Martinisonline, I have been using use the ESPHome solution with the SunSynk 8.8kW inverter since about 10 Feb (just after my Inverter was installed), and updates are pretty immediate. Life graphs such as Inverter Power update every 2-3 s here - so I guess it is a function of when the inverter sends an update on the bus? Other data such as Battery SOC updates much slower, so I think it only sends it when the value changes?
In terms of setting write updates, it is normally also instantaneous here, but I sometimes observe  a slight lag (0,5s?), when I for example toggle the grid option for a time period, but it is not something one does so interactively that it bothers one.
I am surprised by the ESPHome device's performance (ESP32) - I have 81! entities defined on it, with absolutely no issue so far - it is running 24/7 unless I reboot/recompile to refine the ESPHome code. I had just done last night the very nice power flow that emulates the SunSynk screen -see attached screen, and had to add a few missing sensors that was not defined in the ESPHome setup.
  • Replies 657
  • Views 183.8k
Excellent. Like a lot the format style.
my Inverter is a Deye 5K and I'm using a solution based in a raspberry Pi with USB-RS-485 adapter and with a Solark Modbus HA integration. It is working for about 1 year flawless, with a refresh rate of about every 5 seconds.
Now I'm thinking to start to sell the surplus energy to the provider but want to do some automations to change some parameters automatically in the Inverter, specifically the battery charge rate according to time of the day and PV production.
The integration I have, doesn't have the "write" functionality, is read only.
I'm thinking to update the system and start to use this ESP32 approach to gain the "write" possibility. I have some ESP32 devices around and I did before some very simple projects with ESPHome. I've read the thread and the examples provided, but still is a bit confusing how the ESPHome intregration works and how it writes into the inverter registers.
Had a look on the version shared by Klatremis, but the registers are completely different from the Deye 5Kw equipment.
Can you share more details about your solution? ESPHome code...?
Thank you.
"My" ESPHome code, which is a combination of others work before me.
But I believe the Deye registers are completely different?
esphome:
preferences:
  flash_write_interval: 5min
esp32:
  board: esp32dev
  framework:
    type: arduino
#################################### GLOBALS ####################################
substitutions:
  modbus_update_interval: "3s"
  settings_skipped_updates: "10"
  query_throttle: "50ms"
  device_name: sunsynk
  friendly_name: SunSynk Link
#################################### STATIC SECTION ####################################
wifi:
  ssid: XXXX
  password: XXX
  fast_connect: true
ota:
  safe_mode: true
  reboot_timeout: 10min
  num_attempts: 5
web_server:
  port: 80
#captive_portal:
# Enable logging
#logger:
#  baud_rate: 0
# Enable Home Assistant API
api:
# https://esphome.io/components/time.html#home-assistant-time-source
time:
  - platform: homeassistant
uart:
 tx_pin: 17
 rx_pin: 16
 baud_rate: 9600
 stop_bits: 1
modbus:
 flow_control_pin: 4
modbus_controller:
 - id: sunsynk_esphome
   address: 0x01
   modbus_id: sunsynk_modbus
   setup_priority: -10
   update_interval: ${modbus_update_interval}
   command_throttle: ${query_throttle}
switch:
  - platform: restart
  - platform: modbus_controller      # 248 Toggle System Timer
    use_write_multiple: true
    modbus_controller_id: sunsynk_esphome
    name: "Toggle System Timer"
    register_type: holding
    address: 248
    bitmask: 1
    entity_category: config
    icon: "mdi:toggle-switch"
  - platform: modbus_controller          # 274 Toggle Grid Charge Timezone1
    name: "Toggle Grid Charge Timezone1"
    address: 274
    bitmask: 1
  - platform: modbus_controller          # 275 Toggle Grid Charge Timezone2
    name: "Toggle Grid Charge Timezone2"
    address: 275
    bitmask: 1
  - platform: modbus_controller          # 276 Toggle Grid Charge Timezone3
    name: "Toggle Grid Charge Timezone3"
    address: 276
    bitmask: 1
  - platform: modbus_controller          # 277 Toggle Grid Charge Timezone4
    name: "Toggle Grid Charge Timezone4"
    address: 277
    bitmask: 1
  - platform: modbus_controller          # 278 Toggle Grid Charge Timezone5
    name: "Toggle Grid Charge Timezone5"
    address: 278
    bitmask: 1
  - platform: modbus_controller          # 279 Toggle Grid Charge Timezone6
    name: "Toggle Grid Charge Timezone6"
    address: 279
    bitmask: 1
number:
  - platform: modbus_controller         # 268 Settings SoC Timezone1
    name: "Set SoC Timezone1"
    unit_of_measurement: "%"
    address: 268
    min_value: 0
    max_value: 100
    step: 5
    value_type: U_WORD
  - platform: modbus_controller         # 269 Settings SoC Timezone2
    name: "Set SoC Timezone2"
    address: 269
    min_value: 0
    max_value: 100
    step: 5
    value_type: U_WORD
  - platform: modbus_controller         # 270 Settings SoC Timezone3
