For Sale: 48V 120AH 6.1KWH LIFEPO4 WALL MOUNT SOLAR UPS BATTERY (2ND LIFE)
I am selling off my battery, its time for an upgrade.
This ine is still basically new and has the following usage specifications: Running off a Victron Multi 2 5000 with BMV and MPPT
Deepest discharge   -112.50 Ah (Was testing it conservatively.)
Last discharge         -75.20 Ah
Average discharge   -75.70 Ah
Charge cycles           56.00
Full discharges          0.00
Bought from Lithium Batteries South Africa in May. Consists of 16 cells, 120Ah BMS, DC circuit breaker, wall mountable box.
R20000  (Yes this is the best bang for buck lithium battery out there by far!)
Same price as 4 x 200Ah Lead Acid but with loads more capacity.
Not even a comment?
This is an excellent battery with double the capacity of the other brands for the price.
Edited by Jaaks
I suppose what you have to take into account is that 16 LiFePO4 cells from the same source will cost R14,400 and an ANT BMS will add R2500 for a total of R16,900. At least that is what I would consider if I wanted to buy such equipment. The breaker and meter are nice to have but would already be present in an existing installation. Besides the ANT BMS provides much more useful information than the Daly BMS in your system. Hope this helps you.
OK, so you want the cost breakdown?
16 x R900 = R14400
Circuit breaker R460
BMS R2000
Connectors R450
Wires R300
Specially designed wall mount enclosure R800
Lugs, heatshrink, sundries R250
Few hours to ensure all is built correctly and works. R???
Total R 18 660 + labor, also had to drive around to all the shops to buy all the extras so add fuel to that. I added it in my head so may be out a bit. Included is the remainder of the warranty too.
The source sells them for R22 200 if you can get stock.
Any decent offers and we can start negotiating?
If anyone can build me a battery like this with ANT BMS for R16900 I will seriously want to buy two of them!!!!
Edited by Jaaks
I think people would rather buy a 3.5kW pylontechs for R20K, comes with a 10 yr warranty, works seamlessly with some inverters..
2nd Hand batteries are still new to the market with no documented history that allows one to feel confident in the purchase...
What are you upgrading to?
I want a bit more capacity so looking at larger cells. I am almost off grid with this one but must add some more panels and another kW or so in batteries. I am looking into getting 16 x 200Ah cells.
Hi Jaaks
If you want more capacity, why not just double up on the cells and make a 16s2p battery? You can use the same BMS if your load hasn't changed. And you would need a larger enclosure, if needed. Seems the best bang for buck option?
Ian
Possible yes, but I have a lead on some 200Ah cells and just need the cash.
Thanks the the ideas though
Decided that is is working too well and an upgrade going to cost too much. So holding on to it, Unless I get a good offer maybe?
Pm me for details
  • 3 months later...
Anyone interested in this item?
Highly negotiable and price drop available.
Contact me with an offer.
