RIP InfiniSolar
Plonky this looks like a very nice inverter. It has sooo many communications options as wel.
https://www.solarweb.com/
This is their cloud service. (Mmmm sounds very familiar)
Anyway I just hope it has battery backup as well. I see they say in 2017 they will have a powerwall system
  • Replies 86
  • Views 18.4k
  • SilverNodashi
    SilverNodashi
    don't worry 2017 is a couple weeks away
  • nope, they just switch to off grid mode or i suppose go into galv. isolation and continue to run from pv  and or battery
  • Jaco De Jongh
    Jaco De Jongh
    Ai Jaco, regtig jammer meneer, huil myself dood as dit met my gebeur.  Sterkte
It does, does it not. :D
SMA has as good software, as has Victron.
Trick however, over time, comes in when you keep on swapping inverters and want to keep on using the same software to be able to really compare data.
But as I said, that takes time. ;)
Really sorry to hear about your damage Jaco. The best lowtech possible solution I can come up with is to build a mini veranda above the inverter and other kit and make sure it is sealed against the wall. At least it will divert torrents of water ingress from your valuable equipment. Good luck with finding a suitable replacement.
Edward the water should never get to that wall if the first place. In the 10 years of living in this house this was the first time that this happened.
The side of the wall / roof is painted with the "lap en pap" water sealant at the top of the roof. What happened in this case was the wind blew the water back up the tin roof and the water then dripped into the lip channel and the water then ran down the lip channel and started to drip out right into the inverter.
But now I know this can happen. Will still see what I will end up doing when I get the report from Mustek about the Infini.
@plonkster where did you see die Fronius has battery backup as well ?
Google "Fronius Primo Hybrid". I know it exists. I know the installer who installed my father's system mentioned that he could get hold of them (that's in Namibia). I have no idea if and where you'd get one locally :-(
Nope if I Google that all I get is about the Tesla Powerwall that is coming out next year.
Just got the report back from Mustek. It will cost R44k to fix the Infini. Now waiting for a letter from them to state it is not economical to repair it.
So it looks like the Goodwe is the way to go.
Darn it... about to email my insurance broker!!  Vas byt @JDP !
ouch!
Take it to UPS warehouse in Edenvale for a quote. The spares and labor shouldn't be THAT much. Mustek probably wants to replace the whole PCB instead of repairing it.
Silver i want to scrap it. I dont trust it anymore. I want to get an IP65 unit that will not blow up if it gets some water on it.
ok, no worries. I would have repaired it and made sure it doesn't get rain again. And, yes, I read what you said about the water. But still. It's an expensive, and good inverter, well worth repairing IMO
Yes, I doubt that they have the knowledge to repair it. Mustek is a computer peripherals supplier, which like Rectron, got onto the "load shedding" band wagon and started importing and distributing Voltronic inverters.  Like in the case of PCs, nothing on a pc board is repaired if it becomes faulty, the whole board is simply replaced.
Finally taking the time to look over that Primo Hybrid spec sheet. DC input voltage is 80-600V. Looks like they are doing the same thing the Solar Edge guys did: Use a GTI (with minor adaptations) and wire a lithium battery to the input instead of PV. Wire PV in "parallel" to the battery.
It will probably work with Lead Acid, but you'll need a 96V bank in all probability.
But it is only available from 2017. Where do you see you can get it now ?
The guy who installed my dad's Symo said he could get one. That was last year. In Windhoek. I haven't seen any advertised anywhere. Literally hearsay.
OK so then I cant get one. Aaaa plonky why get me all excited for something I can not get in SA ? :P
Has a delay of between 5 and 10 seconds when connecting and disconnecting from grid, 150v min battery voltage.
STILL WANT ONE!
How much do you think I could get on the black market for a "slightly used kidney"
