Why do batteries explode?
By the looks of the cable, a lot of heat were present. Wrong and too high of a charge, short circuit??
I don't like Osaka batteries. Heard too many bad stories and there were/are fakes/copies floating around. (China copy from a copy from a copy..)
Edited by DavidB
3 hours ago, Scubadude said:
Saw this today ... Townhouse in Gordons Bay severely damaged by a gel battery explosion. What would cause this?
Could be excessive heat 🤔
A colleague of mine's car battery exploded on the way to work many years ago (a Ford XR3, to date the story). All that remained were some bits of plastic clamped to the end of the battery leads.  Also a lot of battery acid all over the engine and underneath the bonnet.
He had a new battery fitted and all was fine, so it must have been a short circuit inside the battery itself.
guessing would be battery's placed right next to next other with little to no spacing, 1 develops a bad cell, short circuits, heat builds up fast, transfers said heat to the surrounding (were good ?) battery's, cascade effect, possibly in a room with no ventilation, add a spark and a boom.
I had a 200ah sla with a bad cell, the heat coming off it was actually quite substantial, dangerous in fact.
  • Moderator2 changed the title to Why do batteries explode?
