Infini 10kw 3 phase Firmware Upgrade
this is the problem, i already try intall to many firmwares
One firmware give-me error 50
other firmware start OK , after give-me error 62 for 4 seconds and give-me OK
Other firmware aparently working, but if i shutdown AC and start AC again, the Breaker AC shutdown whem the inverter start AC
  • Replies 193
  • Views 21.1k
  • riogrande75
    riogrande75
    The password of fw files from the czech site is "daily". But be warned: Not every FW for the 10k infini works on all models!!! You have to choose the right one based on your serial# which in
  • riogrande75
    riogrande75
    Yes, thats ok - don't worry. From what I know of: First there was a "NON-Parallel" version starting in 2015. Latest fw I'm aware of is from 2018. Then 2016/09 they came up with a 10k v
  • riogrande75
    riogrande75
    What inverter do you have exactly (pic of type/serial would be helpful) and what fw version does it run currently?
Ok, FW is very old and includes almost all bugs... :-)
A fw upgrade is in fact not really risky, as long as you have fw upgrade files for your previous version. You can always flash another fw over the running firmware, even it does not work with your device or is older.
Your inverter is obviously a non-parallel infini 10k. Latest fw I got for this series is from 2019-05-09:
Infini10KW-nonP-FSP20190509P
This one includes BMS support,etc.
So you can give it a shot with this one, if you are not happy, just flash old FW back:
Infini10KW20150701-nonPar.rar
Every upgrade on your own risk - off course!!!
PS: Keep in mind to remove card from options slot for the upgrade, read the manual for the upgrade (pdf) and always flash both: master and slave firmware!
Edited by riogrande75
I tried to collect almost all fw upgrade files for 10k infini's but do not have many for the very old non-parallel models.
All I can offer ist this:
Infini10kW_20160412.zip
Infini10KW20160810P-nonPar.rar
I know of a 2018-11-06 firmware, that performed perfectly over many years in a infini 10k in my basement. Unfortunately I don't have the upgrade files for this one.
  • 6 months later...
On 2023/01/15 at 1:01 PM, riogrande75 said:
As I know the source of you inverter now 🤨, I hardly recommend to check the serial# of the clone with solarpower before any flash procedures.
Maybe it is safe to install fw from 2020/04/02 (this is the one I am not aware of any bugs). Actually I've installed this version on all of the 10k's that I'm aware of.
Only some new brand new devices from 2022 run later FW, but all of them have issues.
i have this same verion installed but issue is that inverter did not start charging with grid and if ON the grid feed then its stop charging from solar also and the setting we keep the battery fist then load and then grid feed
If you post your serial and vendor or even better, a photo of your device's serial sticker, I might be able to send you a link with the latest firmware available for it. Then you should be good.
Dear All,
Which exactly firmware should I use to upgrade the model below ?
Model: InfiniSolar 10K-PAR-B
SN: 96162011100284
Protocol: 17
QMD: 000,010000,99,3,3,2300,2300,04,120
VFW: 00001.01
VFW2: 00001.01
BMS support currently not working.
Thank you in advance!
Tom
One note: If you don't face any troubles or you miss any new feature, no upgrade is neccessary.
Here links to some firmware files, that should work. If a installed fw makes troubles, just start the fw upgrade process again with another/older firmware.
Latest: MPI10K_2025-08-22
Older: Infini 10k 2023-11-14
Old but good working: Infini10KWParallelB20200204P
PS: Keep in mind to temp. remove any options card for the upgrade!!!
