Degert Posted January 12, 2021 Share Posted January 12, 2021 Hi, I am new to world of renewables. I have an 8kW Deye inverter (installed 6 January), with 18 x 330W panels (being installed today) and a US3000 battery. With the panels being installed a week after the inverter, it has given me a chance to monitor our power consumption from the grid for a week. The problem is that the inverter states that we've used 318kWh in the past 6 days, while the municipal meter has only read 181kWh. I would understand a small difference, but surely something is wrong with the inverter's readings? Quote Link to comment Share on other sites More sharing options...
PaulinNorthcliff Posted January 13, 2021 Share Posted January 13, 2021 I would imagine that your inverter is measuring the power going into it, AND the power going out of it. Do you have the clamp meter attached correctly? Quote Link to comment Share on other sites More sharing options...
PaulinNorthcliff Posted January 13, 2021 Share Posted January 13, 2021 39 minutes ago, PaulinNorthcliff said: I would imagine that your inverter is measuring the power going into it, AND the power going out of it. Do you have the clamp meter attached correctly? I had this happen on my (previous) Goodwe inverter when I went offgrid. Quote Link to comment Share on other sites More sharing options...
Degert Posted January 13, 2021 Author Share Posted January 13, 2021 1 hour ago, PaulinNorthcliff said: I would imagine that your inverter is measuring the power going into it, AND the power going out of it. Do you have the clamp meter attached correctly? I don't think that's the problem. See pic below, the clamp is only around the live wire coming in from the grid. I asked the installer, but I don't agree with his view that the inverter needs to "build a memory" before the readings will be accurate. With the panels now online, I will post the readings again on Sunday (municipal + generation should be close to consumption + losses)... Quote Link to comment Share on other sites More sharing options...
PaulinNorthcliff Posted January 13, 2021 Share Posted January 13, 2021 Good luck. Quote Link to comment Share on other sites More sharing options...
FixAMess Posted January 13, 2021 Share Posted January 13, 2021 Its not only about the correct wire placement but is the clamp facing the correct direction, or is that not an issue with Sunsync? Quote Link to comment Share on other sites More sharing options...
Achmat Posted January 13, 2021 Share Posted January 13, 2021 2 minutes ago, FixAMess said: Its not only about the correct wire placement but is the clamp facing the correct direction, or is that not an issue with Sunsync? The clamp must be in the right direction for the sunsynk as well. I don't have this issue with my 8kw sunsynk inverter. Quote Link to comment Share on other sites More sharing options...
Degert Posted January 13, 2021 Author Share Posted January 13, 2021 Thanks, I will change it and let you know. FYI, for the past 24 hours, the consumption at the meter was 23kWh, while the inverter shows it should have been 50.9kWh (total consumption less generated kWh). Quote Link to comment Share on other sites More sharing options...
FixAMess Posted January 13, 2021 Share Posted January 13, 2021 If I'm not mistaken there is a way to tell if its facing the correct direction described in the user manual, readings must be +ve or -ve (Cant remember). Do you have the manual? Quote Link to comment Share on other sites More sharing options...
Degert Posted January 13, 2021 Author Share Posted January 13, 2021 Thanks all. It was actually plain to see (once I removed the clamp. The clamp has an arrow indicating the direction in which energy should flow. However, the installer probably found that the clamp was difficult to install the correct way around, so he just took the easy way out. I've managed to get the clamp out, but I'm struggling to install it again. I am sure that was the problem, but will give feedback later. Thanks a lot! Gareth_ZA 1 Quote Link to comment Share on other sites More sharing options...
Achmat Posted January 13, 2021 Share Posted January 13, 2021 (edited) 1 hour ago, Degert said: Thanks all. It was actually plain to see (once I removed the clamp. The clamp has an arrow indicating the direction in which energy should flow. However, the installer probably found that the clamp was difficult to install the correct way around, so he just took the easy way out. I've managed to get the clamp out, but I'm struggling to install it again. I am sure that was the problem, but will give feedback later. Thanks a lot! You can actually also just swap the wires from the clamp on the inverter instead of turning the clamp around. Edited January 13, 2021 by Achmat YellowTapemeasure 1 Quote Link to comment Share on other sites More sharing options...
PaulinNorthcliff Posted January 13, 2021 Share Posted January 13, 2021 1 hour ago, Degert said: Thanks all. It was actually plain to see (once I removed the clamp. The clamp has an arrow indicating the direction in which energy should flow. However, the installer probably found that the clamp was difficult to install the correct way around, so he just took the easy way out. I've managed to get the clamp out, but I'm struggling to install it again. I am sure that was the problem, but will give feedback later. Thanks a lot! See my earlier comment about "attached correctly"... Glad you got sorted. Quote Link to comment Share on other sites More sharing options...
Degert Posted January 13, 2021 Author Share Posted January 13, 2021 (edited) Thanks PaulinNorthcliff and everyone else. I've now changed the clamp, but a different problem popped up. I am now generating 27W of power (impossible), consuming 0W, and exporting 1.1kW to the grid (so it's showing -1.1kW). My grid feedback is blocked (as set by installer, zero export to CT), and I've checked that the wheel/meter is not turning backwards. It was stationary and at times moving forward. I assume that the direction WAS in fact correct, and I now need to change it back? Edited January 13, 2021 by Degert Quote Link to comment Share on other sites More sharing options...
Achmat Posted January 13, 2021 Share Posted January 13, 2021 It seems to be the wrong way around now as the value should only be negative if you are feeding back. Not familiar with the Deye user interface but there should be a screen that shows the reading from the CT on the inverter itself. I had an issue with my sunsynk and there seems to be two different sets of connection points on the inverter to connect the CT coil. I had it on the first connection and it had to change it to the second one. This is from the 8kw sunsynk. I initially had it on CT L1 and had to move it to CT L2. Quote Link to comment Share on other sites More sharing options...
