Jaco De Jongh Posted December 2, 2018 Share Posted December 2, 2018 If any, what din mount changeover switch do you use/prefer. Any recommendation for online electrical wholesales. (ACDC and RS excluded) Quote Link to comment Share on other sites More sharing options...
Mike Posted December 2, 2018 Share Posted December 2, 2018 i tend to use the Hager 63A changeover, found it to be the most stable over the last 5 years, on the smaller off grid installs i have used the Hager 40A between genie and inverter Mark, Jaco De Jongh, Juokorow and 1 other 3 1 Quote Link to comment Share on other sites More sharing options...
Jaco De Jongh Posted December 2, 2018 Author Share Posted December 2, 2018 38 minutes ago, Mike said: Hager 63A changeover Just looked at them on one site... Wants the Changeover to be the same as the rest of the breakers to ensure uniformity. The hager range might just fit the application. Quote Link to comment Share on other sites More sharing options...
___ Posted December 2, 2018 Share Posted December 2, 2018 I have a Hager changeover as well. Reasonably priced, feels quite solid, and does the job. Jaco De Jongh 1 Quote Link to comment Share on other sites More sharing options...
alkafak Posted December 2, 2018 Share Posted December 2, 2018 I used this one and comfortable fornme Jaco De Jongh 1 Quote Link to comment Share on other sites More sharing options...
langou Posted December 2, 2018 Share Posted December 2, 2018 Also use them with happiness!! Try ElctroMechanica online store - has big Hager selection. Jaco De Jongh 1 Quote Link to comment Share on other sites More sharing options...
SilverNodashi Posted December 10, 2018 Share Posted December 10, 2018 Those Hager changeover switches work very well and are of good quality ___ 1 Quote Link to comment Share on other sites More sharing options...
Fanie Minnie Posted July 12, 2022 Share Posted July 12, 2022 On the diagram, what is 'PLN' I understand load = Eskom 220V? and INV Out = inverter output/220V? Quote Link to comment Share on other sites More sharing options...
Scorp007 Posted July 12, 2022 Share Posted July 12, 2022 7 hours ago, Fanie Minnie said: On the diagram, what is 'PLN' I understand load = Eskom 220V? and INV Out = inverter output/220V? I put from the grid/Eskom Quote Link to comment Share on other sites More sharing options...
CraigL Posted July 13, 2022 Share Posted July 13, 2022 LOAD - Supply to DB from change over switch PLN - Eskomsepush INV Out - 220V supply coming from inverter Quote Link to comment Share on other sites More sharing options...
