June 2021 Product Price List
https://powerforum-store.co.za/collections/batterys/products/hubble-lithium-s-100-12-8v-1-2kwh
The S-100 is a 1C 100Ah lithium battery designed to be a drop in replacement for existing Lead Acid or Gel batteries.
The S-100 has a integrated BMS inside the battery container, which also contain the prismatic lithium cells.
The S-100 can be connected up to 4 times in series maximum. You can configure the batteries in 12V, 24V, 36V or 48V in series.
It is important to note that there are two versions of this battery:
•    The older Hubble S-100 (with serial # prefixes starting with DS) can be configured in series or parallel, but not  both simultaneously. This means that one or more older Hubble S100s can be configured:
o    Series: 1, 2, 3 or 4 batteries; OR
o    Parallel: Up to 15 batteries only in 12V configuration.
•    The newer Hubble S-100 batteries (with serial # prefixes starting with HL) can be configured up to 4 batteries in series with 4 batteries in parallel.
o    This means that a bank of 16 batteries can be configured at 48V, with a maximum discharge and charge rate of 400A and 200A respectively
12.8V  1.2KWh
Rating: 1C
Maximum continuous discharge: 100Amp
Cells: 2nd life prismatic LiFePO4
Communication: None
CAN Bus: No
RIOT Cloudlink Ready: No
hubble_lithium_s-100_a4_pamphet_v2.2.pdf
