@sjlouw I allways use 32's the older 8266's wifi stack on esphome was allways touch and go. I ended up removing R7 as well as two other resistive sensors I had on the 32. Its now perfectly stable.
Thanks for the effort.
This is by far the best option of getting the data in HomeAssistant on sunsynk inverters!
  • Replies 657
  • Views 183k
@sjlouw I am doing something wrong and I can't figure out what cause I can't get my ESP32 to work!
I have tried 2 different boards and two different RS485 connectors (same models as you specified) but no joy
Have tried different ethernet cables etc, I am using a T568B cable so using the orange/orange&white cables (pin 1&2)
These are the errors I am getting, any idea?
Settings on the inverter are as specified.
Also trying to get this working for my Sunsynk 8kw. I have the MicroRobotics 4-pin USB-RS485 dongle, have connected pins 1,2,3 from the T568B cable (orange/white, orange, green/white) to B, A, Ground.
My inverter is set to Slave, ID 1.
I am trying to use mbusd as described in kellerza's sunsynk repo
mbusd -d -L - -v 9 -p /dev/ttyUSB0  -s 9600 -m 8N1 -P 502 -T 5
And then `pymodbus.console` to connect to mbusd to do a basic sanity test. Unfortunately, I just get timeouts.
As an alternative, I'm wondering if I could replace the firmware on the Sunsynk Wifi dongle (ESP32, talking RS232 to the inverter) with ESPHome, and query the inverter via that router? Anyone tried this?
The only suggestion I have is to ensure the SunSynk Modbus ID is correct:
Mine was zero, which did not seem to work.
mine is started as:
mbusd -v 2 -c /etc/mbusd/mbusd.conf
and mbusd.conf contains:
########## Serial port settings #############
# Serial port device name
device = /dev/ttyUSB0
# Serial port speed
speed = 9600
# Serial port mode
mode = 8n1
# RS-485 data direction control type (addc, rts, sysfs_0, sysfs_1)
trx_control = addc
# Sysfs file to use to control data direction
# trx_sysfile =
############# TCP port settings #############
# TCP server address to bind
address = 192.168.1.6
# TCP server port number
port = 502
# Maximum number of simultaneous TCP connections
maxconn = 32
# Connection timeout value in seconds
timeout = 60
######### Request/response settings #########
# Maximum number of request retries
retries = 3
# Pause between requests in milliseconds
pause = 100
# Response wait time in milliseconds
wait = 500
# Reply on Broadcast
replyonbroadcast = no
6 minutes ago, Kalahari Meerkat said:
mine is started as:
Thanks!
I'm just trying to get a minimal response back from the inverter, to show that I am correctly connected to it. From there, I'm happy to try and install all sorts of programs, etc. Is there a simple "ping" that should get an answer?
I tried:
printf  "client.connect\nclient.read_device_information\n" | pymodbus.console tcp --host 192.168.201.1 --port 502
But I just get a timeout. And I have confirmed that my slave id is set to 01.
Is there a simple "liveness" check that I can do to confirm that I am able to talk to my inverter?
On 2022/09/14 at 2:28 PM, Sc00bs said:
@sjlouw @Sc00bs
Scoobs, did you ever get this to work?
im using a esp32 devkit 1, and then the same rs485 to ttl convertor sjlouw used.
Tried with a deye 12kw 3 phase and also no comms.
I saw from sjlouws diagram that Green of white is pin 1 connecting to A and Green is pin 2 connecting to B, but from the deye manual, it looks like Pin one on Rs485 is B and pin2 is A.
Still didnt work for me though, bunch of crc errors..
Edited by roadkill
wrong name
Same problem on a new install. I wonder if something changed with latest firmware.
