Battery Questions
I am told the balancer is about R1,287.19 ex VAT.
EDIT: If there is still stock, they said.
  • Replies 136
  • Views 31.5k
  • I'd love to attend an auction of stuff at customs that's been there for 10 years and can't be delivered anymore. Must be some really cool stuff there.
  • Hi ebrsa I think the terms got a bit mixed up somewhere in the chinglish. The HA02 is not technically an equalizer, but rather a balancer and by keeping the batteries balanced you might need to p
  • My assumption would be yes, doubt those small cables could carry any form of reasonable load.
9 minutes ago, The Terrible Triplett said:
I am pretty sure if Victron says one is fine, it is fine.
It is not a cheap product - so they would be very careful not to mislead you.
Having said that, IF you do find a problem, email them direct, and they will assist. :D
What if your two banks are not balanced at different points then the one will get?
Thanks Jaco
No idea ... when I do need a balancer, I am going to investigate the Victron. Ja ja ja, there are cheaper devices but I would like help when I need it.
Like my post on the controller's screw threads that got damaged, just go a new unit under warranty today.
EDIT: Most suppliers would have told me that it is my problem, I overtightened the screws. Said a LOT about Victron when they just swapped it out, for I was preparing for a repair bill, having to wait months.
And you can get them locally 😆
If there is still stock, jip.
In an existing bank that has parallels, eg 4x12v for a 24v bank I would use 2, and keep midpoints seperate, no question. In a new bank you could get away with one. Point being you cannot tie midpoints together now that you buy a ballancer. The imbalance already exists in some way if it's been used a while. A ballancer is a prevention not a cure. These victron ones can sink one amp max, thats only 12-14w. The principal is it compares voltage on the upper and lower batteries and in a charge(usually absorb) if one shows higher voltage it will start to apply a load across the higher one to slow down its charge. I've got some teardown pics somewhere I'll see if I can find them
Sent from my SM-A500FU using Tapatalk
1. If you look at the back of the HA02 it shows 2.4V minimum (not 1.2V on previous post).
2. Glad didn't recommend supplier, they just (after a week) came back with a cancelled order (no-stock).
Now i am confuse, do i need 2 for a 4 batteries in a 24 volt system ?
How many banks do you have Manie?
Update your signature then it's easier to know ;)
Is it 4 x 6v batteries that make up one 24v bank?
Edited by viper_za
Do you know if these HA ballancers only do their thing during a charge? I couldn't see anything on that, its an important distinction. But the wider input range is nice for non 12v configurations
4 hours ago, Weasel said:
Manie, I would recommend 2 if the batteries are old. If they are new you can tie the midpoints together and use one.
I have 4 x 12 volt batteries (24v System)
Anyone know off the top of their heads what the max equalization current is for Victron balancer?
And HA balancers?
And HA balancers?
HA02 = 0-10A
I have one and I am very happy...
Better HA's and Victron the improve their devices to also cater for 6v Trojans ... or else ...
23 minutes ago, Mark said:
HA02 = 0-10A
Where did you buy yours Mark ?
From China with Edmund... shared the postage... see my PVOutput to see the MidP voltages... I seldom get more than 0.2% difference and then the HA02 balances the bank quickly...
Thanks Mark
I cannot tell you just how responsive this company is, and how willing to help. If you're a professional/developer/builder who want to integrate their stuff into a new product, they absolutely go out of their way to help. Sometimes I wonder if Matthijs ever sleeps :-)
I'm somewhat in the middle of a new adventure here, so more about that later :-)
And HA balancers?
The HA02 can do 6V and the HA01 0-5A.
TTT is starting to take a Mandarin language course. First its the Voltronics inverters and now the Chinese battery balancers. Looks like its is going to be Chinese take-away when I visit in Sept :lol:
Chicken Noodles ... and it will be running dog flavor just because.  :D:D (lekker gril julle nou ne!)
Seriously, Chris, 4 x 6v batts, I will need one HA02?
