June 2, 201610 yr Was also looking into this. These were the best I could find http://www.takealot.com/sunbeam-1-litre-cordless-kettle-stainless-steel/PLID38389115?utm_source=pricecheck&utm_medium=referral&utm_campaign=PriceCheck http://www.binuns.co.za/sunbeam-1-5-litre-thermal-flask-kettle.html?utm_source=pricecheck&utm_medium=referral&utm_campaign=PriceCheck
June 2, 201610 yr Author Thanks Viper for the links. For some reason I am not able/allowed to post more than one line
June 3, 201610 yr That thermal flask kettle looks like it could work well. Currently I boil kettles on the gas stove, but my solar system could handle 1350W without a problem.
June 3, 201610 yr Author I don't have a problem with 2200w kettle but only after 10am. Between 8-10 when is time for the second coffee my system can't handle and we don't have a gas stove
June 3, 201610 yr Yeah and the idea of a flask means it might still be warm enough. Please let me know if some tests it out how good it actually is. I currently swap over to Eskom when I want to boil it, don't like hitting my bank like that (current kettle uses 2300w)
June 10, 201610 yr Has anyone looked at the Bennett Read flask type kettles? The one I Had some years ago was a 750watt heating element and was basically a 2 liter pump Flask - like the ones you see at functions push button on top Which forces air in and water out spout. Got it at makro there were two capacity units back then. Not sure of still on the market?
June 10, 201610 yr Looks like they have a slightly newer version on bid or buy ? http://m.bidorbuy.co.za/item/140862528/Bennett_Read_4_8_L_Smart_Flask_Stainless_Steel_Flask.html
June 11, 201610 yr Can also try a 12v kettle (150w) 450ml so two cups of coffee/tea. Been using a setup 2x 80watt PV's , 100Ah Batt add plus with 12v car USB charger phones/tables are also charged
June 13, 201610 yr Author I want to thank to all of you who were willing to help me with advices. This is what I bought:http://www.takealot.com/prima-1-3-litre-porcelain-electic-kettle/PLID38389118 I'm happy with the performance of the 1.2KW kettle. Thanks again
June 13, 201610 yr Author 3-4 minutes for two cups. Basically double the time of the old 2.2KW kettle
June 13, 201610 yr 9 minutes ago, ibiza said: 3-4 minutes for two cups. Basically double the time of the old 2.2KW kettle Now get yourself a good quality flask boil it at 3-4PM and enjoy your free coffee at night
July 1, 201610 yr On 6/13/2016 at 8:05 PM, viper_za said: Now get yourself a good quality flask boil it at 3-4PM and enjoy your free coffee at night such as?
July 1, 201610 yr 3 hours ago, SilverNodashi said: such as? I would say Stanley Vacuum flasks are some of the best but real expensive, but even the el cheepos hold's it hot enough for 4-6 hours to drink coffee
July 1, 201610 yr 27 minutes ago, viper_za said: I would say Stanley Vacuum flasks are some of the best but real expensive, but even the el cheepos hold's it hot enough for 4-6 hours to drink coffee interesting. So when the panels don't have enough energy at about 16:30, the water will still be warm by about 8PM. That's two or three free cups of coffe! I wonder if I can convince the missus to use it? Which one do you use?
July 2, 201610 yr 11 hours ago, SilverNodashi said: Which one do you use? I'm using a cheap non Stainless steel one. (Think it was like R150) and this does the job for 4-6 hours. Secret is adding a little hot water first to let the inner chamber heat up first then add the boiling water after. These flask are claimed to to keep hot or cold for 24hours.http://www.thermosflasks.co.za/thermos-store/thermos-flasks/2lt-stainless-king-flask-detail If I can get only 12hours that's free morning coffee too, but the price
July 31, 201610 yr Late response - But I wanted to make sure I was accurate: I bought a Sunbeam 1.35Kw Kettle from Binuns for around R360, including delivery. It is a Stainless Steel, with a basic thermal "semi-vacuum" outer. It keeps water at decent heat for at least an hour after boiling and the lower wattage has had no difference to the people using it (4min vs 8min). It takes longer to boil because it is not a 2+ Kw kettle that you find on all shelves at most stores... My Batteries would have a heart attack every time kettle used to be turned on, just because of high draw, so this saved me. As an aside: Simple rule (applies to geysers as well) +- 2seconds/KiloWatt/Degree... Best thing I ever learned - Applies to almost every heating element.
August 1, 201610 yr 12 minutes ago, viper_za said: convenience Jip, that makes a whole lot of sense till your batts die on you and you need to replace them as per Kleva's post on the other thread.
August 1, 201610 yr I seem to remember Kleva having part of his bank replaced, maybe the other batts were also damaged
August 2, 201610 yr It's the same story as when wife turns on hairdryer while invertor on, nobody other than me checks or gives a damn. But a smaller element running for a longer time has less of a damaging effect on the batteries (remember the difference in your C5 C10 C20 rates?). Still need decent batteries though, but budget is now completely shot - bought a microlight to continue my flying (so all money going there for the moment).
August 20, 20169 yr On 6/3/2016 at 10:57 AM, ibiza said: I don't have a problem with 2200w kettle but only after 10am. Between 8-10 when is time for the second coffee my system can't handle and we don't have a gas stove Perhaps you can use the 2.2Kw kettle now?
