July 1, 20206 yr I am looking at this Geyserwise PV option at the moment. A lot of the information available points to the PV solution being more expensive. However, I have been quoted just over R15k for the system (not installed, but I can DIY). Quote includes 3x 375W Candadian Solar panels. This price seems reasonable in comparison to other options at the moment. My concern though is, will it heat the water quick enough during the day? My intention would be to heat it hotter than I need it during the day, my wife shower and kid bath in evening, and I could hopefully still be able to shower in the morning. We also wash bottles and dishes 2 or 3 times per day. No appliances draw hot water. The usage pattern wouldn't really make a difference with any solar option. Current usage (winter, Pretoria) is 11kWh average per day on my 3kW 200l geyser, based on the usage pattern described above.
July 2, 20206 yr @Craigm I am no expert, but the Geyserwise PV system is specified so that it normally heat your geyser in around half the day. So if all conditions are good your tank should be heated by midday(ich). However it is never just so easy. It depends on the sun your house receives, the weather, your water usage, geyser size and your house efficiencies (long distance from the geyser to where you use the hot water). Do the following test: switch your geyser on around 11am for 3 hours and then switch it off. That should be enough to heat the water to temperature. Now use your hot water as described above and see if it last. This is what any solar geyser will give you. You get the water heated during the day while the sun is shining. In winter there is less sun and in summer there is more. When you use hot water in the evening it is replaced with cold water. During the night this cold and hot water does exchange heat between the layers in your geyser giving you not so hot water in the morning (no matter how much you insulate your geyser as the cold water is already inside). So in practice you will see that if everyone showers in the evening, or everyone showers in the morning a solar system will work fine. If some people shower in the evening you will need to use electricity to heat the water for the morning shower person to feel happy. PS. This is true for any solar geyser system.
July 2, 20206 yr 1 hour ago, Louisvdw said: If some people shower in the evening you will need to use electricity to heat the water for the morning shower person to feel happy. PS. This is true for any solar geyser system. I think one can safely say that you need a backup heating system since your solar geyser will not work for you at all times. Edited July 2, 20206 yr by Richard Mackay
July 2, 20206 yr 17 minutes ago, Richard Mackay said: I think one can safely say that you need a backup heating system since your solar geyser will not work for you at all times. Yes a few weeks ago our flatplate collecter had cracked a pipe . Don't know why the pump did start up on 5 degrees and you could see the temperature change. I have replaced it with Kwikkot vacuum tubes . Even the vacuum tubes need some assistance from the geyser element in winter . Don't no why they don't they fix these flatplate radiator . Had it at the factory no guarantee and no repair . Did repair it with little effort . Must get rid of it .
July 2, 20206 yr Author Thanks so much for all the info thus far. For me currently Flat plate seems the best option. It is cheapest and safest. The Geyserwise is really nice but according to my maths (might not be 100% accurate, but should be a good estimate), the geyserwise PV system will not get the geyser warm enough during then day, thus ending up paying Eskom more. I have attached my maths, should anybody be interested... For me the ROI on a Flat plate is around 3 years, even less if Eskom keeps messing up like they are doing right now. The most expensive part is the installation, as the going rate in the Lowveld is around R8k for a days work. If you are up to installing a PV geyser system yourself, any other solar geyser shouldn't be that much more difficult to install.
July 3, 20206 yr I was given a link to this forum by Richard Mackay who thought I would be interested in the topic. After reading through the posts it would appear that no one on this forum has used, or owns, the Geyserwise product. We lost our house in the 2017 Knysna fires but rebuilt on the same site in 2018. In the process, having always being interested in the solar topics, I decided to invest in the Geyserwise system for the new build. I have found, over the last two years, that the system does what it says on the box! The installed system is as follows: 1) Panel orientation, North East 2) Panels set flat on the roof with a pitch of 30 degrees. 3) Panels, Renesola standard 250 watt, 3off. 4) Geyser 150l Kwikhot mounted vertically on South wall. 5) Standard geyser blanket fitted. 6) Element Geyserwise dual AC2.2kW/DC(8-72volt) 7) DC element set to a maximum of 60 degrees. 8) I have installed a voltmeter and ammeter on the DC input to the geyser so that I can see what is going on. 9) Electricity availability charge roughly R4.00 per day. 10) Electricity charges are roughly R2.00 per kW. My personal details are: 1) Retired. 2) 2 persons in the house. 3) Hot water is used for showering(no bath in the house) , generally once a day in the evening. hand washing etc when necessary and sink duties 2 times a day. We have no dishwasher, never have had. 4) No domestic help. 5) Cooking is carried out using a combination of induction hob combined with two gas burners and a double oven. My wife does a fair amount of baking. 6) We have two cooked meals a day, full English breakfast and lunch. We do not eat out a lot. 7) There is one large fridge/freezer unit. 8) All lighting is LED. 9) We have no electric space heaters. I have tried to insulate the new house as well as possible and our climate is fairly mild. 10) I have a number of fair size machines in my workshop. I am sketching this all out as a previous poster has mentioned, quite correctly, your power consumption depends entirely on your lifestyle and without this information you cannot make an informed assessment! Also, as someone has posted the solar salesmen are salesmen…. Because of my interest in solar water heating I kept a detailed record of power consumption in the previous house. The long term average was 13kW per day. With the Geyserwise system installed our household power consumption is now between 7 and 8 kW per day during summer and 9 to 10kw per day in winter. From the above detail I am saving approximately R5.00 per day in winter and R9.00 in summer. In retrospect I would consider an additional panel to support the winter power generation. This power would however go to waste in summer?
December 11, 20205 yr On 2020/07/03 at 2:52 PM, Doug said: 7) DC element set to a maximum of 60 degrees. Is that what the Geyserwise offers or do you feel higher might be hard on the geyser in the long run? I've had this system installed yesterday, it seems DC can go up to 75 degrees. So I wondering, have they updated the system or is higher than 60 degrees not recommended? My planning to get enough hot water for 24hours, been to set this to 65 degrees. Today been mostly sunny, so got there around 11:30am. I'm really impressed with this after a day's use. I've set the AC timers on 50 degrees, to have some heat to shower with during cloudy days, but more importantly, the lower Eskom cut in should give savings. I'm feeling really tempted to go for that 75 degrees. How it went: Got to 65 degrees then stopped. Once it fell back to 60 degrees, DC started heating again. If it starts heating too late in the day, hot water might not last. If it tried to keep it on 65, it would have been perfect. Just my thoughts on going for panels rather than tubes: If the system fails, I can use the long lasting panels on the solar system by just changing cables to go to the inverter. Also, feel more comfortable to control the heating. Edited December 11, 20205 yr by SunnyParys
