February 25, 20215 yr Greetings I have 12 x 325w panels running into 2x Growatt SPF-5000ES inverters. Currently panels are in two strings one on top row and other on bottom row of 6. There are walls on both sides of roof casting shade on the left in the morning and on the right in the afternoons. Should they rather be split as a circular string on the left and and circular string on the right instead so one string is in sun longer in morning and they switch in the afternoon. Picks may illustrate better.
February 25, 20215 yr Author Thank you for the feedback. Didn't realise how much shade there is being created by those walls and the other roofs are east or west facing and have trees to contend with.
February 25, 20215 yr Author That is interesting. My next issue is enough battery capacity to benefit for such generating capacity I guess. Have two Shoto SDA10-48100L5 but still getting power often from the grid... not charging early or late enough is part of the factor too I think. For house and cottage, capacity may not be quite enough.
February 27, 20215 yr The only other option that I can think of are optimizers. They allow the panels to work independently so the shaded ones don't affect the rest. I think this is the best case for optimizers I've ever seen. Edited February 27, 20215 yr by Buyeye
February 28, 20215 yr On 2021/02/25 at 2:59 PM, TDH said: Didn't realise how much shade there is being created by those walls and the other roofs are east or west facing and have trees to contend with. Just my hummble opinion if i were you,i would build a structure on the wall (from wall to wall) and lay my panels flat In other words raise them Edited February 28, 20215 yr by Quwatush Shams (Suly)
March 1, 20215 yr 18 hours ago, Quwatush Shams (Suly) said: Just my hummble opinion if i were you,i would build a structure on the wall (from wall to wall) and lay my panels flat In other words raise them Actually a very good Idea since he would get to use all his panels not just the ones not in shade. opimizers look likehttps://www.geewiz.co.za/inverters/105896-solaredge-p500-optimiser-500w-mc4-96-cell.html?sfdr_ptcid=2961_617_545101417&sfdr_hash=872bec3df5269b1627ea97711fb694fe&gclid=Cj0KCQiAvvKBBhCXARIsACTePW8jYbqZo9XPP0RwHMw2y_rREEXfdpSbl5Qe5v0oVC5s7hhX4fIHirwaAjihEALw_wcB this but you need to check compatibility with your inverter. If you can build a structure to raise them out of the shade that would be better.
March 2, 20215 yr Author On 2021/03/01 at 9:52 PM, YellowTapemeasure said: Knock down those walls and build a braai/pizza oven with those bricks... 😉😄 Suggestions to close the bedroom and dinning room roofs supported by those walls 😀 budget won't allow for more panels to do the job.
March 4, 20215 yr On 2021/02/25 at 2:59 PM, TDH said: Thank you for the feedback. Didn't realise how much shade there is being created by those walls and the other roofs are east or west facing and have trees to contend with. I have 6 facing north and 6 facing east. So you could do something like that. That would allow you to have 2 x 3 north facing cluster that might escape the shadows you refer to. You will get a different PV delivery curve. I start getting PV quite early in the morning, so peak would not be midday. However the east facing panels do provide useful power until at least 14:00.
April 9, 20215 yr Author Just an update. While I still want to do east and west panels, in the meantime time the strings were changed to left and right and on a clear day it seems I can generate 3-5kw additional (subject to consumption as well) than the configuration of top and bottom strings.