    name: "Set SoC Timezone3"
    address: 270
    min_value: 0
    max_value: 100
    step: 5
    value_type: U_WORD
  - platform: modbus_controller         # 271 Settings SoC Timezone4
    name: "Set SoC Timezone4"
    address: 271
    min_value: 0
    max_value: 100
    step: 5
    value_type: U_WORD
  - platform: modbus_controller         # 272 Settings SoC Timezone5
    name: "Set SoC Timezone5"
    address: 272
    min_value: 0
    max_value: 100
    step: 5
    value_type: U_WORD
  - platform: modbus_controller         # 273 Settings SoC Timezone6
    name: "Set SoC Timezone6"
    address: 273
    min_value: 0
    max_value: 100
    step: 5
    value_type: U_WORD
sensor:
 - platform: wifi_signal
   name: WiFi signal ${device_name}
   internal: true
   update_interval: 60s
 - platform: template
   name: Wifi ${device_name}
   unit_of_measurement: '%'
   accuracy_decimals: 0
   icon: "mdi:wifi"
   lambda: |-
        if (id(wifi_s).state < -92.0)
          return 1.0;
        if (id(wifi_s).state > -21.0)
          return 100.0;
        else
          return round(( -0.0154 * id(wifi_s).state * id(wifi_s).state ) - ( 0.3794 * id(wifi_s).state ) + 98.182 );
 - platform: uptime
   filters:
      - lambda: return x / 3600;
   unit_of_measurement: hours
 - platform: modbus_controller          #72 Battery Charge Total
   name: "SS Battery Charge Total"
   address: 72
   unit_of_measurement: "kWh"
   accuracy_decimals: 1
   device_class: energy
   state_class: total_increasing
   filters:
    - lambda: |-
           x = x / -1;
           if (x > 32767) return (0 - x + 65535) /10;
           else return (0 - x) /10;
 - platform: modbus_controller          #74 Battery Discharge Total
   name: "SS Battery Discharge Total"
   address: 74
   filters:
    - lambda: |-
           if (x > 32767) return (x - 65535) /10;
           else return (x) /10;
 - platform: modbus_controller          # 81 Grid Export Total (Sell)
   name: "SS Grid Export Total (Sell)"
   address: 81
   accuracy_decimals: 2
   filters:
    - lambda: |-
           if (x > 32767) return (x - 65535) / 10;
           else return x /10;
 - platform: modbus_controller          # 78 Grid Import Total (Buy)
   name: "SS Grid Import Total (Buy)"
   address: 78
   filters: #GOOD
    - lambda: |-
           x = x / -1;
           if (x > 32767) return (0 - x + 65535) /1;
           else return (0 - x) /1;
 - platform: modbus_controller          # 85 Load Power Total
   name: "SS Load Power Total"
   address: 85
   filters: #GOOD
    - lambda: |-
   name: "SS Total PV Power (kWh)"
   address: 96
   filters:
     - multiply: 0.1
 - platform: modbus_controller          # 169 Grid Power
   name: "SS Grid Power"
   address: 169
   unit_of_measurement: "W"
   device_class: power
   state_class: measurement
   filters: #GOOD
    - lambda: |-
           if (x > 32767) return (x - 65535) /1;
           else return (x) /1;
 - platform: modbus_controller          # 178 Load Power
   name: "SS Load Power"
   address: 178
   device_class: power
   filters: #GOOD
    - lambda: |-
           else return (x) /1;
 - platform: modbus_controller       # 186 PV1 Power
   name: "SS PV1 Power"
   address: 186
   device_class: power
 - platform: modbus_controller       # 187 PV2 Power
   name: "SS PV2 Power"
   address: 187
   device_class: power
 - platform: template           # PV Total Power
   name: "SS PV Power"
   device_class: power
   update_interval: 15s
   lambda: |-
     return (id(sunsynk_esphome_pv1_power).state + id(sunsynk_esphome_pv2_power).state);
 - platform: total_daily_energy     # PV Daily Energy
   name: 'SS PV Daily Energy'
   power_id: sunsynk_esphome_pv_power
   unit_of_measurement: 'kWh'
   icon: mdi:circle-slice-3
   restore: true
   filters:
      # Multiplication factor from W to kW is 0.001
      - multiply: 0.001
 - platform: modbus_controller  # 190 Battery Output
   name: "SS Battery Output Power"
   address: 190
   device_class: power
   filters: #GOOD
    - lambda: |-
           else return (x) /1;
 - platform: modbus_controller          # 184 Battery SOC
   name: "SS Battery SOC"
   address: 184
   device_class: battery
   filters: #GOOD
    - lambda: |-
           else return (x) /1;
 - platform: modbus_controller          # 184 Battery Usable SOC
   name: "SS Battery Usable SOC"
   address: 184
   filters: #GOOD
   # battery normally charges to 99%, shutdown level is 20%, so subtract 19 from value and calculate as percentage divided by 80
    - lambda: |-
           if (x > 32767) {
              int y = ((((x - 65535) -19) /80) *100) /1;
              if (y > 100) return 100;
              return y;
           else {
              int y = (((x -19) /80) *100) /1;
              return y;
 - platform: modbus_controller          # 216 Battery Charging Efficiency
   name: "SS Battery Charging Efficiency"
   address: 216
   filters: #GOOD
    - lambda: |-
