Posted November 30, 20186 yr Hi all! I share with you a very low cost radiation sensor I have installed at home. It is only needed a small sollar panel, 5w 18 Vo, a ESP32 and a pair of 10 ohm resistors. Here you have the scheme: You can see my radiation sensor online on this web: beduino.sytes.net/www/radiation.php Iy you are interested i can send the code for esp32. We´ve got a cloudy day and it is funny. Edited November 30, 20186 yr by Javi Martínez
November 30, 20186 yr Author The code: #include <ETH.h> #include <WiFi.h> #include <WiFiAP.h> #include <WiFiClient.h> #include <WiFiGeneric.h> #include <WiFiMulti.h> #include <WiFiScan.h> #include <WiFiServer.h> #include <WiFiSTA.h> #include <WiFiType.h> #include <WiFiUdp.h> //#include <stdio.h> const char* ssid = "******"; // your ssid const char* password = "*****"; // your pass const char* host = "*****"; // your host int t; float v; void setup() { Serial.begin(2400, SERIAL_8N1); // We start by connecting to a WiFi network Serial.println(); Serial.println(); Serial.print("Connecting to "); Serial.println(ssid); WiFi.begin(ssid, password); while (WiFi.status() != WL_CONNECTED) { delay(500); Serial.print("."); } Serial.println(""); Serial.println("WiFi connected"); Serial.println("IP address: "); Serial.println(WiFi.localIP()); } void loop () { for (int i=1;i<=5;i++) {int a=analogRead(39);t=t+a;delay(200);} float k = t; t=0; k = k/5; v=2*k/4095*3.3/10*1000/0.33; // 0.33 is the ISC of my pannel in Amps. Use your ISC. //Serial.print("connecting to "); //Serial.println(host); WiFiClient client; const int httpPort = 80; if (!client.connect(host, httpPort)) { Serial.println("connection failed"); return; } String url = "*****"; // your URL client.print(String("GET ") + url + v + " HTTP/1.1\r\n" + "Host: " + host + "\r\n" + "Connection: close\r\n\r\n"); unsigned long timeout = millis(); while (client.available() == 0) { if (millis() - timeout > 5000) { Serial.println(">>> Client Timeout !"); client.stop(); return; } } while (client.available()) { //String line = client.readStringUntil('\r'); //Serial.print(line); } //Serial.println(); //Serial.println("closing connection"); }
December 3, 20186 yr Author Fog is the same that night for solar pannels....😴 https://thingspeak.com/channels/640675
December 3, 20186 yr Hi Javi Are you using this to compare your (large) solar panel power production with a small reference panel? I can see this being useful to quickly check if there is a problem, on your main solar panels, without having to climb onto the roof.
December 3, 20186 yr Author 1 minute ago, NigelL said: Hi Javi Are you using this to compare your (large) solar panel power production with a small reference panel? I can see this being useful to quickly check if there is a problem, on your main solar panels, without having to climb onto the roof. Yes, you are right.
December 3, 20186 yr I think that I will need to make one of these. I am not sure if you are familiar with the bird called the "Hadeda". It is quite large, loud, and also has a correspondingly large droppings! My house seems to be on the Hadeda and Egyptian Goose flight-path to a nearby water reservoir.... 😀
December 3, 20186 yr 29 minutes ago, NigelL said: Hadeda Hadeda Ibis (Bostrychia hagedash). Kaaaa! Kaaaa! (at 6AM in the morning)... Also, my dog chases them. Edited December 3, 20186 yr by plonkster
December 3, 20186 yr 7 minutes ago, plonkster said: Kaaaa! Kaaaa! (at 6AM in the morning)... I believe it is the only avian species with a fear of hights. Once on the ground walking, not a peep. Once they get airborne, and gain some height, Kaaaaa!!!!! Kaaaaa!!! :-)
December 3, 20186 yr 7 minutes ago, Riaanh said: I believe it is the only avian species with a fear of hights. Once on the ground walking, not a peep. Once they get airborne, and gain some height, Kaaaaa!!!!! Kaaaaa!!! :-) HAHAHA!
December 10, 20186 yr @Javi Martínez , thank you for the idea , I had a look at the code and it seems like you are measuring the voltage of the panels with a resistor for the load. I liked the idea and jumped at it and patched up a small panel to a ardunio. Used a LED as a resistor but I I found that it just dropped the peak voltage to a lower value rather than "following" the solar output. Here is a pick of the last few days data , you will see that it stays virtually the same all the time even , like today , we have hardly any sunshine . Should I get a larger Panel? Best regards Paul
December 10, 20186 yr Author No. You need a resistor. If you use a led you Will have the same Voltage, the forward drop Voltage of led. Which panel are you using? Vo and power. @PaulF007 Edited December 10, 20186 yr by Javi Martínez
December 10, 20186 yr Thank you , I will add a small resistor instead. 3 hours ago, Javi Martínez said: Which panel are you using? Vo and power One of those very small panels that you get on the garden solar lights. So I dont have an idea of what the specks would be. I measured 3.2 v OC but that is as much as what I have.
