Another Blue install
15 hours ago, plonkster said:
They don't really overheat (they just think so, and raise an alarm). It's also not really a failure, it's a minor manufacturing issue that can be repaired. Victron knows about the issue and will take care of you.
I can confirm that my unit is not hot to touch in these events, feels very normal.
  • Replies 88
  • Views 17.3k
  • Done and up and running again
  • I have been live now for a year and according to the data generated 4541kW (4.5 MW sounds better) . My consumption has gone down since the geyser was placed on a timer with the installation, but as yo
  • Everything in place
13 hours ago, Jaco de Jongh said:
And I though the inverter de-rates itself when it monitors excessive heat..
Well they do, but to the point of where it should of shut down and still going in my case if the charts are to be believed.
It does, but again, the heat isn't the real problem. It's a false positive... so it can derate as much as it want, it still thinks its running too hot.
So they have started today,  redid two DBs and started stripping trunking and cables of the Solar install.
DC combiner to find a new home somewhere near the bottom and then a lot of new trunking to be done.
Mmmm remember DC and AC should not run in the same trunking. Should do some planning for the trunking below the MPII.
Edited by Ironman
Yeap, might take it up left and down in the middle again. I have also seen others take the DC behind the trunking. Not sure about regulations when they actually just cross and don't run further in the same trunking, this is apparently also done..
Perfectly fine to be in the same vicinity, where they terminate. Nobody is that OCD.... okay... few people are that OCD 🙂
Making some progress, flow seems much better. Ironman should be happy about the AC side of things :)
Edited by PaBz0r
@PaBz0r - I'm keen to know more about what you used for what looks to be the bus bar just above the fused disconnect?  Perhaps a closer photo as well if you don't mind?
I still need to do that on my system.
It is indeed a DC Combiner, it has copper busbars with cone type isolated supports, that screw into the box and bars.  I will have to open it up to get you a clearer picture.
TTT had a pic of his in this thread, last picture of the first post https://powerforum.co.za/topic/2946-victron-grid-tied-setup-from-scratch/ . Basically a more compact version of this.
Edited by PaBz0r
  • 7 months later...
I have been live now for a year and according to the data generated 4541kW (4.5 MW sounds better) . My consumption has gone down since the geyser was placed on a timer with the installation, but as you can see the grid usage percentage is low, which was part of the goal, but of course  beating loadshedding was the priority