# - platform: modbus_controller          # 013 Firmware Control Board
#   modbus_controller_id: sunsynk_esphome
#   name: "SS Firmware Control Board"
#   id: sunsynk_esphome_firmware_control_board
#   register_type: holding
#   address: 13
# - platform: modbus_controller          # 013 Firmware Comms Board
#   name: "SS Firmware Comms Board"
#   id: sunsynk_esphome_firmware_comms_board
#   address: 14
 - platform: modbus_controller          # 079 Grid Frequency
   name: "SS Grid Frequency"
   address: 79
   unit_of_measurement: "hz"
   filters: #GOOD
    - lambda: |-
           if (x > 32767) return (x - 65535) /100;
           else return (x) /100;
   #device_class: none
 - platform: modbus_controller          # 192 Load Frequency
   name: "SS Load Frequency"
   address: 192
   filters: #GOOD
    - lambda: |-
   #device_class: none
 - platform: modbus_controller          # 154 Grid Inverter Voltage
   name: "SS Grid Inverter Voltage"
   address: 154
   unit_of_measurement: "V"
   filters: #GOOD
     - lambda: |-
   device_class: voltage
 - platform: modbus_controller         # 150 Grid Voltage
   name: "SS Grid Voltage"
   address: 150
   filters: #GOOD
     - lambda: |-
   address: 154
   filters: #GOOD
     - lambda: |-
 - platform: modbus_controller          # 183 Battery Voltage
   name: "SS Battery Voltage"
   address: 183
   filters: #GOOD
     - lambda: |-
           if (x > 32767) return (x - 65535) / 100;
           else return x / 100;
 - platform: modbus_controller          # 312 Battery Charge Voltage
   name: "SS Battery Charge Voltage"
   address: 312
   filters: #GOOD
     - lambda: |-
           x = x / -1;
           if (x > 32767) return (0 - x + 65535) /100;
           else return (0 - x) /100;
 - platform: modbus_controller          # 167 Grid Inverter Load
   name: "SS Grid Inverter Load"
   address: 167
   filters: #GOOD
     - lambda: |-
           else return (x) /1;
   device_class: power
 - platform: modbus_controller          # 172 Grid External Power
   name: "SS Grid External Power"
   address: 172
   filters: #GOOD
     - lambda: |-
           else return (x) /1;
   device_class: power
 - platform: total_daily_energy        # Grid External Daily Energy
   name: 'SS Grid External Daily Energy'
   power_id: sunsynk_esphome_grid_external_power
   restore: true
   filters:
      - multiply: 0.001
 - platform: modbus_controller          # 166 Aux Output Power
   name: "SS Aux Output Power"
   address: 166
   filters: #GOOD
     - lambda: |-
           else return (x) /1;
   device_class: power
 - platform: modbus_controller          # 164 Inverter Output Current
   name: "SS Inverter Output Current"
   address: 191
   unit_of_measurement: "A"
   device_class: current
   filters: #GOOD
    - lambda: |-
 - platform: modbus_controller          # 191 Battery Output Current
   name: "SS Battery Output Current"
   address: 191
   filters: #GOOD
    - lambda: |-
 - platform: modbus_controller          # 182 Battery Temperature
   name: "SS Battery Temperature"
   address: 182
   unit_of_measurement: "°C"
   device_class: temperature
   filters: # GOOD
    - lambda: |-
           if (x > 32767) return ((x - 65535)-1000) / 10;
           else return ((x)-1000) / 10;
 - platform: modbus_controller          # 090 DC Transformer Temperature
   name: "SS DC Transformer Temperature"
   address: 090
   filters: # GOOD
    - lambda: |-
 - platform: modbus_controller          # 091 Radiator Temperature
   name: "SS DC Radiator Temperature"
   address: 091
   filters: # GOOD
    - lambda: |-
 - platform: modbus_controller          #076 Grid Import Day (Buy)
   name: "SS Grid Import Day (Buy)"
   address: 76
   filters: # GOOD
    - lambda: |-
           else return x /10;
 - platform: modbus_controller          # 070 Battery Charge Day
   name: "SS Battery Charge Day"
   address: 70
   filters: #GOOD
    - lambda: |-
           x = x / 10;
           else return (x) /1;
 - platform: modbus_controller          # 071 Battery Discharge Day
   name: "SS Battery Discharge Day"
   address: 71
   filters: #GOOD
    - lambda: |-
           x = x / 10;
           else return (x) /1;
 - platform: modbus_controller          # 175 Inverter Output Power
   name: "SS Inverter Output Power"
   address: 175
   device_class: power
   filters: #GOOD
    - lambda: |-
           if (x > 32767) return (0 - x + 65535) /-1;
           else return (0 - x) /-1;
################################################ READ SETTINGS ################################################
 - platform: modbus_controller          # 250 Settings Timezone1
   name: "SSS Setting Timezone1"
   skip_updates: ${settings_skipped_updates}
   address: 250
   filters: #GOOD
    - lambda: |-
           else return (x) /1;
 - platform: modbus_controller          # 251 Settings Timezone2
   name: "SSS Setting Timezone2"
   address: 251
   filters: #GOOD
    - lambda: |-
           else return (x) /1;
 - platform: modbus_controller          # 252 Settings Timezone3
   name: "SSS Setting Timezone3"
   address: 252
   filters: #GOOD
    - lambda: |-
           else return (x) /1;
 - platform: modbus_controller          # 253 Settings Timezone4
   name: "SSS Setting Timezone4"
   address: 253
   filters: #GOOD
    - lambda: |-
           else return (x) /1;
