August 6, 20188 yr Good morning . I have a automotive inline amp meter . +60 to -60 amp . Will I be able to use it on 105 volt 16 amps . Thanks
August 6, 20188 yr Hi Chris. I think responses are slow because of a lack of information. What type of meter are you referring to, some might, and others not.
August 6, 20188 yr Author Hi Riaah thanks for the response , it is one the ampmeters used in cars to check battery charging dash mount . Busy cleaning at garage removing stuff that can't be used any more .
August 6, 20188 yr So I assume one of those old round Dial type meters, It should work as it only has 2 connection pins and basically uses a shunt for Amps. No 12V light for illumination to be used, and the accuracy on those things are debatable at best, but just for indication of current direction it should be good.
August 6, 20188 yr Author Used this one a lot on the older cars to setting the generator voltage regulators . Was good enough for that no digital meters those days . My hobby before solar . I was not sure if it could handle the 100 volt . Thanks
August 6, 20188 yr Generally the rule is not to use automotive stuff for >30V applications. But that's usually for stuff like switches and fuses, where higher voltages means larger arcs. For an ampere meter that obviously doesn't apply. So the short answer is that I don't know, but I probably wouldn't do it.
August 6, 20188 yr Tend to agree with @Riaanh & @plonkster, the Voltage is probably not relevant since it is a current meter for DC (ie: no induction, just a shunt). From your description it sounds like it doesn't have a illumination/globe. Just bear in mind that it will most likely be quite inaccurate down the low end of the current range, so can only really be a basic guide. But I am curious about what you have that is 105 Volts DC? I wouldn't try use this on the PV side though, the internal resistance is unknown so if a MPPT controller is involved then it could play havoc with it's logic. Battery side only. Does it not have any writing on it, or a picture? Edited August 6, 20188 yr by KLEVA
August 6, 20188 yr Author KLEVA my multimeter is good for only 10 amp . My 18 panels is combined on the roof in groups of 6 panels ( 3 x 2 ) .There is a combiner box in the ceiling where the 3 strings is combined with the surge arrestors next to the trap door . It would be nice for me to compere the incoming amps of the different groups of panels ( age difference of 3 years between 1st and last panels ) . Thanks if it does not work I will buy another .
August 7, 20188 yr 9 hours ago, KLEVA said: Voltage is probably not relevant At some point it becomes relevant. That point where it is high enough to jump from point A to point B, or more specifically, in a fault condition where things are already getting a bit heated or maybe even a bit wet and the clearances just aren't enough. With switches and fuses this is critical. With a meter it is probably not so critical. I am inclined to think that you'll probably be fine though.
August 7, 20188 yr UNI-T make a multi-meter with a CT clamp for DC Amps. My has mysteriously grown legs but I think its model number is 204.
August 7, 20188 yr Author Thanks will try and get one . U convinced me , just remember if my production cost keep going up I stand to lose my one and only client .
