Home Assistant Sunsynk Power Flow Card and Dashboard
Updates
  • Card can now be installed via HACS
  • Card configuration attributes have been updated and entities moved to own section.
  • Automatic card resize when show_solar: no and cardstyle: lite
  • Changes to svg path elements and layout
See updates on the the first post.
  • Replies 592
  • Views 130.6k
  • thank you @slipx, I've been using the power flow card for a while now but didn't know about the animations. now thanks your examples I've implemented the animations. I use a generator on my AUX port
  • I've made  a small update to the Dashboard. The load shedding card shows remaining time based on battery SOC and battery power. You will need to create some template sensors as discussed here and prov
  • Here's a slight contribution to the goodness on this thread which lives on my main HA screen: type: custom:bar-card entities: - entity: sensor.load_shedding_area_eskde_4_sandownext10cityofj
3 hours ago, slipx said:
Updates
Brilliant. I am busy building a solar monitoring "bootstrap" for home assistant and I am definitely including this card.
My idea is to setup a basic system and then make a HA Backup.
The idea is to help new users to simply restore a backup that includes all the plugins and resources to get a fully functional monitoring desktop up and running, complete with graphs,charts, config screens etc.
After that people can modify and tweak the contents to work for them.
More Updates
  • Add panel_mode attribute: yes/no. Removes any card height restrictions for better card scaling. For use with Panel(1 card) view types or grid layouts.
  • Update grid_status_194 attribute. Now accepts 1/0 or `on/off`
Example of panel_mode: yes and grid card
How do you install it from HACS? I searched on Hacs and I do not find it. I have a manual install but would like to switch to HACS so I can do upgrades in the future without manually copying and changing everything
I'm still waiting for it to be added to the store. For now you can add it as a custom repository, under Frontend. Click the 3 dots on the right and select custom repositories. Add the github link and the category is lovelace.
New release v1.1.0
  • Change the inverter image to create a more unified look and feel.
  • Reposition some of the path elements
  • Add inverter_colour: attribute to the card config. Customise the look of your card by choosing your own inverter colour.
New Version 1.1.3
Updates
  • Improve text displayed when batteries are charging
  • Merge pull request 14. Refactor inverter state logic. Thanks @Sparkz0629
  • Merge pull request 12. Add card configuration example to README. Thanks @Sparkz0629
New Release v1.2.0
NOTE: This release changes the card configuration. Please see the README
Updates:
  • Choose between two inverter images (modern or Sunsynk)
  • Colour options for all card objects
  • Supports inverted battery power i.e. -discharge, +charge
New Release v1.2.1
NOTE: The card configuration has changed from release v1.2.0. Please see the README
Updates:
  • Daily totals can now be toggled independently.
  • Option to hide "AUX" from the full card
  • Realign PV data to avoid overlap
  • Daily load is displayed on the full card if "AUX" is hidden and the load show_daily attribute is set to yes
  • Add more verbose inverter status message i.e Normal, Fault etc
New Release v1.2.2
Updates:
  • Grid Connected /Grid Disconnected status now displayed with separate icons ( "mdi-powerline" / "mdi-powerline-off")
  • Grid Disconnected dot removed and instead the "grid disconnected" icon colour can be configured through the card config to match your colour scheme
Edited by slipx
New Release
This release contains breaking changes. See the README for additional required card attributes
v1.3.0 Updates
  • Display up to four mppts through new solar configuration attribute mppts (one, two, three, four).
  • Add option to hide non-essential from full card and reposition daily grid when enabled.
  • The simple card has been removed. This view can be created using the full card and setting show_aux: no and show_nonessential: no.
  • Add option to invert AUX power. Set to yes if your sensor provides a positive number for AUX input and negative number for AUX output.
Please note card configuration changes for this release. Refer to the README
v1.3.3 Updates
  • New card options for grid - show_daily_buy: 'yes' and show_daily_sell: 'yes'. These replace the old show_daily attribute
  • New sensor entity added - grid_sell_day_77
  • Daily Grid Sell Total displayed on the card
  • Ability to toggle on/off "Daily Grid Buy" and "Daily Grid Sell" independently
v1.3.5 - NOTE: This update renames the ess_power: to essential_power and introduces a new nonessential_power attribute. Please update your card configuration
Updates
Internal calculations for essential and non-essential power will be ignored if sensors are specified e.g. Solar Assistant provides sensors for these two attributes. Setting the attribute values to none will use the internal card logic to calculate.
v1.4.1
Updates
  • Improve AUX flow
  • Nearly all card entities are clickable if associated with a valid Home Assistant entityID
Hi,
Thanks for this amazing card.