 - platform: modbus_controller          # 254 Settings Timezone5
   name: "SSS Setting Timezone5"
   address: 254
   filters: #GOOD
    - lambda: |-
           else return (x) /1;
 - platform: modbus_controller          # 255 Settings Timezone6
   name: "SSS Setting Timezone6"
   address: 255
   filters: #GOOD
    - lambda: |-
           else return (x) /1;
 - platform: modbus_controller          # 256 Settings Sell Mode Timezone1
   name: "SSS Setting Sell Mode Timezone1"
   address: 256
   filters: #GOOD
    - lambda: |-
           else return (x) /1;
 - platform: modbus_controller          # 257 Settings Sell Mode Timezone2
   name: "SSS Setting Sell Mode Timezone2"
   address: 257
   filters: #GOOD
    - lambda: |-
           else return (x) /1;
 - platform: modbus_controller          # 258 Settings Sell Mode Timezone3
   name: "SSS Setting Sell Mode Timezone3"
   address: 258
   filters: #GOOD
    - lambda: |-
           else return (x) /1;
 - platform: modbus_controller          # 259 Settings Sell Mode Timezone4
   name: "SSS Setting Sell Mode Timezone4"
   address: 259
   filters: #GOOD
    - lambda: |-
           else return (x) /1;
 - platform: modbus_controller          # 260 Settings Sell Mode Timezone5
   name: "SSS Setting Sell Mode Timezone5"
   address: 260
   filters: #GOOD
    - lambda: |-
           else return (x) /1;
 - platform: modbus_controller          # 261 Settings Sell Mode Timezone6
   name: "SSS Setting Sell Mode Timezone6"
   address: 261
   filters: #GOOD
    - lambda: |-
           else return (x) /1;
 - platform: modbus_controller          # 245 Settings Export Limit
   name: "SSS Setting Export Limit"
   address: 245
   device_class: power
   filters: #GOOD
    - lambda: |-
           else return (x) /1;
 - platform: modbus_controller          # 217 Settings Battery Shutdown
   name: "SSS Setting Battery Shutdown"
   address: 217
   filters: #GOOD
    - lambda: |-
           else return (x) /1;
 - platform: modbus_controller          # 219 Settings Battery Low
   name: "SSS Setting Battery Low"
   address: 219
   filters: #GOOD
    - lambda: |-
           else return (x) /1;
 - platform: modbus_controller          # 218 Settings Battery Restart
   name: "SSS Setting Battery Restart"
   address: 218
   filters: #GOOD
    - lambda: |-
           else return (x) /1;
 - platform: modbus_controller          # 210 Settings Battery Max Charge Current
   name: "SSS Setting Battery Max Charge Current"
   address: 210
   filters: #GOOD
    - lambda: |-
           else return (x) /1;
 - platform: modbus_controller          # 211 Settings Battery Max Discharge Current
   name: "SSS Setting Max Discharge Current"
   address: 211
   filters: #GOOD
    - lambda: |-
           else return (x) /1;
 - platform: modbus_controller          # 230 Settings Grid Charge Current
   name: "SSS Setting Grid Charge Current"
   address: 230
   filters: #GOOD
    - lambda: |-
           else return (x) /1;
   name: 'SS Inverter Daily Energy'
   power_id: sunsynk_esphome_inverter_output_power
   restore: true
   filters:
      - multiply: 0.001
############################################### BINARY SENSORS ###############################################
binary_sensor:
 - platform: status
   name: Status ${device_name}
 - platform: modbus_controller          # 194 Grid Connected Status
   name: "SS Grid Connected Status"
   address: 194
############################################### BINARY SENSORS SETTINGS ###############################################
 - platform: modbus_controller          # 244 Settings Load Limit Enabled
   name: "SSS Setting Load Limit Enabled"
   address: 244
 - platform: modbus_controller          # 247 Settings Solar Export Enabled
   name: "SSS Setting Solar Export Enabled"
   address: 247
 - platform: modbus_controller          # 232 Settings Battery Grid Charge Enabled
   name: "SSS Setting Battery Grid Charge Enabled"
   address: 232
############################################### TEXT SENSORS SETTINGS ###############################################
text_sensor:
 - platform: wifi_info
   ssid:
      name: SSID ${device_name}
   bssid:
      name: BSSID ${device_name}
 - platform: modbus_controller          # 243 Settings Energy Management Model (PL)
   name: "SSS Setting Energy Management Model"
   raw_encode: HEXBYTES
   address: 243
   lambda: |-
      uint16_t value = modbus_controller::word_from_hex_str(x, 0);
      switch (value) {
        case 0: return std::string("Battery Priority Mode");
        case 1: return std::string("Load First Mode");
        default: return std::string("Unknown");
 - platform: modbus_controller          # 059 Overall State
   name: "SS Overall State"
   address: 59
   lambda: |- # It is not clear what each of these states mean. TODO Fill in the string values once known
      switch (value) {
        case 0: return std::string("0");
        case 1: return std::string("1");
        case 2: return std::string("2");
        case 3: return std::string("3");
        case 4: return std::string("4");
        case 5: return std::string("5");
I hope it helps!
