August 26, 20232 yr Thank you as always. As a DIY handyman on a budget which would be the best allrounder wire stripper and best crimper to have in my tool-bag? Something I could use around the house for general maintanence and for my intended hobby building DIY lithium pouch cell batteries during retirement. Any & all advice appreciated.
August 26, 20232 yr 43 minutes ago, DenBeech said: Thank you as always. As a DIY handyman on a budget which would be the best allrounder wire stripper and best crimper to have in my tool-bag? Something I could use around the house for general maintanence and for my intended hobby building DIY lithium pouch cell batteries during retirement. Any & all advice appreciated. For diy this stripper and crimper would be fine and wouldn't break the bank.
August 26, 20232 yr https://leroymerlin.co.za/1-5mm-6mm-crimping-tool-ctr0333-major-tech?sfdr_ptcid=32806_617_695180264&sfdr_hash=490e60f8e29deb646d1cc2d354738722&gclid=CjwKCAjwoqGnBhAcEiwAwK-OkQJOVuWxeHGXzvlxK9FRk-L9joJ2rJ77dghcgwMC-hfZX-Rx_sLcVhoC31UQAvD_BwE https://leroymerlin.co.za/auto-wire-stripper-dexter-200mm?sfdr_ptcid=32806_617_516943601&sfdr_hash=acc169d44d67b8b3a5a384144a3be786&gclid=CjwKCAjwoqGnBhAcEiwAwK-OkUhJmcnA2sHecntKNG80AuKwKLia9wCPlvcEq8ndKzU55dQyGZsMJRoC-GgQAvD_BwE
August 26, 20232 yr I purchased a crimper from Mantech and then found out they had the inserts loose. bought 2 most common inserts for my use. a few weeks back seen Addendorf had a crimper that comes with 5 sets of inserts for R500. less than half what i paid at Mantech. Edited August 26, 20232 yr by razzor13bt
August 26, 20232 yr https://leroymerlin.co.za/auto-wire-stripper-dexter-200mm?sfdr_ptcid=32806_617_516943601&sfdr_hash=acc169d44d67b8b3a5a384144a3be786&gclid=CjwKCAjwoqGnBhAcEiwAwK-OkUhJmcnA2sHecntKNG80AuKwKLia9wCPlvcEq8ndKzU55dQyGZsMJRoC-GgQAvD_BwE This wire stripper that Talia posted is a crimper as-well..2 IN 1 TOOL.
August 26, 20232 yr 1 hour ago, razzor13bt said: a few weeks back seen Addendorf had a crimper that comes with 5 sets of inserts for R500. You don't perhaps have a link or know what the brand was? Just checked their site and couldn't find it.
August 26, 20232 yr There are 2 sets where the crimp dies can be changed, the first one is in a bag and the second one in a plastic case, I do not know if the dies are different between the two sets. The third link is a solar set with a crimping plier and wire stripper which works great for solar cable. https://www.adendorff.co.za/mac-afric-crimping-plier-set-including-5-interchangeable-inserts-tcrimp007 https://www.adendorff.co.za/tcrimp008 https://www.adendorff.co.za/tcrimp009 The first link is similar to the one that TaliaB posted, the second one is also self adjusting but works a bit better than the first one with some cables. https://www.adendorff.co.za/self-adjusting-wire-stripper https://www.adendorff.co.za/felo-auto-wire-stripper-pliers-insulated-vde-02-60-mm-tstrip001 Have a look at their website for the closest branch, make a note of the item code, phone the branch and ask they must do a physical stock check and if stock is low ask them to keep one aside.
