October 2, 20205 yr Hi All I have been searching, but haven't been able to come up with a definite answer. Can the Sunsynk/Deye/Ohm 5kW inverters be setup to in parallel on a 3-phase network? i.e. 3 inverters (1 per phase) sharing the same battery? I have seen reference to being setup in parallel on one phase, but lacking info on 3-phases setup. Thanks in advance
October 2, 20205 yr Yes the Sunsynk can be set one per phase. Currently there's no 3 phase Sunsynk's on the market.
October 2, 20205 yr 2 hours ago, DaveP said: Hi All I have been searching, but haven't been able to come up with a definite answer. Can the Sunsynk/Deye/Ohm 5kW inverters be setup to in parallel on a 3-phase network? i.e. 3 inverters (1 per phase) sharing the same battery? I have seen reference to being setup in parallel on one phase, but lacking info on 3-phases setup. Thanks in advance Hi Dave yes the Sunsynk 5.5 and 8.8 Can be setup in 3 Phase The inverters each attach to a Phase and they have comms cables that they use to communicate with each other they share the same Battery bank be it Litium or Lead acid PM me your email address and I can send you the installer manual via email
October 2, 20205 yr Author 3 hours ago, Boerseun said: Hi Dave yes the Sunsynk 5.5 and 8.8 Can be setup in 3 Phase The inverters each attach to a Phase and they have comms cables that they use to communicate with each other they share the same Battery bank be it Litium or Lead acid PM me your email address and I can send you the installer manual via email Thanks Boerseun That's exactly what I was hoping for. Been looking for a 3-phase grid tied hybrid solution that uses a 48V battery system. Only 3-phase hybrids on CoCT approved inverter list use high voltage batteries. Will send you a PM for the manual, thanks.
October 2, 20205 yr Author 4 hours ago, Chloe said: Yes the Sunsynk can be set one per phase. Currently there's no 3 phase Sunsynk's on the market. Thanks, just what I was hoping for
April 7, 20215 yr Hi all, I see this very old conversation. To ask a further question, id I may... I have bought three of the Sunsynk 5 kW inverters. I want to couple it for 3 phase. Will the coms cables goes from INVETER 1 (Master, A phase) = Parallel 2 plug, to INVERTER 2 (Slave, B phase) = Parallel 1 plug, then the Parallel 2 plug to INVERTER 3 (Slave, C phase) = Parallel 2 plug ????
April 27, 20215 yr Good afternoon, My name is Ussemane José From Mozambique, I want to know if Sunsynk does fabricate 3ph inverter from rang 8-40kW suitable for large houses
April 28, 20215 yr 21 hours ago, Ussemane Jose said: Good afternoon, My name is Ussemane José From Mozambique, I want to know if Sunsynk does fabricate 3ph inverter from rang 8-40kW suitable for large houses Yes they do, hybrids up to 10kW, on-grid up to 55kW 3 phase.
January 22, 20224 yr Hi I know an old thread I want to build a 90kw system 3ph this is usually done using Victron Quattro's and a kak load of mppts and wiring. The Sunsynk 8.8 manual states max 3 per phase but Deye video says 5 per phase, I need 4per phase. Has anybody attempted this. The other way would be HV battery and inverter but there are no good brands on the inverter side yet. Freedom won do high voltage batteries
January 22, 20224 yr 10 minutes ago, coffeedogsjujitsu said: Hi I know an old thread I want to build a 90kw system 3ph this is usually done using Victron Quattro's and a kak load of mppts and wiring. The Sunsynk 8.8 manual states max 3 per phase but Deye video says 5 per phase, I need 4per phase. Has anybody attempted this. The other way would be HV battery and inverter but there are no good brands on the inverter side yet. Freedom won do high voltage batteries Have a look at Atess inverters. 100kw full Hybrid
January 22, 20224 yr 2 hours ago, coffeedogsjujitsu said: Hi I know an old thread I want to build a 90kw system 3ph this is usually done using Victron Quattro's and a kak load of mppts and wiring. The Sunsynk 8.8 manual states max 3 per phase but Deye video says 5 per phase, I need 4per phase. Has anybody attempted this. The other way would be HV battery and inverter but there are no good brands on the inverter side yet. Freedom won do high voltage batteries
January 22, 20224 yr 2 hours ago, Leshen said: Have a look at Atess inverters. 100kw full Hybrid I did thx and it seems like a great solution ,no reviews out on it though I see freedom won actually stock it and are compatible. Also a Chinese brand seems they are thinking ahead.
January 22, 20224 yr 33 minutes ago, Don said: Yes we must and there is Atess but I really can't find any reviews on that, so as long as the market is stuck at 48v we are stuck with expensive Victron AC/DC coupled for big systems.
January 23, 20224 yr 17 hours ago, coffeedogsjujitsu said: Yes we must and there is Atess but I really can't find any reviews on that, so as long as the market is stuck at 48v we are stuck with expensive Victron AC/DC coupled for big systems. This is simply not so. We should not be stuck around residential units. Synsynk makes a 12kw 3 phase unit and you can add up to 16 in parallel. Yes it is still running at 48V. As per the OP perhaps the grid tied 100kw 3 phase Solis can be used during the day and then switch the batteries charged via another inverter or may be the clever guys can indicate if batteries cannot be used in the place of panels via the MPPTs. My idea would be just to add a current limiter of say 10A per input. The Solis has 10 x MPPTs. Edited January 23, 20224 yr by Scorp007
January 23, 20224 yr Goodwe has a few high capacity inverters as well, might be worth your while contacting them.
