Desperate for any help or advice
Hi everyone,
I am posting here out of despiration, I hope someone can help.
I noticed after my installation that my system was still using ALOT of grid power, between 60-70%.  I found this strange as I have a decent sized system and should be 90% off the grid.  Here is a link to that post:
This is what I have:
8kva Sunsynk inverter
10 x 555w pv panels
12.5kva battery
Solar geyser apart from main system.
Oven and stove not conected to system.
I also posted on Sunsynks forum regarding this, there is a very helpful gentleman on the forum that has assited me with a few pointers.
I unticked priority load and limit to load only, under system settings.
This from what I understand will help me to use the grid less, which is my main focus.
After unticking these boxes my readings on the inverter started to appear incorrect  Also from what I understand my CT clamp might be in on the wrong cable and/or facing the wrong direction.
Notice the reading of -194watts.
Funny thing is that during loadshedding the numbers are correct but when there is grid power the numbers dont make sense.
Here we had loadshedding between 12h00 and 02h00:
Screenshot_20230814_084456_SunsynkConnect.thumb.jpg.2b5dd5c3d29ca66c1909fac59ce2aea8.jpg
This is how the CT clamp is connected.
Any help or advice will be appreciated.  Even if someone maybe has the contact number of a technician that has good knowlage of the Sunsynk systems.
Many thanks,
Oelof
  • Replies 54
  • Views 7.2k
  • I just want to thank everyone that participated in this tread, everyone's input was very valuable in getting my plant to operate as it should. So it was quite journey to get to this point... the guys
  • What batteries do you have Oelof? Based on the RS485 12 it tells me you have either Pylontech batteries or Felicity lithium? It's a stone very far but I will be in Pretoria next week & I can defin
  • You need to tick priority load. That will let the system use power from solar (and not prioritise charging the battery). You also need to tick Zero export but untick limit to load. Limit to load = ess
You need to tick priority load. That will let the system use power from solar (and not prioritise charging the battery). You also need to tick Zero export but untick limit to load. Limit to load = essentials only. You have non-essentials that you want to feed from solar, so you don't want limit to load. But first show us the 2 System Mode screens. Also go to the main screen (press Esc until you see the dials) and then click on battery and show us that too. If you see negative readings under CT, it's pointing in the wrong direction. That will give us an indication whether your CT is pointing in the right direction. I assume your main breaker is the first 63A one on the left. If so, your CT needs to be connected to the red wire that leaves that breaker at the bottom. The arrow on the CT needs to point away from that breaker, ie. pointing towards the rest of your DB. Post those pictures and we'll advise further.
Edit: and I've just noticed your Normal light is not on. Has the system been fully deployed or why is that light off?
Edited by p_i
25 minutes ago, Oelof said:
Hi everyone,
10 x 555w pv panels
12.5kva battery
Many thanks,
Oelof
Change the white and black. White on 5 , Black on 6.
Arrow on Ct should point down as it is installed now
Thanks vir wat, I did swop them but did not notice any difference. Perhaps the inverter takes some time to adjust?
Also on the Sunsynk forum a gentleman thats assisting me with the same issue mentioned that the CT clamp is on the wrong cable and should be on this cable?
There appears to be only one red wire leaving that 63A breaker, so it makes no difference whether it's connected to the input red (top) or the output red (bottom). Simply trace the wire at the bottom of the 63A and make sure that's the one that the CT coil is clamped to.
11 minutes ago, p_i said:
You need to tick priority load. That will let the system use power from solar (and not prioritise charging the battery). You also need to tick Zero export but untick limit to load. Limit to load = essentials only. You have non-essentials that you want to feed from solar, so you don't want limit to load. But first show us the 2 System Mode screens. Also go to the main screen (press Esc until you see the dials) and then click on battery and show us that too. If you see negative readings under CT, it's pointing in the wrong direction. That will give us an indication whether your CT is pointing in the right direction. I assume your main breaker is the first 63A one on the left. If so, your CT needs to be connected to the wire that leaves that breaker at the bottom. The arrow on the CT needs to point away from that breaker, ie. pointing towards the rest of your DB. Post those pictures and we'll advise further.
@p_i
This is exactly what another user said on the the sunsynk forum. I will post the settings in a few minutes, but I think were on the right track now.
Thanks for all the help.
Ok will do.
Here is a better photo
Correct.
Preferably on top of the incomer breaker but should make no difference like it is now at the bottom of the breaker. Same feed.
Just now, VirWat said:
Correct.
Yes, but it might be difficult to get the CT coil around the top wire unless it's out in the clear somewhere slightly further away. There doesn't appear to be any space in that photo. 😀
Still say.
Just change the CT direction where it is installed now.
Arrow should point down.
Iow. The white /black wires should be at the bottom
2 minutes ago, VirWat said:
Still say.
Ok no problem. I am no electrician, so I will have to turn off all the mains first. I will probably only be able to do that tomorrow though. Should I still swop the black and white on the inverter as well?
You should either swap the direction of the CT coil or simply swap the wires. The net effect is the same as long as you don't do both actions!
Ok, I will swop the wires on the Inverter. This is much easier. Let me do that and take some pictures of my settings. I will revert shortly.
Before you swap wires first post the photos. That will give us confirmation as to whether you need to swap wires.
Just a remark. It seems strange to see such a thick wire on the 30A MCB to the right of you main switch yet the 63A MCB has a thinner red wire connected.
You have been given great advice so far.
YES!
Both seems to be 10 Sq to me. May be wrong!
Sorry for butting in here. What you say makes sense; however my SS inverter setting is priority battery and when I have PV available, the house loads get fed first, and any surplus PV charges the batteries, not vice versa with battery first etc. This is obviously the way I want it. In similar scenario, if I’m already at my preset minimum SOC, with grid present, then PV goes to house loads first, but if there’s insufficient PV it draws the shortfall from the grid. No battery recharge prioritization over load/house ever. Does this make sense?
In terms of limiting grid usage per the OP, the two most critical things for me were to shift loads to a little later in day and try to stagger (and have a sufficiently low SOC setting for daytime to accommodate the swings of power usage), and having the „limit to house“ setting permanently enabled (with a bit of battery SOC setting intervention) so that non-essentials benefit from the sun during the day. All assuming CT coil etc are correct obviously.
Ok, I've swopped the black and white on the inverter. Its still giving a - reading though.
Here are the settings as requested:
Screenshot_20230814_200316_Gallery.jpg.af3e4518b58950bd47f6714fc19eefde.jpgScreenshot_20230814_200258_Gallery.thumb.jpg.61e8afcd85f5bf71ba9322702de17c87.jpgScreenshot_20230814_200243_Gallery.thumb.jpg.0e815cf8da52f3a8478da7a77d21e031.jpgScreenshot_20230814_200227_Gallery.thumb.jpg.119499fd2a3b1bf16786855b0a0d0ad2.jpg
You missed the photo for this one.
2 minutes ago, Virwat said:
Any Essential/ non Essential DB installed?
Photos please.
Only the stove and Geyser is not directly on the inverter
