November 21, 2025Nov 21 this is the problem, i already try intall to many firmwaresOne firmware give-me error 50other firmware start OK , after give-me error 62 for 4 seconds and give-me OKOther firmware aparently working, but if i shutdown AC and start AC again, the Breaker AC shutdown whem the inverter start AC
November 21, 2025Nov 21 the only firmware workin is tis: Infini10KW20150701But the fan start too late and temperatura is too high 60º or more with 1% load
November 21, 2025Nov 21 Ok, FW is very old and includes almost all bugs... :-)A fw upgrade is in fact not really risky, as long as you have fw upgrade files for your previous version. You can always flash another fw over the running firmware, even it does not work with your device or is older.Your inverter is obviously a non-parallel infini 10k. Latest fw I got for this series is from 2019-05-09:Infini10KW-nonP-FSP20190509PThis one includes BMS support,etc.So you can give it a shot with this one, if you are not happy, just flash old FW back:Infini10KW20150701-nonPar.rarEvery upgrade on your own risk - off course!!!PS: Keep in mind to remove card from options slot for the upgrade, read the manual for the upgrade (pdf) and always flash both: master and slave firmware! Edited November 21, 2025Nov 21 by riogrande75
November 21, 2025Nov 21 hello againwith this: Infini10KW-nonP-FSP20190509P, inverter shutdown breaker AC electric differential on the dashboard when it's in hybrid mode II and in 100% battery mode, and I turn on the AC power..with this is working Infini10KW20150701-nonPar.rar, but problem is the fans!do you have one more? Edited November 21, 2025Nov 21 by Josearaujo10
November 22, 2025Nov 22 I tried to collect almost all fw upgrade files for 10k infini's but do not have many for the very old non-parallel models.All I can offer ist this:Infini10kW_20160412.zipInfini10KW20160810P-nonPar.rarI know of a 2018-11-06 firmware, that performed perfectly over many years in a infini 10k in my basement. Unfortunately I don't have the upgrade files for this one.
November 22, 2025Nov 22 Finaly my inverter is workingupdate Infini10KW-nonP-FSP20190509P is ok, problem is circuit breaker is class AC 30ma and is not compatible with 3phase inverterThank you for all
June 5Jun 5 On 2023/01/15 at 1:01 PM, riogrande75 said:As I know the source of you inverter now 🤨, I hardly recommend to check the serial# of the clone with solarpower before any flash procedures.Maybe it is safe to install fw from 2020/04/02 (this is the one I am not aware of any bugs). Actually I've installed this version on all of the 10k's that I'm aware of.Only some new brand new devices from 2022 run later FW, but all of them have issues.i have this same verion installed but issue is that inverter did not start charging with grid and if ON the grid feed then its stop charging from solar also and the setting we keep the battery fist then load and then grid feed
June 5Jun 5 If you post your serial and vendor or even better, a photo of your device's serial sticker, I might be able to send you a link with the latest firmware available for it. Then you should be good.
June 23Jun 23 Hello All,My inverter is InfiniSolar 10K-PAR-B, SN 96162011100284, Protocol 17. Is Infini10KWParallelA20200402DP the correct firmware for my inverter?
23 hours ago23 hr Dear All,Which exactly firmware should I use to upgrade the model below ?Model: InfiniSolar 10K-PAR-BSN: 96162011100284Protocol: 17QMD: 000,010000,99,3,3,2300,2300,04,120VFW: 00001.01VFW2: 00001.01BMS support currently not working.Thank you in advance!Tom
12 hours ago12 hr One note: If you don't face any troubles or you miss any new feature, no upgrade is neccessary.Here links to some firmware files, that should work. If a installed fw makes troubles, just start the fw upgrade process again with another/older firmware.Latest: MPI10K_2025-08-22Older: Infini 10k 2023-11-14Old but good working: Infini10KWParallelB20200204PPS: Keep in mind to temp. remove any options card for the upgrade!!!
