March 18, 20206 yr Hi Guys I'm tired of load shedding and would like to 'keep the lights on'. I know very little about this so I am looking for advice. I'm looking at the Mecer axperts but I am confused despite reading many of the posts on this topic. I feel like I have the following options in my price range: 1. Axpert mks ii 5k 2. Axpert mks 5k 3. Axpert King 5k I want to start of with a 4.4 LIPO4 battery and then expand in the future with solar panels. Please can someone advise me on the above options. Thanks
March 18, 20206 yr Axpert King IMO with 2 x 3.5 Pylontechs to start with I've used them all and King works the best IMO Edited March 18, 20206 yr by Quat Allah As Shams
March 19, 20206 yr Author Thanks appreciate the quick response. What are the advantages of the King over the MKS?
March 19, 20206 yr Blending of Solar,Batteries and Grid Where are you based ? Edited March 19, 20206 yr by Quat Allah As Shams
March 19, 20206 yr Than you might want to look at NRS approved inverter http://resource.capetown.gov.za/documentcentre/Documents/Forms, notices, tariffs and lists/Approved Photovoltaic (PV) Inverter List.pdf
March 19, 20206 yr Disadvantage of King is you can't run multiple units in parallel, so if you buy 5kW then that is your max with no option to upgrade. If you run the MKS II then you can parallel lots of them, but you don't have solar and grid blending as mentioned. What does that mean exactly? When solar + battery isn't enough to power your loads then the grid will fully power the load while the solar charges the battery. Another scenario is let's say you run geysers in the middle of the day and during that time you want to augment solar with grid instead of battery to put less strain on battery: can't do that with MKS II.
March 19, 20206 yr Author @Quat Allah As Shams Thanks. I'm not keen on grid tie at the moment. The cost is just too high and not viable. @pierre. Interesting point. 5kw will be my max but the benefit of the blending seems more attractive as long as I am satisfied with 5kw. Appreciate the advice guys. Do any of you have experience with any of the following online stores? sustainable-energy-solutions.co.za, solaradvice.co.za, thepowerstore.co.za, enway.co.za, bonanzatech.co.za, mhn.co.za, gwstore.co.za
March 20, 20206 yr 8 hours ago, pierre. said: King is you can't run multiple units in parallel Not true see manual below of kodak king as an example https://cdn.shopify.com/s/files/1/1776/7837/files/OG_Plus_Installation_Manual.pdf?1075 @pierre.Please check facts before posting or advising Edited March 20, 20206 yr by Quat Allah As Shams
March 20, 20206 yr Same machine from same factory only different as far I as know Edited March 20, 20206 yr by Quat Allah As Shams
March 20, 20206 yr Dealt with Bonanzatech, owner Alberto quite pleasant to deal with. I bought a VM iii, it also has the SUB function, which is supposed to blend, have not hooked mine up yet, so cannot confirm, but a lot of discussion on the forum
March 21, 20206 yr On 2020/03/20 at 5:33 AM, Quat Allah As Shams said: Not true see manual below of kodak king as an example https://cdn.shopify.com/s/files/1/1776/7837/files/OG_Plus_Installation_Manual.pdf?1075 @pierre.Please check facts before posting or advising Just checked and saw it's the VMIII that doesn't have parallel operation. My bad.
March 21, 20206 yr Looking at the King manual I guess one disadvantage of King is a solar voltage is 60VDC~115VDC while MKS II is 120VDC~430VDC. So with the king you will wire more panels in parallel.
August 24, 20206 yr I just installed my system with MKS 5K, 9 330 W Canadian panels and 9.6 kWh battery. It works well so far and is very versatile. It's advantage is that it can operate with a remote control panel. I'm still in the tuning phase but I think I got it. It can be used with solar panels or just as a powerful UPS. Just a matter of programming it but very easy. The advantage of the higher solar panel voltage is to keep the current low. I arranged 3 banks of 3 panels in series each. That makes a max voltage of 112 V and a max total current of 26.6 A. That can be handled with 6 mm² wire.
August 25, 20205 yr For those still following this and new comers... The above statement of the Kings not being able to run in parallel is incorrect and they definitely can (not only the Kodak units version). The newer builds also come with the parallel cards pre fitted. The main advantage of the King is a zero millisecond transfer time which is great for sensitive equipment (CCTV, Servers, Networking equipment, etc) As mentioned above, the dis-advantage over the MKS is the PV voltage which results in running fewer panels in series but more in parallel
September 1, 20205 yr On 2020/03/19 at 10:54 AM, Quwatush Shams (Suly) said: Blending of Solar,Batteries and Grid Many say the axperts can't as they are not real hybrid inverters. I couldn't find any specs or infos in the manual nor manufacturer contact information to ask. Where can I confirm that information for the Axpert King inverters? I am using it for load shedding and want to expand with solar.
September 1, 20205 yr 18 minutes ago, capkasa said: Where can I confirm that information for the Axpert King inverters? I am using it for load shedding and want to expand with solar. The Kings certainly can - I run 3 of them. It is a double-conversion device, which means all incoming power (PV and grid) get converted to DC, and all loads are powered from that DC (and the battery) via the inverter. Some people get confused about the difference between grid-tied and hybrid - the King is hybrid but not grid tied.
September 1, 20205 yr On 2020/03/21 at 11:20 PM, pierre. said: Looking at the King manual I guess one disadvantage of King is a solar voltage is 60VDC~115VDC while MKS II is 120VDC~430VDC. So with the king you will wire more panels in parallel. So it needs more strings in a combiner I guess?
September 2, 20205 yr 5 hours ago, capkasa said: So it needs more strings in a combiner I guess? Yes and I run one as well
September 2, 20205 yr The Axpert VM III can blend solar and utility and has a solar array max voltage of 450 v