Here is the Github by @Klatremisfor the ESPhome for the 12K DEYE inverter whose Modbus registers are totally different to the Sunsynk 8kw & 5kw inverters.
Not sure which DEYE/Sunynk models Modbus registers are compatible, maybe something to do for someone with some spare time to work out 🙂
https://github.com/klatremis/esphome-for-deye/
Edited by Sc00bs
Many thanks CorneSchutte and Sc00bs for your replies.
In a short analysis, looks like your code (CorneShutte) matches my Deye 5Kw registers.
Received today the TTL-RS485 adapter, so later today is time for bricolage :)
One question:
How is it managed the registers that contain two words? for example the Total Grid Buy Power (KWh) contains two registers (78 for low word and 80 for high word) according to the Modbus doc. I understand that the final value is a combination of these two values, right?
Is this being managed by the ESPHome code somehow?
Martinisonline - the ESPHome code (as originally written by sjlouw and refined by jacauc, with the update mod by slipx), only has the following for Grid Import Total (Buy) and it works fine for me:
   address: 78
   filters: #GOOD
    - lambda: |-
           x = x / -1;
Thus this ESPHome implementation therefore does not use the 80 register as far as I can tell? See if it works for you?
For me, the code I inherited from jacauc etc worked immediately - the challenge was to identify the correct 2 wires in the Ethernet cable to connect to the TTL-RS485, but once I had done that, it simply just worked. I had recently tidied it up and put the ESP32 and TTL-RS485 in a nice case with some ventilation slots and have had no issues.
CorneSchutte, what I'm thinking is:
The registers have a 16bit length, which means they can handle values from 0 up to 65535. On this specific register, one unit represents 0.1KWh so the maximum value the register can record is 6.553,5 KWh. So, when this value is reached, the register goes to 0 and the "high word" or the register 80 increments.
Saying this, it will work fine until it reaches the 6,55 MWh. After that it will reset to 0 if we don't take into account the register number 80!
Maybe I'm wrong, but this is my understanding :)
esphome:
preferences:
esp32:
  board: esp32dev
  framework:
    type: arduino
substitutions:
wifi:
  ssid: XXXX
  password: XXX
  fast_connect: true
ota:
  safe_mode: true
  num_attempts: 5
web_server:
  port: 80
#captive_portal:
# Enable logging
#logger:
#  baud_rate: 0
api:
time:
uart:
 tx_pin: 17
 rx_pin: 16
 baud_rate: 9600
 stop_bits: 1
modbus:
 flow_control_pin: 4
modbus_controller:
   address: 0x01
   setup_priority: -10
switch:
  - platform: restart
    address: 248
    bitmask: 1
    address: 274
    bitmask: 1
    address: 275
    bitmask: 1
    address: 276
    bitmask: 1
    address: 277
    bitmask: 1
    address: 278
    bitmask: 1
    address: 279
    bitmask: 1
number:
    address: 268
    min_value: 0
    max_value: 100
    step: 5
    value_type: U_WORD
    address: 269
    min_value: 0
    max_value: 100
    step: 5
    value_type: U_WORD
    address: 270
    min_value: 0
    max_value: 100
    step: 5
    value_type: U_WORD
    address: 271
    min_value: 0
    max_value: 100
    step: 5
    value_type: U_WORD
    address: 272
    min_value: 0
    max_value: 100
    step: 5
    value_type: U_WORD
    address: 273
    min_value: 0
    max_value: 100
    step: 5
    value_type: U_WORD
sensor:
   internal: true
   icon: "mdi:wifi"
   lambda: |-
          return 1.0;
          return 100.0;
        else
 - platform: uptime
   filters:
   address: 72
   filters:
    - lambda: |-
           x = x / -1;
   address: 74
   filters:
    - lambda: |-
   address: 81
   filters:
    - lambda: |-
           else return x /10;
   address: 78
   filters: #GOOD
    - lambda: |-
           x = x / -1;
   address: 85
   filters: #GOOD
    - lambda: |-
   address: 96
   filters:
     - multiply: 0.1
   address: 169
   device_class: power
   filters: #GOOD
    - lambda: |-
           else return (x) /1;