EDIT. Think I might be using the wrong port. I was trying using the one on the bottom right, not top left
Edited by slipx
update
@sjlouw
Thank you for the esphome code! I have modified it somewhat and below is my current code if anyone is interested:
esphome:
esp32:
  board: esp32dev
  framework:
    type: arduino
#################################### STATIC SECTION ####################################
wifi:
  ssid: !secret wifi_ssid
  password: !secret wifi_password
  fast_connect: true
  ap:
    ssid: '${device_name}'
    password: !secret fallback_password
ota:
  safe_mode: true
  reboot_timeout: 10min
  num_attempts: 5
#web_server:
#  port: 80
#  auth:
#    username: !secret esphome_web_username
#    password: !secret esphome_web_password
#switch:
#  - platform: restart
#    name: "${device_name} Restart"
captive_portal:
esp32_ble_tracker:
  scan_parameters:
    active: true
bluetooth_proxy:
  active: true
# Enable logging
logger:
# Enable Home Assistant API
api:
  password: !secret esphome_api_password
# Enable time component to reset energy at midnight
# https://esphome.io/components/time.html#home-assistant-time-source
time:
  - platform: homeassistant
uart:
 tx_pin: 17
 rx_pin: 16
 baud_rate: 9600
 stop_bits: 1
modbus:
 flow_control_pin: 4
modbus_controller:
 - id: sunsynk_esphome
   address: 0x01
   modbus_id: sunsynk_modbus
   setup_priority: -10
   update_interval: 5000ms
sensor:
 - platform: modbus_controller          #72 Battery Charge Total
   modbus_controller_id: sunsynk_esphome
   name: "SS Battery Charge Total"
   register_type: holding
   address: 72
   unit_of_measurement: "kWh"
   accuracy_decimals: 1
   device_class: energy
   state_class: total_increasing
   filters:
    - lambda: |-
           x = x / -1;
           float MAX_VALUE = 32767;
           if (x > MAX_VALUE) return (0 - x + 65535) /10;
           else return (0 - x) /10;
 - platform: modbus_controller          #74 Battery Discharge Total
   name: "SS Battery Discharge Total"
   address: 74
   accuracy_decimals: 0
   filters:
    - lambda: |-
           x = x / 1;
           if (x > MAX_VALUE) return (0 - 65535) /10;
           else return (x) /10;
# - platform: modbus_controller          # 81 Grid Export Total (Sell)
#   modbus_controller_id: sunsynk_esphome
#   name: "SS Grid Export Total (Sell)"
#   id: sunsynk_esphome_grid_export_total_sell
#   register_type: holding
#   address: 81
#   unit_of_measurement: "kWh"
#   accuracy_decimals: 2
#   device_class: energy
#   state_class: total_increasing
#   filters:
#    - lambda: |-
#           x = x / 1;
#           float MAX_VALUE = 32767;
#           if (x > MAX_VALUE) return (0 - 65535) / 10;
#           else return x /10;
 - platform: modbus_controller          # 78 Grid Import Total (Buy)
   name: "SS Grid Import Total (Buy)"
   address: 78
   filters: #GOOD
    - lambda: |-
           x = x / -1;
           if (x > MAX_VALUE) return (0 - x + 65535) /1;
           else return (0 - x) /1;
 - platform: modbus_controller          # 85 Load Power Total
   name: "SS Load Power Total"
   address: 85
   filters: #GOOD
    - lambda: |-
           x = x / 1;
#   name: "SS Total PV Power (kWh)"
#   id: sunsynk_esphome_total_pv_power_kwh
#   address: 96
#   filters:
#     - multiply: 0.1
 - platform: modbus_controller          # 169 Grid Power
   name: "SS Grid Power"
   address: 169
   unit_of_measurement: "W"
   device_class: power
   state_class: measurement
   filters: #GOOD
    - lambda: |-
           x = x /1;
           if (x > MAX_VALUE) return (0 - 65535) /1;
           else return (x) /1;
 - platform: modbus_controller          # 178 Load Power
   name: "SS Load Power"
   address: 178
   device_class: power
   filters: #GOOD
    - lambda: |-
           x = x /1;
           else return (x) /1;
#   name: "SS PV1 Power"
#   id: sunsynk_esphome_pv1_power
#   address: 186
#   unit_of_measurement: "W"
#   device_class: power
#   state_class: measurement
#   name: "SS PV2 Power"
#   id: sunsynk_esphome_pv2_power
#   address: 187
 - platform: modbus_controller          # 184 Battery SOC
   name: "SS Battery SOC"
   address: 184
   unit_of_measurement: "%"
   device_class: battery
   filters: #GOOD
    - lambda: |-
           x = x /1;
           else return (x) /1;
