WannabeSolarSparky Posted October 2, 2021 Share Posted October 2, 2021 Finally took the plunge and bought a better Off Grid Solar System Was again a bit of a learning curve to extract the data from the inverter. Finally have it working on RPi4 using a bit of Python with MQTT, Influxdb and Grafana Always amazes me how data can become so easily visualised on a single page. hoohloc, MdF, Buyeye and 1 other 4 Quote Link to comment Share on other sites More sharing options...
LumexClipsal Posted October 2, 2021 Share Posted October 2, 2021 (edited) Care to share how you accomplished that? Perhaps have a Pi image? well done.looks really good Edited October 2, 2021 by JoeyhZA Quote Link to comment Share on other sites More sharing options...
hoohloc Posted October 2, 2021 Share Posted October 2, 2021 This looks much better than the shine app or growatt server display. Interesting LumexClipsal 1 Quote Link to comment Share on other sites More sharing options...
WannabeSolarSparky Posted October 2, 2021 Author Share Posted October 2, 2021 3 hours ago, JoeyhZA said: Care to share how you accomplished that? Perhaps have a Pi image? well done.looks really good I will see what I can do to share this. Currently it only works for the growatt spf5000es, I am planning on making it work for other growatt models and maybe other inverter Brands too. LumexClipsal 1 Quote Link to comment Share on other sites More sharing options...
WannabeSolarSparky Posted October 2, 2021 Author Share Posted October 2, 2021 Another screen shot showing the charging data. Bit cloudy in Cape Town today so the data is all over the place at the moment LumexClipsal 1 Quote Link to comment Share on other sites More sharing options...
WannabeSolarSparky Posted October 2, 2021 Author Share Posted October 2, 2021 Anyone here know which Growatt side Li protocol to use for Narada BMS on the npfc100 batteries. Going to take me ages to cycle through each setting Quote Link to comment Share on other sites More sharing options...
Antonio de Sa Posted October 2, 2021 Share Posted October 2, 2021 1 hour ago, WannabeSolarSparky said: I will see what I can do to share this. Currently it only works for the growatt spf5000es, I am planning on making it work for other growatt models and maybe other inverter Brands too. I would be very much interested in such software, I have 2 X Growatt SPF 5000 ES inverters. running in master slave configuration. Quote Link to comment Share on other sites More sharing options...
WannabeSolarSparky Posted October 7, 2021 Author Share Posted October 7, 2021 Grafana Dashboard for SPF5000ES Be sure to load the following 2 plugins to grafana before using this template. grafana-cli plugins install fetzerch-sunandmoon-datasource grafana-cli plugins install briangann-gauge-panel Growatt SPF5000ES Solar Production and Usage Data-1633593721539.json LumexClipsal 1 Quote Link to comment Share on other sites More sharing options...
WannabeSolarSparky Posted October 7, 2021 Author Share Posted October 7, 2021 28 minutes ago, WannabeSolarSparky said: Grafana Dashboard for SPF5000ES Be sure to load the following 2 plugins to grafana before using this template. grafana-cli plugins install fetzerch-sunandmoon-datasource grafana-cli plugins install briangann-gauge-panel Growatt SPF5000ES Solar Production and Usage Data-1633593721539.json 314.1 kB · 1 download Forgot to mention, make sure its the latest version of grafana that fully supports transformations sanjeewasam and LumexClipsal 2 Quote Link to comment Share on other sites More sharing options...
WannabeSolarSparky Posted October 15, 2021 Author Share Posted October 15, 2021 Since crypto mining is paying for all the fancy new equipment I guess it should be fitting to add the crypto prices to that stats display Quote Link to comment Share on other sites More sharing options...
bkoekemoer Posted December 15, 2021 Share Posted December 15, 2021 Your dashboard looks so cool. Since Growatt decided to remove the History option for the shineServer web interface my monthly stats are lost. I still don't understand why they removed it.... Apparently its only available on the installers dashboard and that doesn't make sense at all Anyway, will have to play around with the API's and see if I can get to the historic data... Has anybody got a javascript or python script to retrieve the historic data? I have 2 x SPF 5000ES inverters running independently each on 1 phase of a 3 phase system. 2 x GCL E-KwBe 5.6kWh battery's. 16 x 420W Canadion PV panels. Quote Link to comment Share on other sites More sharing options...
Hozen Posted November 11, 2022 Share Posted November 11, 2022 Hello guys, I have two Narada 48NPFC100 which are connected to the Growatt SPF 5000 ES inverter. I have checked the parameters in the manual for Narada. However I need some help with the following parameters to ensure prolonged life and a healthy battery, would you please provide me with the recommended for the following parameters on the Growatt: Setting voltage point back to utility source when selecting SBU (program 12) Setting voltage point back to battery mode when selecting “SBU priority” (program 13) C.V charging voltage (program 19) Floating charging voltage (program 20) Low DC cut-off voltage (program 21) Thank you in advance! Quote Link to comment Share on other sites More sharing options...
capoccio1 Posted June 22, 2023 Share Posted June 22, 2023 (edited) hi all, i installed grafana on my raspberry following this guide: (https://github.com/sdsolomo/growatt-x000ES) I can access the webpage by typing raspberry IP:3000 but I don't see any data. From ssh if you do this command: growatt@raspberrypi:~ $ python3 getconfig.py python3: can't open file '/home/growatt/getconfig.py': [Errno 2] No such file or directory I get the error, how can I fix it? Edited June 23, 2023 by capoccio1 Quote Link to comment Share on other sites More sharing options...
capoccio1 Posted July 10, 2023 Share Posted July 10, 2023 hi, can someone help me? I followed the instructions step by step but I can't read the data Quote Link to comment Share on other sites More sharing options...
capoccio1 Posted July 10, 2023 Share Posted July 10, 2023 Quote Link to comment Share on other sites More sharing options...
capoccio1 Posted July 10, 2023 Share Posted July 10, 2023 getconfig.py getstatus.py Quote Link to comment Share on other sites More sharing options...
capoccio1 Posted July 11, 2023 Share Posted July 11, 2023 Anyone who can help me? Quote Link to comment Share on other sites More sharing options...
WannabeSolarSparky Posted July 11, 2023 Author Share Posted July 11, 2023 Hi @capoccio1 Did you download the pc software as I suggested so that you can test if you actually have communication with your cable? Quote Link to comment Share on other sites More sharing options...
capoccio1 Posted July 11, 2023 Share Posted July 11, 2023 if done, the inverter communicates as follows: Quote Link to comment Share on other sites More sharing options...
capoccio1 Posted July 11, 2023 Share Posted July 11, 2023 tried with different usb cables, they all give the same result Quote Link to comment Share on other sites More sharing options...
capoccio1 Posted July 13, 2023 Share Posted July 13, 2023 Hello, I contacted the inverter supplier who sent me the program, in the photo you can verify that the inverter communicates with the PC showing all the data, the USB cable works well. Quote Link to comment Share on other sites More sharing options...