I have very limited HA experience and I'm using the sensors for my Sunsynk in HA pulled from the e-linter dongle using Gary Waterworth's integration.
I use the export to essential load feature, but I cannot find the right sensor or attribute that will help me calculate the inverter_load_grid_169 entity. Is this not possible with the wifi data logger, or is there some way to get that info from the inverter via the logger?
thanks again!
Edited by HardeHout
Hi.
Best would be to ask Gary in this thread. I don't know if its exposed through his integration. Here is the extract from the documentation for the description of that modbus register.
167
L1
Grid side L1 power
R
1W
int Signed int
168
L2
Grid side L2 power
R
1W
int Signed int
169
L1L2
Total power of grid side L1L2
R
1W
int 00
Signed int
> 0 BUY
< 0 SELL
v1.4.3
Update - Please note the breaking change, show_solar has been moved to the root config.
  • Optimizes the card configuration and includes smarter attribute error checking.
  • README updated to show required/optional attributes and their default values.
  • Card configuration examples have been updated
v1.4.4
Updates
  • Adds sensor for battery current
  • Adjustments to battery layout to accommodate battery current
Edited by slipx
v1.4.6
Add new card option large_font: to increase the size of the displayed sensor data. Default is no. Set to yes to enable. See README and example card config for more information
hello, i wonder if this will work with the solarman integration for Deye inverters. can anyone tell me if it can be configured to use the solarman entities to  be the sensors for this energy card?
would anyone be willing to help me remotely set this up on my HA with the solarman entities? im not so good with coding and making changes like this. so im willing to pay for such service :)
thanks for any help or info.
Yes it does work with Solarman. Have a look at the github WIKI. There are some videos to help guide you with installing the card. You need to create two template sensors and you can also use the card config below. Also have a look here
sensors:
  sunsynkcard_gridstatus:
    friendly_name: Gridstatus
    value_template: |
      {% if is_state('sensor.solarman_grid_connected_status', 'On-Grid') %}
        1
      {% else %}
        0
      {% endif %}
  sunsynkcard_inverterstatus:
    friendly_name: InverterStatus
    value_template: |
      {% if is_state('sensor.solarman_running_status', 'Stand-by') %}
        0
      {% elif is_state('sensor.solarman_running_status', 'Self-Checking') %}
        1
      {% elif is_state('sensor.solarman_running_status', 'Normal') %}
        2
      {% elif is_state('sensor.solarman_running_status', 'Fault') %}
        4
      {% endif %}
and here is the card config
type: custom:sunsynk-power-flow-card
cardstyle: lite
panel_mode: 'no'
show_solar: 'yes'
battery:
  energy: 15960
  shutdown_soc: 20
  show_daily: 'yes'
solar:
  show_daily: 'yes'
  mppts: two
load:
  show_daily: 'yes'
  show_aux: 'no'
grid:
entities:
  batchargeday_70: sensor.solarman_daily_battery_charge
  batdischargeday_71: sensor.solarman_daily_battery_discharge
  loadday_84: sensor.solarman_daily_load_consumption
  grid_buy_day_76: sensor.solarman_daily_energy_bought
  grid_sell_day_77: sensor.solarman_daily_energy_sold
  solarday_108: sensor.solarman_daily_production
  inverter_grid_voltage_154: sensor.solarman_grid_voltage_l1
  inverter_load_freq_192: sensor.solarman_load_frequency
  inverter_out_164: sensor.solarman_current_l1
  inverter_out_175: sensor.solarman_total_power
  inverter_load_grid_169: sensor.solarman_total_load_power
  pv1_power_186: sensor.solarman_pv1_power
  pv2_power_187: sensor.solarman_pv2_power
  pv3_power_188: none
  pv4_power_189: none
  battery_voltage_183: sensor.solarman_battery_voltage
  battery_soc_184: sensor.solarman_battery_soc
  battery_out_190: sensor.solarman_battery_power
  essential_power: sensor.solarman_total_load_power
  battery_current_191: sensor.solarman_battery_current
  grid_external_power_172: sensor.solarman_total_grid_power
  pv1_v_109: sensor.solarman_pv1_voltage
  pv1_i_110: sensor.solarman_pv1_current
  pv2_v_111: sensor.solarman_pv2_voltage
  pv2_i_112: sensor.solarman_pv2_current
  pv3_v_113: none
  pv3_i_114: none
  pv4_v_115: none
  pv4_i_116: none
  grid_status_194: sensor.sunsynkcard_gridstatus
  inverter_status_59: sensor.solarman_running_status
  aux_power_166: sensor.aux_output_power
Edited by slipx
