Nothing is free - until now.
I have an Axpert Mk _ 5000  inverter. Used it for a year. Then the solar function gave in. For some reason the batteries fried.
BUT it was working perfectly fine as long as you disconnect the panels.
So, it still functioned perfectly as an inverter-charger as long as you don't worship the sun.
Free to a good home.
I also had x 3 Victron battery balancers (which worked perfectly before the Axpert fried the Omni battery bank)
- also to a good home.
whoever is first to respond gets it. But take it all. I cannot sukkel with item by item. My nerves are shot anyway.
The Axpert is perfect as a charger/ load-shed backup. Just don't attach panels.
I upgraded to Victron with great regret at my rash decision to connect panels to the Axpert.
Now you can have it for free - which does not reflect on you at all as the load shedding function is still perfect!!
Hi,
Also if available in Joburg will need those please to equalize batteries. Willing to collect or even pay for courier costs if not in Joburg
Edited by Quwatush Shams (Suly)
49 minutes ago, Clivevan said:
Yes you are first if you can collect from 30 Dundalk Parkview?
send me a private mail for email and tel number
Awesome, thanks will do
send me a private mail for email and tel number.
Great to help someone. All that is needed I guess is to connect panels via an external MPPT to manage the battery charging function and not charge from AC if that is also at fault and over charges
