Freedom Won balancing ?
I'm monitoring ( on line via the Victron VRM portal ) a friends Freedom Won / Quattro / Victron MPPT  installation and am noticing how the Freedom Wons cells are getting more and more unbalanced. At 100% full charge the max cell voltage is 3.77V with a cell max- min difference of 0.41V - Average was 3.40V . At the bottom end at 10% SOC ( only ever been below 40% once in the last 2 years due to loadshedding ) min cell voltage was 2.56V and cell max-min was 0.66V - avg was 3.16V. Is there a utility to manually initialise a cell balance routine ?  How are you supposed to rebalance the Freedom Won if the internal balancer is loosing control?
13 minutes ago, Bernardf said:
I have a Freedom Won battery with my Sunsynk inverter. Can someone tell me how I can get the cell level data to monitor it?
With the Victron the data is available on their portal.  Does Sunsynk not have a portal also?
No on the Solarman portal you can only see stuff like battery voltage, temperature and SoC. Not info on the individual cells. Is there PC software with which I can view the info via the battery's USB port?
Hi guys ,i am busy building a lithuim battery. My system consists of Victron inverters and Victron charge controllers. I need a BMS that can comunicate with the Venus. Can anybody assist ?
Did you come right?
I'm looking as a similar install to yours, and this "unbalanced" cell issue has me a bit worried
Looks at the VRM data the freedom won system is still horribly unbalanced. Apparently installer and Freedom have been looking at the system remotely but I cannot get any sense from the owners of the system what they are saying / doing.  For me I would not buy Freedom Won -  their charging algorithms are very aggressive and don't seem to pull back when cells go out of balance .   rather go with  SolarMD.  Full cell visibility is also available with SolarMD via their communicator device and their portal
14 minutes ago, bobmabena said:
Did you come right?
No I haven't. I am going to e-mail Freedom Won directly and ask them.
On 2021/07/16 at 4:40 PM, vulgrim said:
I am building a 7p 16 s battery bank. I am using 112  100AH Sinopoly lithuim batteries.
Wow that's a huge capacity! 33.6kWh😳...Where did you buy your cells?