 - platform: modbus_controller          # 216 Battery Charging Efficiency
   name: "SS Battery Charging Efficiency"
   address: 216
   filters: #GOOD
    - lambda: |-
           x = x /1;
 - platform: modbus_controller          # 194 Grid Connected Status
   name: "SS Grid Connected Status"
   address: 194
 - platform: modbus_controller          # 059 Overall State
   name: "SS Overall State"
   address: 59
 - platform: modbus_controller          # 013 Firmware Control Board
   name: "SS Firmware Control Board"
   address: 13
 - platform: modbus_controller          # 013 Firmware Comms Board
   name: "SS Firmware Comms Board"
   address: 14
 - platform: modbus_controller          # 079 Grid Frequency
   name: "SS Grid Frequency"
   address: 79
   unit_of_measurement: "hz"
   filters: #GOOD
    - lambda: |-
           x = x /1;
           if (x > MAX_VALUE) return (0 - 65535) /100;
           else return (x) /100;
   #device_class: none
 - platform: modbus_controller          # 154 Grid Inverter Voltage
   name: "SS Grid Inverter Voltage"
   address: 154
   unit_of_measurement: "V"
   filters: #GOOD
     - lambda: |-
           x = x / 1;
   device_class: voltage
 - platform: modbus_controller         # 150 Grid Voltage
   name: "SS Grid Voltage"
   address: 150
   filters: #GOOD
     - lambda: |-
           x = x / 1;
 - platform: modbus_controller          # 183 Battery Voltage
   name: "SS Battery Voltage"
   address: 183
   filters: #GOOD
     - lambda: |-
           x = x /1;
           if (x > MAX_VALUE) return (x - 65535) / 100;
           else return x / 100;
 - platform: modbus_controller          # 312 Battery Charge Voltage
   name: "SS Battery Charge Voltage"
   address: 312
   filters: #GOOD
     - lambda: |-
           x = x / -1;
           if (x > MAX_VALUE) return (0 - x + 65535) /100;
           else return (0 - x) /100;
 - platform: modbus_controller          # 167 Grid Inverter Load
   name: "SS Grid Inverter Load"
   address: 167
   filters: #GOOD
     - lambda: |-
           x = x / 1;
           else return (x) /1;
   device_class: power
 - platform: modbus_controller          # 191 Battery Output Current
   name: "SS Battery Output Current"
   address: 191
   unit_of_measurement: "A"
   device_class: current
   filters: #GOOD
    - lambda: |-
          x = x / 1;
 - platform: modbus_controller          # 182 Battery Temperature
   name: "SS Battery Temperature"
   address: 182
   unit_of_measurement: "°C"
   device_class: temperature
   filters: # GOOD
    - lambda: |-
           x = x /1;
           if (x > MAX_VALUE) return ((x - 65535)-1000) / 10;
           else return ((x)-1000) / 10;
#   name: "SS Environment Temp"
#   id: sunsynk_esphome_environment_temperature
#   address: 095
#   unit_of_measurement: "°C"
#   accuracy_decimals: 0
#   device_class: temperature
#   filters:
#     - multiply: 0.1
 - platform: modbus_controller          # 090 DC Transformer Temperature
   name: "SS DC Transformer Temperature"
   address: 090
   filters: # GOOD
    - lambda: |-
           x = x /1;
 - platform: modbus_controller          # 091 Radiator Temperature
   name: "SS DC Radiator Temperature"
   address: 091
   filters: # GOOD
    - lambda: |-
           x = x /1;
 - platform: modbus_controller          #076 Grid Import Day (Buy)
   name: "SS Grid Import Day (Buy)"
   address: 76
   filters: # GOOD
    - lambda: |-
           x = x / 1;
           else return x /10;
 - platform: modbus_controller          # 070 Battery Charge Day
   name: "SS Battery Charge Day"
   address: 70
   filters: #GOOD
    - lambda: |-
           x = x / 10;
           else return (x) /1;
 - platform: modbus_controller          # 071 Battery Discharge Day
   name: "SS Battery Discharge Day"
   address: 71
   filters: #GOOD
    - lambda: |-
           x = x / 10;
           else return (x) /1;
 - platform: modbus_controller          # 175 Inverter Output Power
   name: "SS Inverter Output Power"
   address: 175
   device_class: power
   filters: #GOOD
    - lambda: |-
           x = x /1;
           if (x > MAX_VALUE) return (0 - x + 65535) /-1;
           else return (0 - x) /-1;
I tried plugging into the top left RS485 port and get a bunch of CRC errors.  Everything is wired up as per the previous posts.