Degert Posted January 13, 2021 Author Share Posted January 13, 2021 Thanks Achmat. I've changed the clamp back around, and checked that it is on CT-L2. So I am back where I began. I will monitor and post the results on Sunday. Here is what I have now: Quote Link to comment Share on other sites More sharing options...
Peter Topp Posted January 13, 2021 Share Posted January 13, 2021 Hi I have had similar problems as my manual in the box for a 8kw was wrong with confirmation from Sunsynk. You can download the correct installation manual from the Sunsynk web sight if it shows connection on (3 an4) CT1 which is wrong. The correct connection is on (5 and 6) CT2. You also do not have to change the ct around you will only have to swop the wires in the inverter on 5 and 6. Your photo shows a wrong connection on (3 and 5) I am sure this will sort out your problem. Quote Link to comment Share on other sites More sharing options...
Degert Posted January 13, 2021 Author Share Posted January 13, 2021 19 minutes ago, Peter Topp said: Hi I have had similar problems as my manual in the box for a 8kw was wrong with confirmation from Sunsynk. You can download the correct installation manual from the Sunsynk web sight if it shows connection on (3 an4) CT1 which is wrong. The correct connection is on (5 and 6) CT2. You also do not have to change the ct around you will only have to swop the wires in the inverter on 5 and 6. Your photo shows a wrong connection on (3 and 5) I am sure this will sort out your problem. Hi Peter. That picture was from Achmat, showing how he solved his issue. My wires were correct from the get-go (on CT2), as you can see below. But who knows, maybe the gremlins will disappear after playing around with the clamp... Quote Link to comment Share on other sites More sharing options...
Peter Topp Posted January 13, 2021 Share Posted January 13, 2021 (edited) Hi Degert Sorry looking at the picture wrong. The connection is correct. I must change my specs. Edited January 13, 2021 by Peter Topp Quote Link to comment Share on other sites More sharing options...
Achmat Posted January 14, 2021 Share Posted January 14, 2021 17 hours ago, Degert said: Thanks Achmat. I've changed the clamp back around, and checked that it is on CT-L2. So I am back where I began. I will monitor and post the results on Sunday. Here is what I have now: You can also check with Deye if you are on the latest software. YellowTapemeasure 1 Quote Link to comment Share on other sites More sharing options...
R Cerva Posted January 14, 2021 Share Posted January 14, 2021 Hi Achmat. I'm battling to get wifi setup going to connect the app. Always say something of the carractors in the password. Had % sign in password. So removed that so its only DFG1234 now. Just example but still does not want to connect to my wifi. How do you get upgrade software. Have 2 x 8kva in parallel but with diffirent version firmware. Quote Link to comment Share on other sites More sharing options...
Degert Posted January 14, 2021 Author Share Posted January 14, 2021 21 minutes ago, Achmat said: You can also check with Deye if you are on the latest software. I've sent them a mail thanks. Quote Link to comment Share on other sites More sharing options...
Achmat Posted January 14, 2021 Share Posted January 14, 2021 1 minute ago, R Cerva said: Hi Achmat. I'm battling to get wifi setup going to connect the app. Always say something of the carractors in the password. Had % sign in password. So removed that so its only DFG1234 now. Just example but still does not want to connect to my wifi. How do you get upgrade software. Have 2 x 8kva in parallel but with diffirent version firmware. Do you have the Deye or Sunsynk inverter? I also had issues connecting the dongle to my home wifi network. Had to first remove any special characters in the password for my home network and the dongle only connects to 2.4GHz wifi networks. You can only request a software upgrade from their support and the wifi dongle must be connected. You will need to give them the dongle and inverter serial numbers. Quote Link to comment Share on other sites More sharing options...
R Cerva Posted January 14, 2021 Share Posted January 14, 2021 10 hours ago, Achmat said: Do you have the Deye or Sunsynk inverter? I also had issues connecting the dongle to my home wifi network. Had to first remove any special characters in the password for my home network and the dongle only connects to 2.4GHz wifi networks. You can only request a software upgrade from their support and the wifi dongle must be connected. You will need to give them the dongle and inverter serial numbers. Hi. Have the Deye model nr. SUN-8K-SG01LP1-EU. 2 Units in parallel. Maybe you can help me out as well. I connected a generator to my system and want to use it only to charge the batteries. Maybe you can pick up my topic under invertors i think. Quote Link to comment Share on other sites More sharing options...
Degert Posted January 15, 2021 Author Share Posted January 15, 2021 So after 1 day's proper measurements (not fiddling with the clamp), this is what I got: Municipal energy used (meter readings): 16.2kWh Energy purchased according to inverter: 39.3kWh Energy generated + municipal energy: 34.7kWh Total consumption energy according to inverter: 56.1kWh Perhaps someone else could do the same exercise to compare? I am still waiting for Deye to respond about my firmware version. Quote Link to comment Share on other sites More sharing options...
PaulinNorthcliff Posted January 15, 2021 Share Posted January 15, 2021 (edited) 17 minutes ago, Degert said: I am still waiting for Deye to respond about my firmware version. Shabir +27 (082) 504-4510. Located in Johannesburg is the Deye Technical Support in SA. He came out to my property and updated firmware for me in December. I believe my firmware is ver 3874, if that sounds correct. Edited January 15, 2021 by PaulinNorthcliff Quote Link to comment Share on other sites More sharing options...
