 inverters, including Voltronic Power, and the Axpert MKS 4 is made by them:
https://iprorwxhlinpml5p.ldycdn.com/cloud/opBpoKkmRmjSnnqlljlnk/lithium-ion-battery-pack-48v.jpg
From: https://www.bsl-battery.com/lifepo4-solar-batteries-48v-lithium-ion-battery.html
Edit: You should check installation manuals to see which battery type you need, and decide how you are going to buy or make an appropriate cable, exactly where to plug it in at the battery end, and any required DIP switch settings.
"When the batteries are connected to different brands of inverters, the BMS automatically recognises the inverter communication protocol and matches it." It sounds like you can even talk to it with more than one protocol. I've not heard of that before.