   address: 178
   device_class: power
   filters: #GOOD
    - lambda: |-
           else return (x) /1;
   address: 186
   device_class: power
   address: 187
   device_class: power
   name: "SS PV Power"
   device_class: power
   lambda: |-
   restore: true
   filters:
      - multiply: 0.001
   address: 190
   device_class: power
   filters: #GOOD
    - lambda: |-
           else return (x) /1;
   address: 184
   filters: #GOOD
    - lambda: |-
           else return (x) /1;
   address: 184
   filters: #GOOD
    - lambda: |-
           if (x > 32767) {
              return y;
           else {
              return y;
   address: 216
   filters: #GOOD
    - lambda: |-
#   address: 13
#   address: 14
   address: 79
   filters: #GOOD
    - lambda: |-
   #device_class: none
   address: 192
   filters: #GOOD
    - lambda: |-
   #device_class: none
   address: 154
   filters: #GOOD
     - lambda: |-
   address: 150
   filters: #GOOD
     - lambda: |-
   address: 154
   filters: #GOOD
     - lambda: |-
   address: 183
   filters: #GOOD
     - lambda: |-
   address: 312
   filters: #GOOD
     - lambda: |-
           x = x / -1;
   address: 167
   filters: #GOOD
     - lambda: |-
           else return (x) /1;
   device_class: power
   address: 172
   filters: #GOOD
     - lambda: |-
           else return (x) /1;
   device_class: power
   restore: true
   filters:
      - multiply: 0.001
   address: 166
   filters: #GOOD
     - lambda: |-
           else return (x) /1;
   device_class: power
   address: 191
   filters: #GOOD
    - lambda: |-
   address: 191
   filters: #GOOD
    - lambda: |-
   address: 182
   filters: # GOOD
    - lambda: |-
   address: 090
   filters: # GOOD
    - lambda: |-
   address: 091
   filters: # GOOD
    - lambda: |-
   address: 76
   filters: # GOOD
    - lambda: |-
           else return x /10;
   address: 70
   filters: #GOOD
    - lambda: |-
           x = x / 10;
           else return (x) /1;
   address: 71
   filters: #GOOD
    - lambda: |-
           x = x / 10;
           else return (x) /1;
   address: 175
   device_class: power
   filters: #GOOD
    - lambda: |-
   address: 250
   filters: #GOOD
    - lambda: |-
           else return (x) /1;
   address: 251
   filters: #GOOD
    - lambda: |-
           else return (x) /1;
   address: 252
   filters: #GOOD
    - lambda: |-
           else return (x) /1;
   address: 253
   filters: #GOOD
    - lambda: |-
           else return (x) /1;
   address: 254
   filters: #GOOD
    - lambda: |-
           else return (x) /1;
   address: 255
   filters: #GOOD
    - lambda: |-
           else return (x) /1;
   address: 256
   filters: #GOOD
    - lambda: |-
           else return (x) /1;
   address: 257
   filters: #GOOD
    - lambda: |-
           else return (x) /1;
   address: 258
   filters: #GOOD
    - lambda: |-
           else return (x) /1;
   address: 259
   filters: #GOOD
    - lambda: |-
           else return (x) /1;
   address: 260
   filters: #GOOD
    - lambda: |-
           else return (x) /1;
   address: 261
   filters: #GOOD
    - lambda: |-
           else return (x) /1;
   address: 245
   device_class: power
   filters: #GOOD
    - lambda: |-
           else return (x) /1;
   address: 217
   filters: #GOOD
    - lambda: |-
           else return (x) /1;
   address: 219
   filters: #GOOD
    - lambda: |-
           else return (x) /1;
   address: 218
   filters: #GOOD
    - lambda: |-
           else return (x) /1;
   address: 210
   filters: #GOOD
    - lambda: |-
           else return (x) /1;
   address: 211
   filters: #GOOD
    - lambda: |-
           else return (x) /1;
   address: 230
   filters: #GOOD
    - lambda: |-
           else return (x) /1;
   restore: true
   filters:
      - multiply: 0.001
binary_sensor:
 - platform: status
   address: 194
   address: 244
   address: 247
   address: 232
text_sensor:
   ssid:
   bssid:
   address: 243
   lambda: |-
      switch (value) {
   address: 59
      switch (value) {
I hope it helps!
