June 28, 20233 yr 19 minutes ago, SJB said: I was under the impression that the deye needs to talk to the BMS, so I can remove the CAN cable? You can leave it in and see if the inverter can still talk to the battery, but I would think it would communicate via the rpi anyway. I would plug the RPI into B1 RS485A and then go from B1 RS485B to B2 RS485A, like below. 25 minutes ago, SJB said: set the dip switches and I assume resetting the batteries Yes, you'll need to turn the batteries off, change the dips and switch them back on. It'll be best to turn the master on first.
June 28, 20233 yr Yes remove the CAN cable and connect SA assistant from the primary battery to the inverter.
June 28, 20233 yr that worked and I can see the battery packs but now the deye is beeping, do I need to change something in the settings
June 28, 20233 yr 19 minutes ago, SJB said: that worked and I can see the battery packs but now the deye is beeping, do I need to change something in the settings I'm not familiar with the Deye specifically, is there a setting for the BMS to use CAN comms? If so, try changing that to whatever you have the rpi plugged into (RS485?). Edit: something like this maybe: Edited June 28, 20233 yr by jumper
June 28, 20233 yr 2 hours ago, SJB said: I think it's this at the moment it's set to 00 and I see RS485 is 10 That could be it if you can change it there and SA can update the inverter, I can't tell if it is just being read from the inverter or can be changed, I don't have SA. If you can't change it there then you will have to change it on the inverter on the screen like I showed above or similar.
October 13, 20241 yr Hi, apologies for posting here. I’m using the same batteries and feeling really frustrated – I’m almost ready to give up on them. I’ve tried about 10-15 different DIP switch settings, but I’m still not sure if they are working properly. I have two batteries connected in parallel and using RS485 LAN and LI protocol (02 36) on my Growatt inverter. However, when I use the LI mode, the batteries charge very slowly, around 5A (250w-290w), and I can’t change the settings while in LI mode. But when I switch to USE or USE2, the charging speed jumps to 40A (1000w-1300w). The problem is, in these modes, I can’t see how much charge the batteries have (SOC) on the inverter. Could anyone please help me? I’m really exhausted dealing with this. Also, I’m not in the USA, so getting a solar assistance device isn’t an option for me.
November 9, 20241 yr On 2024/10/13 at 7:19 AM, Eftakher said: Hi, apologies for posting here. I’m using the same batteries and feeling really frustrated – I’m almost ready to give up on them. I’ve tried about 10-15 different DIP switch settings, but I’m still not sure if they are working properly. I have two batteries connected in parallel and using RS485 LAN and LI protocol (02 36) on my Growatt inverter. However, when I use the LI mode, the batteries charge very slowly, around 5A (250w-290w), and I can’t change the settings while in LI mode. But when I switch to USE or USE2, the charging speed jumps to 40A (1000w-1300w). The problem is, in these modes, I can’t see how much charge the batteries have (SOC) on the inverter. Could anyone please help me? I’m really exhausted dealing with this. Also, I’m not in the USA, so getting a solar assistance device isn’t an option for me. Unfortunately I'm not familiar with the growatt inverter and I run my battery in use mode, so I can't help much at all. FYI solar assistant is a South African company and they do ship internationally, so it doesn't matter where you are, it seems to be the only solution if you need accurate SOC on the inverter.