pin1 (orange/white) -->A
pin2 (orange) -->B
I also tried swapping A and B. Any ideas?
INFO Reading configuration /config/sunsynk.yaml...
WARNING GPIO4 is a Strapping PIN and should be avoided.
Attaching external pullup/down resistors to strapping pins can cause unexpected failures.
See https://esphome.io/guides/faq.html#why-am-i-getting-a-warning-about-strapping-pins
INFO Starting log output from sunsynk.local using esphome API
INFO Successfully connected to sunsynk.local
[13:56:57][I][app:102]: ESPHome version 2022.10.0 compiled on Oct 23 2022, 16:48:26
[13:56:57][C][wifi:502]: WiFi:
[13:56:57][C][wifi:360]:   Local MAC: EC:62:60:9C:2B:E0
[13:56:57][C][wifi:361]:   SSID: 'xxx'[redacted]
[13:56:57][C][wifi:362]:   IP Address: 10.0.0.35
[13:56:57][C][wifi:364]:   BSSID: 60:63:4C:AA:B5:CF[redacted]
[13:56:57][C][wifi:365]:   Hostname: 'sunsynk'
[13:56:57][C][wifi:367]:   Signal strength: -60 dB ▂▄▆█
[13:56:57][C][wifi:371]:   Channel: 3
[13:56:57][C][wifi:372]:   Subnet: 255.255.255.0
[13:56:57][C][wifi:373]:   Gateway: 10.0.0.2
[13:56:57][C][wifi:374]:   DNS1: 10.0.0.101
[13:56:57][C][wifi:375]:   DNS2: 1.1.1.1
[13:56:57][C][logger:275]: Logger:
[13:56:57][C][logger:276]:   Level: DEBUG
[13:56:57][C][logger:277]:   Log Baud Rate: 115200
[13:56:57][C][logger:278]:   Hardware UART: UART0
[13:56:57][C][uart.arduino_esp32:107]: UART Bus:
[13:56:57][C][uart.arduino_esp32:108]:   TX Pin: GPIO17
[13:56:57][C][uart.arduino_esp32:109]:   RX Pin: GPIO16
[13:56:57][C][uart.arduino_esp32:111]:   RX Buffer Size: 256
[13:56:57][C][uart.arduino_esp32:113]:   Baud Rate: 9600 baud
[13:56:57][C][uart.arduino_esp32:114]:   Data Bits: 8
[13:56:57][C][uart.arduino_esp32:115]:   Parity: NONE
[13:56:57][C][uart.arduino_esp32:116]:   Stop bits: 1
[13:56:57][C][modbus:139]: Modbus:
[13:56:57][C][modbus:140]:   Flow Control Pin: GPIO4
[13:56:57][C][modbus:141]:   Send Wait Time: 250 ms
[13:56:57][C][modbus_controller.sensor:010]: modbus_controller.sensorModbus Controller Sensor 'Total Battery Charge (kWh)'
[13:56:57][C][modbus_controller.sensor:010]: modbus_controller.sensor  Device Class: 'energy'
[13:56:57][C][modbus_controller.sensor:010]: modbus_controller.sensor  State Class: 'total_increasing'
[13:56:58][C][modbus_controller.sensor:010]: modbus_controller.sensor  Unit of Measurement: 'kWh'
[13:56:58][C][modbus_controller.sensor:010]: modbus_controller.sensor  Accuracy Decimals: 2
[13:56:58][W][modbus:105]: Modbus CRC Check failed! C071!=00
[13:56:58][W][modbus:105]: Modbus CRC Check failed! 944A!=08
[13:56:58][W][modbus:105]: Modbus CRC Check failed! C569!=8140
[13:56:58][W][modbus:105]: Modbus CRC Check failed! C081!=00
[13:56:58][W][modbus:105]: Modbus CRC Check failed! 401F!=00
[13:56:58][W][modbus:105]: Modbus CRC Check failed! C071!=1810
[13:56:58][W][modbus:105]: Modbus CRC Check failed! 385D!=00
[13:56:58][W][modbus:105]: Modbus CRC Check failed! 9C5!=2030
[13:56:58][W][modbus:105]: Modbus CRC Check failed! C7F1!=00
[13:56:58][W][modbus:105]: Modbus CRC Check failed! C071!=1808
[13:56:58][C][modbus_controller.sensor:010]: modbus_controller.sensorModbus Controller Sensor 'Total Battery Discharge (kWh)'
[13:56:58][C][modbus_controller.sensor:010]: modbus_controller.sensor  Device Class: 'energy'
