Axpert problem
  • Replies 54
  • Views 16.2k
  • If it's just a series resistor, it won't even work most of the time. As soon as a cloud goes by and the current goes down, the voltage drop across the resistor will go down, and the voltage seen by th
  • Hi Guys, Ok, so the inverters was supplied by Voltex and is not dud's. The VOC of their 5KW is 115 VDC. I indicated to them that what they are advertising and selling is not the same. They d
On 2022/04/08 at 2:26 PM, Brian Chetty said:
Is it worth taking out the others that measures 330k ohms in line?
Hi Brain the resistors are fine and the MPPT.
I repair inverters if you need help PM me.
