July 8, 20215 yr Thought you guys might be interested, the latest version of Home Assistant includes a plug-in for Solar Forecasting. https://www.home-assistant.io/integrations/forecast_solar/
July 12, 20215 yr I don't have solar yet (hopefully July/August) however I have put in the two array details and will compare. Has anyone done this and how does it compare?
July 13, 20215 yr On 2021/07/08 at 3:23 PM, Sc00bs said: Thought you guys might be interested, the latest version of Home Assistant includes a plug-in for Solar Forecasting. https://www.home-assistant.io/integrations/forecast_solar/ thanks, i have added it and for today i said it under estimated by 2kwh. Will see tomorrow
July 14, 20215 yr Author 22 hours ago, phidz said: thanks, i have added it and for today i said it under estimated by 2kwh. Will see tomorrow You can tune it, so if it regularly under forecasts you should be able to correct it.
July 14, 20215 yr 46 minutes ago, Sc00bs said: You can tune it, so if it regularly under forecasts you should be able to correct it. I did, measured the roof angle and orientation and today it was bang on. I'm impressed. Will see tomorrow
