Hubble or Pylontech on Axpert 4kW Clone?
Hubble Lithium AM-2 51V 100Ah.                                                 R 24,917.05
Pylon UP5000-GCS 4.8kWh Li-Ion Solar Battery 48V.       R 23,300.00
So, another year has passed and I still haven't bought a new battery. Found these two batteries on the Powerstore.
Some might know my setup due to previous post, but here goes....
MKS4048 Axpert clone. (Yip, the bloody thing still works, and actually works well)
6*400w Canadian solar panels
4*100ah lieng long agm batteries (just about to explode under any load)
My base load is about 500w (100w when fridge/freezer cycles)
While geyser on, 1600w (10:00 - 14:00) (18:00 - 19:00) (04:00- 05:30)
Which battery will be better with my setup? My aim is to at least use it between 04:00 to 05:30 to run the geyser.
I've added a few pics. Node Red and a Pi3 running solpiplog. I can program it to turn the fridge/freezer off in the morning while the geyser is on.
20220514_110832.thumb.jpg.ebcfb608fbd146d7ce5b6c978d1c7959.jpgScreenshot_2022-05-14_11-13-04.png.0d450209bfd2d69d8da62c1ff536327f.png
Edited by Warlok
Added picture
5 hours ago, Nexuss said:
Pylon UP5000 for sure ! Especially since your consumption level is staying below 2,4kw.
Thanks, I am leaning towards the UP5000, since maybe I can use pylonlog to connect to the battery.
Anybody else using solpiplog and pylonlog on a Pylon?pylonlog.png.ff5c01b197fc2694eadf2360fcf64f6b.pngpylonlog2.png.280a64aad14df3ae8734b41cb47aa8a7.png
5 hours ago, BritishRacingGreen said:
👍👍 Mine too !!
Sorry , not quite on topic , but I like that grafana dash .
Thank you. Actually that's Node Red pulling the MQTT values from a raspberry pi3 connected via usb to the inverter.
This is how most of the flow looks like.
node1.thumb.png.10f8dc2ae6209f099f2568718228c9f1.pngnode2.thumb.png.4324e65160e2b5653e4578e9e57b76d5.pngnode3.thumb.png.c209e4fef82f6e49703dbdc4a08b1d4d.png
Hoping to read the true SOC from the battery for better control for the battery.
Anybody out there know how to connect the Pylon to the Raspberry PI?
I always wonder how beneficial that is . I am probably spoiled by the way the Sunsynk treats the batteries (like royalty lol) . I have monitored a bit via batteryview and all the cells were balanced perfectly and they cycle between 3,1-3,5 volts.  I have been cycling my batteries 95% DOD every day for almost a year. 7Kwh pack has done a bit more than 2.1Mwh discharge in the last year and its still on 100% SOH.
As reported by many people, the Axpert clone does not treat batteries well. Looks like it only reads voltage and not true SOC. I've seen a video with a Pylon connected to a Pi with a special cable running ICC software.
Maybe I'm too worried. But can I connect the batteries without comms and set the Axpert to "USE" in the menu and set it to 52.2 volts?
ahhh i see honestly i have no experience outside of the Sunsynk , i had lead acid on my Axpert. There is probably lots of benefits to that kind of battery control if you dont have comms with the inverter.
More confusion........
Why the price difference of R609.00 between these 2 batteries? One is GCS and the other not.
Specs look the same.
If you are in Middleburg, these guys are closer to you and they also have delivery option
https://www.inverter-warehouse.co.za/products/pylontech-lithium-ion-4-8kw-up5000-battery
5 minutes ago, Nexuss said:
Not sure about that website , hellopeter reviews are not kind . Rather shop from a more reputable seller like the Powerforum store
https://powerforum-store.co.za/collections/featured-products/products/pylon-up5000-4-8kwh-li-ion-solar-battery-48v
Both are available on the Powerforum store, but I see GC Solar has a website and the one on the Powerforum store is branded UP5000_GCS
Funny......
shipping.png.351d3a6c12341fa67762e0d2ae88178c.pngYip, I'm in Middelburg.
I still have 15 days before purchasing. I will support the company that gives me the best deal.
Been saving for over a year now, so this is hard earned cash.
You need to send them an email and request a quotation for shipping. Also, be aware of scammers when looking for best deals, don't give away your money
Thanks, already checked. My courier company asks R250.00 to pick up from that location.
Scammers are the scum of the earth. I'd like to meet one face to face.
But, it looks like at last I will be getting the battery, even if I have to drive to the supplier.
This forum has helped me and others so much. Very much appreciated.