[13:56:58][C][modbus_controller.sensor:010]: modbus_controller.sensor  State Class: 'total_increasing'
[13:56:58][W][modbus:105]: Modbus CRC Check failed! EA97!=00
[13:56:58][W][modbus:105]: Modbus CRC Check failed! C071!=800
[13:56:58][W][modbus:105]: Modbus CRC Check failed! C071!=A08
[13:56:58][W][modbus:105]: Modbus CRC Check failed! 57EE!=00
[13:56:58][W][modbus:105]: Modbus CRC Check failed! C071!=20
[13:56:58][C][modbus_controller.sensor:010]: modbus_controller.sensorModbus Controller Sensor 'Total Grid Export (kWh)'
[13:56:58][W][modbus:105]: Modbus CRC Check failed! 32!=00
[13:56:58][W][modbus:105]: Modbus CRC Check failed! 69E5!=00
[13:56:58][W][modbus:105]: Modbus CRC Check failed! 65FA!=00
[13:56:58][W][modbus:105]: Modbus CRC Check failed! 16BF!=00
[13:56:58][W][modbus:105]: Modbus CRC Check failed! F4F2!=00
[13:56:58][W][modbus:105]: Modbus CRC Check failed! C071!=2000
[13:56:58][W][modbus:105]: Modbus CRC Check failed! C071!=10
[13:56:58][C][modbus_controller.sensor:010]: modbus_controller.sensorModbus Controller Sensor 'Total Grid Import (kWh)'
[13:56:58][W][modbus:105]: Modbus CRC Check failed! 9DE1!=00
[13:56:58][W][modbus:105]: Modbus CRC Check failed! 76!=40C
[13:56:58][W][modbus:105]: Modbus CRC Check failed! A615!=00
[13:56:58][W][modbus:105]: Modbus CRC Check failed! 130!=00
[13:56:58][W][modbus:105]: Modbus CRC Check failed! C071!=1000
[13:56:58][W][modbus:105]: Modbus CRC Check failed! 77C1!=38
[13:56:58][W][modbus:105]: Modbus CRC Check failed! 76!=1840
[13:56:58][C][modbus_controller.sensor:010]: modbus_controller.sensorModbus Controller Sensor 'Total Load Power (kWh)'
[13:56:58][W][modbus:105]: Modbus CRC Check failed! E9EE!=800
Edited by slipx
3 hours ago, jacauc said:
@sjlouw
esphome:
esp32:
  board: esp32dev
  framework:
    type: arduino
wifi:
  fast_connect: true
  ap:
ota:
  safe_mode: true
  num_attempts: 5
#web_server:
#  port: 80
#  auth:
#switch:
captive_portal:
esp32_ble_tracker:
  scan_parameters:
    active: true
bluetooth_proxy:
  active: true
# Enable logging
logger:
api:
time:
uart:
 tx_pin: 17
 rx_pin: 16
 baud_rate: 9600
 stop_bits: 1
modbus:
 flow_control_pin: 4
modbus_controller:
   address: 0x01
   setup_priority: -10
sensor:
   address: 72
   filters:
    - lambda: |-
           x = x / -1;
   address: 74
   filters:
    - lambda: |-
           x = x / 1;
#   address: 81
#   filters:
#    - lambda: |-
#           x = x / 1;
   address: 78
   filters: #GOOD
    - lambda: |-
           x = x / -1;
   address: 85
   filters: #GOOD
    - lambda: |-
           x = x / 1;
#   address: 96
#   filters:
#     - multiply: 0.1
   address: 169
   device_class: power
   filters: #GOOD
    - lambda: |-
           x = x /1;
           else return (x) /1;
   address: 178
   device_class: power
   filters: #GOOD
    - lambda: |-
           x = x /1;
           else return (x) /1;
#   address: 186
#   address: 187
   address: 184
   filters: #GOOD
    - lambda: |-
           x = x /1;
           else return (x) /1;
   address: 216
   filters: #GOOD
    - lambda: |-
           x = x /1;
   address: 194
   address: 59
   address: 13
   address: 14
   address: 79
   filters: #GOOD