December 10, 20186 yr Author 1 minute ago, PaulF007 said: Thank you , I will add a small resistor instead. One of those very small panels that you get on the garden solar lights. So I dont have an idea of what the specks would be. I measured 3.2 v OC but that is as much as what I have. If you measure 3.2 V, I suppose Isc will be 300 ma?. Then you can try with a 1 Ohm resistor. Also you have to change the skects, because ADC of ESP32 is 12 bits and Arduino is 10, and ESP measures from OV to 3.3 V and Arduino from 0 to 5 V
December 10, 20186 yr 28 minutes ago, Javi Martínez said: Then you can try with a 1 Ohm resistor. Also you have to change the skects, because ADC of ESP32 is 12 bits and Arduino is 10, and ESP measures from OV to 3.3 V and Arduino from 0 to 5 V Oh yes I have changed it , infact I created a new sketch as I am sending the data directly to Emoncms , but at the moment I am measuring the volts as the figure it self does not make any difference. Ill change to the 10 ohm and have a look at the data for a day or two.
December 28, 20186 yr Ok - running the little panel for a couple of day's I happy to report that this little bugger works well. I ended up not using your sketch. I prefer a wired system so I went for an Arduino with ethernet shield. I also prefer to use MQTT as a data protocol as I can use it within the home automation system as well. While I was at it I also added an LDR and a Temp sensor to the panel just to compare the Light intensity as well as the Temperature output to the solar radiation. As usual Emon CMS is used. First Graph is the " Calibrated " values comparing the solar output to the radiation monitor. ( Forgot to mention I decided to capture the panel volts instead for the radiation value as both values are calculated from the analog output so it would not make much difference ) . I calculated the difference between the "Radiation Panel " and the solar output on a bad weather day, this way I knew that all the power that the panels could provide would be used. This is quite close The next graph is the "Radiation Sensor" vs the Temp sensor. You can see that it follows the output. It will be interesting to see how this changes in the winter months. The last one is the LDR value. Even if the radiation changes the light intensity does not change much. In conclusion, I am happy to report that works surprisingly well considering I am using one of those small cheapo solar panels that powers a led for a week and then gets thrown in the bin. Thank you @Javi Martínez for sharing the idea. I can now use the data to switch the geyser on or off during daytime to optimize some of the "lost" energy .
December 29, 20186 yr Author On 2018/12/28 at 4:58 PM, PaulF007 said: Ok - running the little panel for a couple of day's I happy to report that this little bugger works well. I ended up not using your sketch. I prefer a wired system so I went for an Arduino with ethernet shield. I also prefer to use MQTT as a data protocol as I can use it within the home automation system as well. While I was at it I also added an LDR and a Temp sensor to the panel just to compare the Light intensity as well as the Temperature output to the solar radiation. As usual Emon CMS is used. First Graph is the " Calibrated " values comparing the solar output to the radiation monitor. ( Forgot to mention I decided to capture the panel volts instead for the radiation value as both values are calculated from the analog output so it would not make much difference ) . I calculated the difference between the "Radiation Panel " and the solar output on a bad weather day, this way I knew that all the power that the panels could provide would be used. This is quite close The next graph is the "Radiation Sensor" vs the Temp sensor. You can see that it follows the output. It will be interesting to see how this changes in the winter months. The last one is the LDR value. Even if the radiation changes the light intensity does not change much. In conclusion, I am happy to report that works surprisingly well considering I am using one of those small cheapo solar panels that powers a led for a week and then gets thrown in the bin. Thank you @Javi Martínez for sharing the idea. I can now use the data to switch the geyser on or off during daytime to optimize some of the "lost" energy . Good! If you like this kind of things, I can share a circuit which makes a capacitive barrier of solar pannel, obtaining 64 points of IV curve. I think It is interesting because you know the power that FV could give in that moment. What we did is obtain solar radiation, without considering cell temperature.
May 6, 20204 yr Hi Javi! Great work. I currently start to experiment with sensors and ESPs, and i want to measure solar radiation from a solar panel like you did. Can you pliz explain me the function you use for the calculation of the radiation? In particular that line of code : v=2*k/4095*3.3/10*1000/0.33; // 0.33 is the ISC of my pannel in Amps. Use your ISC Do you use anywhere the dimensions of the solar cell at the calculation since its W/m2? My solar panel is 6V 1.1W 200mA , 112 x 84 mm. I use ESP32. Pliz help if you can. Thanks. Nick.
