October 4, 20169 yr External grid : Eskom (old Rotating meter store exess power in grid, to avoid cycling batteries at night) Hybrid inverters: 2 X Victron Multiplu 48Volt/5000VA/70Amp, (master slave parallel operation give 10000VA), Victrons Include multistage chargers limited to 60A+60A=120A Battery charging current. Internal Grid: 2 X Eltek THEIA HE-t 4.4 grid-tie inverters providing power directly to load at 97% effeciency. excess is routed back to grid or batteries by victrons. The Victrons also Throttle excess power on Eltek's through frequency shifting when eskom down. Batteries : 24 X 2V @ 500A Lead Crystal Batteries CNF J-500, providing 48V @ 500A 20 X 305 W Monocrytaline panels , arranges in 2 strings of 10 panels at 360V feeding into the two Eltek inverters respectivly A BMV-600S battery monitor tells, what coming and going. Effergy engage, cloud based power monitor keeps track of usage.
October 4, 20169 yr Author Thanks Jaco, The Systems certainly keeps the lights on and make 38KW/h on a good day, but I have a shading problem on the one string in the winter, which was a design compromise when I designed the house, but watch this space, I am busy cooking up a new plan.
October 4, 20169 yr The Victron's ability to island with grid tied inverters supporting GFPR really I'd awesome.Sent from my GT-I9195 using Tapatalk
February 2, 20206 yr Hi l like your set up l am trying to do the same ac coupled system with two 10kva Quattros and 4 Eltek inverters. 4.4kw. I have not yet set up the frequency shifting. l would like to know the settings that you applied and also do you have the installer's password? beautiful set up. regards, Malvin
February 3, 20206 yr .. I seriously need to tidy up my install... I've been "getting to it" for the last year....
