July 6Jul 6 Am fully aware that one of the best ways to heat up a home in winter is to have a heat pump, however if one has installs a solar system with batteries, what would be the most effective way to heat up a home in winter at the most cost effective way? Ideally the method would involve or ensure that the battery systems are not too taxed or strained. Your thoughts forumites would be most appreciated, thanks.
Tuesday at 09:125 days 15 hours ago, Moffat said:... if one has installs a solar system with batteries, what would be the most effective way to heat up a home in winter at the most cost effective way? Ideally the method would involve or ensure that the battery systems are not too taxed or strained.This could turn into a very interesting discussion... My thoughts:One would obviously have to consider daytime (good solar harvest) and nighttime (and bad solar harvest daytime when e.g. it is very cloudy or raining) separately.Daytime with good yield: Simply use electricity generated by your PV. This assumes that your system was properly planned and "over sized" for this eventuality. I switched on my 2kW electric blower heater at 08:30 this morning, and just charged the batteries a little slower. Currently (11:00) my solar harvest is just over 5.3kW, and I'm comfortably running both my 2kW geyser and the heater from solar, and a 8000 BTU inverter type air conditioner set to heat whilst still charging the batteries at a low 640W. Around 12:00 the heater will be switched off so that my wife can use the stove (the batteries will be fully charged by then). I planned for this when I designed my system larger than normal (12kW inverter), and even though the ROI might not be as good as some people would like it to be, I am enjoying the "luxury" of being practically off-grid and warm during the cold Free State winter 😁Daytime with bad solar yield: We use the gas heaters.Nighttime: Now this is where we can have a serious discussion about draining the batteries vs running the risk of not having power if there happens to be an electrical outage or load shedding the next morning... and where the esoterics can be thrown around 😉 (How about a "sand battery" heater?). We have under-carpet heaters in the house that are run off the battery for an hour or so at night if really needed, although I don't like to drain my batteries lower than 50% SoC.Looking forward to inputs from other Forumites...
Tuesday at 02:215 days Author 5 hours ago, HennieL said:This could turn into a very interesting discussion... My thoughts:One would obviously have to consider daytime (good solar harvest) and nighttime (and bad solar harvest daytime when e.g. it is very cloudy or raining) separately.Daytime with good yield: Simply use electricity generated by your PV. This assumes that your system was properly planned and "over sized" for this eventuality. I switched on my 2kW electric blower heater at 08:30 this morning, and just charged the batteries a little slower. Currently (11:00) my solar harvest is just over 5.3kW, and I'm comfortably running both my 2kW geyser and the heater from solar, and a 8000 BTU inverter type air conditioner set to heat whilst still charging the batteries at a low 640W. Around 12:00 the heater will be switched off so that my wife can use the stove (the batteries will be fully charged by then). I planned for this when I designed my system larger than normal (12kW inverter), and even though the ROI might not be as good as some people would like it to be, I am enjoying the "luxury" of being practically off-grid and warm during the cold Free State winter 😁Daytime with bad solar yield: We use the gas heaters.Nighttime: Now this is where we can have a serious discussion about draining the batteries vs running the risk of not having power if there happens to be an electrical outage or load shedding the next morning... and where the esoterics can be thrown around 😉 (How about a "sand battery" heater?). We have under-carpet heaters in the house that are run off the battery for an hour or so at night if really needed, although I don't like to drain my batteries lower than 50% SoC.Looking forward to inputs from other Forumites...@HennieL funny you mention fault, we actually had a nationwide grid failure in Zim last night from 18:21hrs to 23:17hrs, though power restoration began happening in some areas after the 2hr mark. Am just thinking of relatively cheap 800w to 1,500w space heaters and their impact moreso for me with only 2 x 5kw batteries. Daytime generation definitely is an important consideration and having enough panels important but night time is greater part of any home heating, well save for areas like Capetown where you may get snow and others near Lesotho which can almost be 0º degrees during the daytime at extreme times...That 800w to 1,500w also pulls a lot over 3-5hrs of evening time, especially where a home or room does not have adequate insulation as well hey. Edited Tuesday at 02:255 days by Moffat Additional information
Tuesday at 02:385 days 1 minute ago, Moffat said:... night time is greater part of any home heating, well save for areas like Capetown where you may get snow and others near Lesotho which can almost be 0º degrees during the daytime at extreme times...We really suffered in the Free State when we experienced the sh**ty unseasonable Cape Town winter weather the last two months - I'm really glad this is the exception, and not the rule... Even though we dropped down to -2 - -3 degrees the last few days, clear winter skies still allowed for very good yield this past week.Regarding night-time heating, the only practical solution would be to store heat (electricity) during the day for use at night. I also like the idea of building a "sand battery" heater, but unless one is prepared to make a large container with sand a feature of your living room or study (or bedroom...), there is no practical way to a) store the container out of the way while it is "charging" during the day and b) moving the container around to where it is needed whilst hot (and heavy...). One practical method would be to use an oil-based radiator heater (like they use(d) in schools and hospitals), have the large sand battery located outdoors, and run a heat-exchanger type system between the radiator heaters and the sand battery - quite possible, and relatively easy to construct, but expensive.
