December 21, 20205 yr Hey guys, I was looking at inverter through solarman and noticed my leak current value was 102ma. What sort of number are you guys getting here?
December 23, 20205 yr On 2020/12/21 at 10:27 PM, excitedphoton said: Hey guys, I was looking at inverter through solarman and noticed my leak current value was 102ma. What sort of number are you guys getting here? I'm getting zero leak current.
December 25, 20205 yr Author Thanks for all the responses. I think I should look look for the source of this problem.
June 29, 20215 yr 1 hour ago, TeddyBear said: Sorry to bring up this thread again. Has anyone solved this issue? I don't even see this option on the app anymore so not sure where you are seeing it now.
June 30, 20215 yr 15 hours ago, Achmat said: I don't even see this option on the app anymore so not sure where you are seeing it now. Currently on the solarman pro web portal in the "other" dropdown
June 30, 20215 yr 1 hour ago, TeddyBear said: Currently on the solarman pro web portal in the "other" dropdown Thanks. Mine is still showing 0.00mA.