    - lambda: |-
           x = x /1;
   #device_class: none
   address: 154
   filters: #GOOD
     - lambda: |-
           x = x / 1;
   address: 150
   filters: #GOOD
     - lambda: |-
           x = x / 1;
   address: 183
   filters: #GOOD
     - lambda: |-
           x = x /1;
   address: 312
   filters: #GOOD
     - lambda: |-
           x = x / -1;
   address: 167
   filters: #GOOD
     - lambda: |-
           x = x / 1;
           else return (x) /1;
   device_class: power
   address: 191
   filters: #GOOD
    - lambda: |-
          x = x / 1;
   address: 182
   filters: # GOOD
    - lambda: |-
           x = x /1;
#   address: 095
#   filters:
#     - multiply: 0.1
   address: 090
   filters: # GOOD
    - lambda: |-
           x = x /1;
   address: 091
   filters: # GOOD
    - lambda: |-
           x = x /1;
   address: 76
   filters: # GOOD
    - lambda: |-
           x = x / 1;
           else return x /10;
   address: 70
   filters: #GOOD
    - lambda: |-
           x = x / 10;
           else return (x) /1;
   address: 71
   filters: #GOOD
    - lambda: |-
           x = x / 10;
           else return (x) /1;
   address: 175
   device_class: power
   filters: #GOOD
    - lambda: |-
           x = x /1;
Thanks for the code @jacauc
Which firmware is you inverter running?
Have asked for an update as it looks like my firmware is quite old.
Will see if that makes a difference with me being able to connect using the ESP32
I doubt. If it worked before with Raspberry there's no reason it won't work with ESP. The modbus protocol is pretty simple,so can't see why it won't work that way. I would suggest trying not bridging the middle two pins on that modbus converter @sjlouw used and trying each of them independently. I actually used my raspberry pi rs485 HAT and wired it into the ESP32
Edited by jacauc
Thanks @jacauc will play around with the pins and see if that works.
It is working without any issues on my Intel Nuc connecting using a USB-RS485 adapter and Bloubuls Node Red flows so what you are saying makes sense.
Only one RS485 port on the 8kw
I managed to get mine working. I had to remove the R7 resistor to increase the D.C. voltage across A/B. I also wired both 2 and 7 -- >A and 1 and 8 -->B
Thanks @slipx
Will give that a go as well
38 minutes ago, Sc00bs said:
Thanks @slipx
Yay, finally working, I think that removing R7 did the trick.
I have an 8kw so maybe they need the R7 to be removed to work on them for some strange reason
Do you have an 8Kw inverter @slipx @sjlouw
Wondering if the removal of the R7 resistor is specific to the 8kw as mine would not connect with the resistor in place but some people do not seem to have that issue, most (all maybe) seem to be on the 5kw inverter.
@jacauc Would be nice to be able to not waste querying cycles to the inverter on values which do not change as quickly e.g. the Daily totals and spend more cycles on the values such as PV Power etc.
I see in your example you aren't monitoring PV power.
Was thinking of putting together an example with all the Inverter values and people can just # out the ones they don't require
Do you think that we could write values back to the inverter using ESPhome as well?
