My software
Still busy changing some coding, Was a bit lazy the past days , recorded 480 hours run-time, should have been much longer as i have to stop stop and compile
Manie that looks Great, can I get a copy:D
Beats my terrible screen (although it is just a logger to a Database)...
Hi Viper
The Value from the Axpert was too granulated (no decimal points), but you get the Watts, so a simple division and rounding gave me a decimal value. Pity I can't do that with the Charge/Discharge Current without a seperate device... All these values are either direct from the Axpert (QPIGS and QMOD responses only) or Calculated based on those values. As mentioned in another post, I seem to have a problem getting finer detail as some Query Codes aren't working.
I cheat a bit with the Utility Apparent Power by calculating the % offset from the Load and using that as the same offset (which if charging batteries at same time is not quite accurate, but close enough).
Manie that looks Great, can I get a copy[emoji3]
I dont have the bmv 702 in my program and it have only usb support. We are bussy with Jaco software to add the usb. And to make his software supper. Usb will be added soon and some interesting functions . Speak to Jaco. We spende many hours on the usb and its communicating . Its just to add it. I am currently busy with the pi and lazerus . Because Lazerus have a nice interface and its the same as Delphi