Tuesday at 06:164 days For surviving on minimal power, a 400W wall panel heater per room, then close interleading doors and only heat the rooms you need. Or electric blankets.
Friday at 11:332 days You're in Zimbabwe, in that warm climate winter heating should be the last thing on your mind. I am in a small off-grid home, so my 24K and 18K inverter aircons take care of heating throughout the night. I set them to 22 degrees and just forget about them.
Friday at 12:592 days 1 hour ago, Yellow Measure said:You're in Zimbabwe, in that warm climate winter heating should be the last thing on your mind.I am in a small off-grid home, so my 24K and 18K inverter aircons take care of heating throughout the night. I set them to 22 degrees and just forget about them.Winter evenings in Zim gets very cold. It’s just the day that is warm in winter. Edited Friday at 01:002 days by Denns
Friday at 05:402 days 2 hours ago, Kalahari Meerkat said:Rocket stove mass heater...You pipped me to the post. Even if you don't use the rocket side of things the concept could be used i.e., the clay couch you build will become your sand battery heated by however you would have heated a conventional sand battery
Friday at 06:261 day 5 hours ago, Denns said:Winter evenings in Zim gets very cold. It’s just the day that is warm in winter.Interesting. I spent a week in Bindura province in February a few weeks ago, it was very hot, both days and nights.
Friday at 06:571 day 3 hours ago, Kalahari Meerkat said:Rocket stove mass heater...How do you deal with the carbon monoxide?
Yesterday at 06:271 day 12 hours ago, Yellow Measure said:Interesting. I spent a week in Bindura province in February a few weeks ago, it was very hot, both days and nights.Feb is a bit too early. I went in June and it was bloody cold at night. During the day you can be in shirts and shorts.
Yesterday at 09:331 day 14 hours ago, Yellow Measure said:How do you deal with the carbon monoxide?a rocket mass heater has a exhaust/chimney out of the house, normally, so that takes care of the exhaust gases, since most local houses are not built to prevent air exchange from the outside and burning the wood, would consume oxygen which get expelled via the exhaust, fresh air from outside would be drawn in via the various holes and possible vents... the amount of wood that these consume vs the heat produced is unbeatable...
12 hours ago12 hr 20 hours ago, Kalahari Meerkat said:rocket mass heater has a exhaust/chimney out of the houseWhy not use a closed, slow combustion fireplace in stead of a rocket stove? One could add some vent controls in the house to distribute the heat throughout the house.
10 hours ago10 hr 1 hour ago, frivan said:Why not use a closed, slow combustion fireplace in stead of a rocket stove? One could add some vent controls in the house to distribute the heat throughout the house.Or just use solar...@frivan , I think you will like this (being technically minded): I did some calcs, and a simple 1.0m x 0.6m x 0.8m double brick "box" filled with sand and covered with good insulation (~80mm glass wool sheets), and heated by ~20kWh of solar during the day could easily keep 2 rooms warm between (say) 18:00 and 08:00 the next nothing with nothing more than a small air blower moving cold air from the house, through this "sand battery" via a zig-zag network of pipes, and back into the house with heated air. I am in a good mind to try something like this myself, building the "box" against my study's outer wall - low tech weekend project with high value (if it works... 🤔)
5 hours ago5 hr 4 hours ago, HennieL said:you will like thisI like it. Was wondering if a couple of 50mm holes through the wall will work for the external box... But screw it, dig up the floor!
5 hours ago5 hr 4 minutes ago, frivan said:I like it. Was wondering if a couple of 50mm holes through the wall will work for the external box... But screw it, dig up the floor!Airflow design is not my field of expertise, but I thought that a practical starting point would be a 100mm or 150mm silent type of bathroom extraction fan - something that will fit a similar sized galvanized metal pipe going through the wall, with the "extraction" side housing the fan at floor level (or a bit above), and the hot air return pipe entering the room at mid height of the wall. The most challenging part would likely be the sourcing (or more likely manufacturing) of a reduction section to take this diameter down to (say) a 25-30mm metal pipe that would run zig-zag through the hot (~300C) sand... I will try to source stainless steel pipe to ensure a long service life if the cost is not exorbitant, else normal galvanized plumbing pipe?
5 hours ago5 hr 7 minutes ago, HennieL said:hot air return pipe entering the room at mid height of the wallSounds good. Just note the risk of 300 degree air coming out with natural convection.9 minutes ago, HennieL said:galvanized plumbing pipeWith galvanized water pipes, you can easily build a radiator (heat exchanger) close to the top of the sand. I would put the elements in the bottom of the sand. Perhaps add a few pipe coils in the box for convection and heat distribution.
41 minutes ago41 min 4 hours ago, frivan said:Sounds good. Just note the risk of 300 degree air coming out with natural convection.Yes, thanks for the heads up. I'm sure one could build a "bleed valve" of some kind, perhaps using the venturi principle, to suck cold air from the room (or the outside) into this hot air flow to "dilute" the hot air down to a safe temperature. Will obviously have to play around with just about everything to "fine tune" this, learning on the way - this is actually what might make up my mind to try this half-baked DIY idea 😁