I was playing with some text sensors to get the timezone to display as 02:00 as opposed to 200 etc. You can try them if it helps
text_sensor:
    lambda: |-
        int minutes, hours;
        if (id(sunsynk_esphome_setting_timezone1).state) {
        minutes = static_cast<int>(id(sunsynk_esphome_setting_timezone1).state) % 100;
        hours = static_cast<int>(id(sunsynk_esphome_setting_timezone1).state) / 100;
        } else {
          minutes = 0;
          hours = 0;
        char formatted_time[6];
        snprintf(formatted_time, sizeof(formatted_time), "%02d:%02d", hours, minutes);
        return esphome::optional<std::string>(formatted_time);
    lambda: |-
        int minutes, hours;
        if (id(sunsynk_esphome_setting_timezone2).state) {
        minutes = static_cast<int>(id(sunsynk_esphome_setting_timezone2).state) % 100;
        hours = static_cast<int>(id(sunsynk_esphome_setting_timezone2).state) / 100;
        } else {
          minutes = 0;
          hours = 0;
Edited by slipx
On 2023/02/24 at 5:06 PM, Rynoster said:
Thought I would also contribute with something small. Not as impressive as what some of the others here but a contribution nonetheless.
The GUI for Sunsynk System Mode, or lack thereof, has really been annoying me, so I put this together. It needed to be easy to read to quickly understand what's going on, and also easy for the wife to change if needed.
It requires the lovelace-layout-card to work. For my purposes, it's also a separate view.
  - theme: Backend-selected
    title: Grid layout
    type: custom:grid-layout
    layout:
      grid-template-columns: 3fr 2fr 2fr 3fr
      grid-template-rows: auto
      grid-template-areas: |
        ". header header ."
        ". system priority ."
        ". prog1 prog2 ."
        ". prog3 prog4 ."
        ". prog5 prog6 ."
      mediaquery:
        '(max-width: 800px)':
          grid-template-columns: auto
            "header"
            "system"
            "priority"
            "prog1"
            "prog2"
            "prog3"
            "prog4"
            "prog5"
            "prog6"
    badges: []
    cards:
      - type: entities
        entities:
          - entity: select.system_mode
        show_header_toggle: false
        view_layout:
          grid-area: system
      - type: vertical-stack
        cards:
          - type: custom:mushroom-template-card
            primary: Program 1
            secondary: >-
              {{ states("select.prog1_time") }} - {{ states("select.prog2_time")
            icon: mdi:timer
            multiline_secondary: false
            badge_icon: mdi:lightning-bolt
            icon_color: blue
            badge_color: green
            fill_container: false
          - type: horizontal-stack
            cards:
              - type: entities
                entities:
                  - entity: select.prog1_time
              - type: entities
                entities:
                  - entity: select.prog1_charge
          - type: entities
            entities:
              - type: custom:slider-entity-row
                entity: number.prog1_power
                grow: true
                entity: number.prog1_capacity
        view_layout:
          grid-area: prog1
        cards:
            primary: Program 2
            secondary: >-
              {{ states("select.prog2_time") }} - {{ states("select.prog3_time")
            icon: mdi:timer
            icon_color: blue
            badge_color: green
            cards:
              - type: entities
                entities:
                  - entity: select.prog2_time
              - type: entities
                entities:
                  - entity: select.prog2_charge
          - type: entities
            entities:
                entity: number.prog2_power
                grow: true
                entity: number.prog2_capacity
        view_layout:
          grid-area: prog2
        cards:
            primary: Program 3
            secondary: >-
              {{ states("select.prog3_time") }} - {{ states("select.prog4_time")
            icon: mdi:timer
            icon_color: blue
            badge_color: green
            cards:
              - type: entities
                entities:
                  - entity: select.prog3_time
              - type: entities
                entities:
                  - entity: select.prog3_charge
          - type: entities
            entities:
                entity: number.prog3_power
                grow: true
                entity: number.prog3_capacity
        view_layout:
          grid-area: prog3
        cards:
            primary: Program 4
            secondary: >-
              {{ states("select.prog4_time") }} - {{ states("select.prog5_time")
            icon: mdi:timer
            icon_color: blue
            badge_color: green
            cards:
              - type: entities
                entities:
                  - entity: select.prog4_time
              - type: entities
                entities:
                  - entity: select.prog4_charge
          - type: entities
            entities:
                entity: number.prog4_power
                grow: true
                entity: number.prog4_capacity
        view_layout:
          grid-area: prog4
        cards:
            primary: Program 5
            secondary: >-
              {{ states("select.prog5_time") }} - {{ states("select.prog6_time")
            icon: mdi:timer
            icon_color: blue
            badge_color: green
            cards:
              - type: entities
                entities:
                  - entity: select.prog5_time
              - type: entities
                entities:
                  - entity: select.prog5_charge
          - type: entities
            entities:
                entity: number.prog5_power
                grow: true
                entity: number.prog5_capacity
        view_layout:
          grid-area: prog5
        cards:
            primary: Program 6
            secondary: >-
              {{ states("select.prog6_time") }} - {{ states("select.prog1_time")
            icon: mdi:timer
            icon_color: blue
            badge_color: green
            cards:
              - type: entities
                entities:
                  - entity: select.prog6_time
              - type: entities
                entities:
                  - entity: select.prog6_charge
          - type: entities
            entities:
                entity: number.prog6_power
                grow: true
                entity: number.prog6_capacity
        view_layout:
          grid-area: prog6
      - type: custom:mushroom-title-card
        title: Sunsynk System Mode
        alignment: center
        view_layout:
          grid-area: header
      - type: entities
        entities:
          - entity: select.priority_mode
        view_layout:
          grid-area: priority
Did you make any further modifications to you dashboard? I did try to add it but I get the error below and I dod have all the mushroom card installed and also the loveloace-layout-card, can you share the code if you did? image.png.7a8bfacfcfdf9db89b5737bf17008d12.png
On 2022/11/03 at 11:19 AM, slipx said:
I am getting some weird spikes on  "172 Grid External Power" and "169 Grid Power" sensors.
