RIP InfiniSolar
And it is 3 phase. So nope this will not work for me.
  • Replies 86
  • Views 18.5k
  • SilverNodashi
    SilverNodashi
    don't worry 2017 is a couple weeks away
  • nope, they just switch to off grid mode or i suppose go into galv. isolation and continue to run from pv  and or battery
  • Jaco De Jongh
    Jaco De Jongh
    Ai Jaco, regtig jammer meneer, huil myself dood as dit met my gebeur.  Sterkte
AAaah! Of course, that explains why it was am option for my dad. He has 3-phase on the farm. The Symo he did buy in the end (non-hybrid) is three-phase too. The Galvo and Primo are the single-phase units, and it seems only the Primo comes as a Hybrid in SOME places (America).
That's a pity really. I don't think you can do any better than a Fronius if you want to go IP65.
Replus is rebranded Goodwe, they do not supply you with the new firmware if Goodwe brings out new firmware. So if the insurance gives me money I will replace it with a Goodwe.
Yes I did thanks.
What link ?
Some good news. The insurance is going to pay out. So hopefully I will have PV again this week some time.
They appointed a assessor to check out the unit  bla bla bla fish paste.
OK so my Goodwe is on its way. I am running a Infini 3Kw at the moment. Do some testing for a client but when my Goodwe is here I will replace the Infini.
Is the Goodwe going to achieve everything that you wanted?
"Ok so what units are out there that will
1) Works like the Infini. True hybrid by combining 3 power sources.
2) dont have any fans
3) 5kw and up pv generation
Wont break the bank."
Yes to all. According to the specs. Will soon find out what is lacking.
3
The Goodwe/Renesola units
A very expensive option: Solaredge SE5000 + Telsa Powerwall
There is a Fronius unit but I'm not sure of the model name.
Fronius is only 3 phase as stated above.
it not such an issue, i just split my db into two segments supplied by two Goodwe's  and all runs grand
I was thinking of doing the same with the 3kw Infini's. Much cheaper than a 5kw unit.
I just run all my loads on the grid feed side. If power fails I switch the load to the inverter side. All the stuff that have to stay on is on UPS power anyway. If we go away I will switch the load to the inverter. I also think that you can run 2 or more together all feeding the grid. So you don't need to have them in parallel.
yep all three of mine feed the grid with no issue and i never have an overload in the "kitchen" no moans from the Mrs, so i am super happy and i run everything thru them
OK Mike so Ploky said the inverters would keep each other up if eskom fails. Is that the case ?
