July 14, 20206 yr Hi Guys. Any expierence with a Phocos PSW-H Any-Grid 5Kw inverter and Pylontech Lithium Ion 3.5kW US3000 Battery combination. The Phocos PSW-H seems to be a Frid tied or Hybrid, depending on you're applicaton. I personall have not heard about this brand. I am desciding on the above solution or an Axpert Inverter MKS 5K-48v MkII 120-450Vdc with a Pylontech Lithium Ion 3.5kW US3000 Battery combination.
July 16, 20206 yr Phocos is compatible with Pylontech batteries' BMS. It's a well.designed inverter with very flexible output source priority and battery charging settings
July 16, 20206 yr Read this manual Any-Grid_PSW-H_Battery-settings-for-Pylontech-Batteries_2020-05-20 (1).pdf
August 16, 20206 yr On 2020/07/14 at 10:24 PM, KobusK said: Any expierence with a Phocos PSW-H Any-Grid 5Kw inverter and Pylontech Lithium Ion 3.5kW US3000 Battery combination. A freind of mine recently installed a phocos and it looks like quite a nice inverter with a reasonable price R16K it seems it can mix utility and solar. Have anybody installed one and how is it comparing with other inverters?
January 10, 20215 yr On 2020/08/16 at 4:42 PM, Gerrie said: A freind of mine recently installed a phocos and it looks like quite a nice inverter with a reasonable price R16K it seems it can mix utility and solar. Have anybody installed one and how is it comparing with other inverters? I have installed 2 phocos anygrid 5kW inverters and I'll recommend the inverter. Its a very solid and flexible inverter. I'll say its better than the infinsolar range and the pricing ia reasonable. It's also less noisy, its a very good inverter
June 4, 20215 yr On 2021/03/11 at 3:01 AM, DarrenG said: How would you say they compare to the Growatt inverters? Good question
June 4, 20215 yr On 2021/03/11 at 3:01 AM, DarrenG said: How would you say they compare to the Growatt inverters? lol if you ask me i can tell you upfront . growatt have their own in house krappy development team so their firmware lacks alot of the stability in functions like charging up batteries and then turning off solar at 100% soc = dumb Phocos yet to see what it does but i can almost guess their version of the firmware works way better . If any one can sponsor me a unit for a day or two i can do a full review . unless you wait till i can get one in stock as i need to develop my bms rs485 protocol so wont be too far ..
August 5, 20224 yr Hello Am looking for PhocosLink device for monitoring on Phocos AnyGrid Inverters, where i can buy this in SA. Sama
September 8, 20223 yr Hi Sama, I see Valsa sells these. I am planning to purchase one too. Phocos Any-Grid™ Series | Johannesburg, South Africa. (valsa.co.za) Regards, Jaco