Trying the following to filter them out which seems to be working:
   address: 169
   device_class: power
   filters:
    - lambda: |-
          float MAX_DIFFERENCE = 8000.0;  // adjust this!
          static float last_value_t = NAN;
          static int count_missed_t = 0;
          if (count_missed_t == 3) last_value_t = x;
          if (isnan(last_value_t) || std::abs(x - last_value_t) < MAX_DIFFERENCE) {
            count_missed_t = 0;
            return last_value_t = x;
          } else {
            count_missed_t += 1;
            return last_value_t;
Hello,
I notice a similar behavior and the issue was the way the variables were defined. There are some power values that are SIGNED, and other are UNSIGNED. Make sure the signed (the ones that can be positive or negative) are properly defined as SIGNED (value_type: S_WORD).
7 hours ago, martinisonline said:
Hello,
Does anyone have a list of all data types for all registers? The Sunsynk word document leaves a lot for the imagination
Hi @jacauc
There are the two Modbus register files that I have
sunsynk_modbus which looks like an extraction from a manual as it looks like it starts at 2.6
I also have a Chinese document that I translated with Google Translate. I think that it is v117 of  the document which was released in 2021 so there may actually be a v118 out by now but haven't seen it as yet.
sunsynk_modbus.pdf Modbus118 Translated-compressed.pdf
On 2022/12/19 at 1:37 AM, slipx said:
How about a small dot that changes colour
Hi @slipx
Thanks for the great job you've done with this card!
I took it one step further and made the battery icon and lightning bolt smart.
When the battery is charging the lightning bolt appears. The bars in the battery changes based on the current SoC of the battery.
I achieved this by overlaying three battery icons and only showing the relevant one (same way as you did with the status indicator).
Just a question for anyone who has solar-assistant integrated into home assistant via MQTT.
How many entities do you have? I think i may be missing a few
did you enable allow setting changes on the solar assistant config page for MQTT?
I guess what i'm asking is how to you get the prog1 time settings like the ones below
I don't have that option, I only seem to have this option below which says Capacity point
Edited by McAllstar
12 hours ago, jacauc said:
Thanks @Sc00bs. I've seen those before but unfortunately it's not very clear to decipher the data types and whether signed/unsigned.
@jacauc I sent an email to DEYE asking if they had a newer Modbus document and received a response from them saying that the V118 document is the latest version
Having the same problem 😞
I think i kinda figured it out.
You need to create a new view by editing one of your dashboards and then select the + icon
then i you need to select the 3 dots in the top right and select "Edit in YAML"
then i think you need to past this part of his code. After that then you can select "add card" and use the rest of his code. you need to modify the entities according to your entity names. That's where my problem comes in I'm using solar-assistant and my entity names don't match his and I'm missing the timer and prod entities.
    title: Grid layout
    layout:
        ". header header ."
        ". capacity point 1 prog2 ."
        ". prog3 prog4 ."
        ". prog5 prog6 ."
      mediaquery:
            "header"
            "system"
            "priority"
            "prog1"
            "prog2"
            "prog3"
            "prog4"
            "prog5"
            "prog6"
    badges: []
11 hours ago, JDSym said:
Hi @slipx
I've made some updates to the card to include dynamic animations. It will now animate power flow based on defined conditions i.e. positive/negative battery power, zero power etc.  I didn't want to have circles moving all over the place so not all paths are animated but you can modify to suite your needs. Note the moving circle is hidden if power is 0. Here is the link to the GitHub repo
https://github.com/slipx06/Sunsynk-Home-Assistant-Power-Flow-Card
Brilliant!
What program do you use to edit the SVG? I've been using Inkscape, and it works quite well. The one disadvantage is that it adds a lot of unnecessary code needed by the program.
1 hour ago, JDSym said:
Brilliant!
Notepad...😄
4 hours ago, slipx said:
Notepad...😄
Impressive 😁
I would suggest showing the absolute values of the readings since the direction of the dot shows the direction of current flow and makes the negative sign in the readings redundant.
