April 29, 20215 yr So I left lead acid 2 months ago and got a hubble installed. Yesterday I noticed that the Sunsynk is showing an error code F58 bms communication fault. I can't find any further details on the web. Do I take it up with hubble? Sunsynk? Or the supplier?
April 29, 20215 yr 4 hours ago, Dani said: So I left lead acid 2 months ago and got a hubble installed. Yesterday I noticed that the Sunsynk is showing an error code F58 bms communication fault. I can't find any further details on the web. Do I take it up with hubble? Sunsynk? Or the supplier? It depends on the cause, I got a once-off F58 error when I upgraded firmware. What doess your LiBMS screen say?
April 29, 20215 yr Author So it seemed to behave during the day so I left it but at night.... I will try swap the cat5e cable tomorrow? Here is the libms screen.
April 30, 20215 yr 11 hours ago, Dani said: So it seemed to behave during the day so I left it but at night.... I will try swap the cat5e cable tomorrow? Here is the libms screen. That's the fault code screen, not the LiBMS screen.
April 30, 20215 yr looked at the AM 2 specs, voltage should be 51 volts, 44 seems too low, call Hubble
April 30, 20215 yr There's definitely a problem. Tried swopping out the comms cables? It's where I would start, the most likely place, especially if it's intermittent.
May 3, 20215 yr Author On 2021/04/30 at 2:59 PM, Tariq said: voltage should be 51 volts, 44 seems too low, call Hubble Thx @Tariq dunno if other hubble users can comment. It's now at 46v and 60%?
May 4, 20215 yr Can be that the BMS did not fully switch on. I know on some BMS the voltage is quite low until the BMS gets the signal to fully switch on and then it rises.
July 17, 20215 yr Reviving this thread. Are you using a RIOT? I noticed that your LiBms reads 00, which is what mine reads when I have the RIOT connected. When I connect battery directly to the inverter, it shows LiBms:01, as well as SOH next to SOC.
July 21, 20215 yr On 2021/07/17 at 10:26 PM, Saliegh said: Reviving this thread. Are you using a RIOT? I noticed that your LiBms reads 00, which is what mine reads when I have the RIOT connected. When I connect battery directly to the inverter, it shows LiBms:01, as well as SOH next to SOC. Is this on a Sunsynk and AM-2 combo? Which firmware are you running? Using CAN or RS485? Please post your battery settings screens as well as the Li-BMS screen. Thanks
July 29, 20215 yr On 2021/07/23 at 9:23 AM, Dani said: Will do when i'm back home. @Dani, are you home yet?
August 15, 20214 yr Author Using hubble Am 2 with sunsyk 5.5 No riot. @swazz99jhb Sorry for the late reply
August 15, 20214 yr Funny how these Hubble's differ. Mine is sitting at 125A yours at 95A. I thought you could see the HOC? I've seen some of the guys posts showing it. Not sure if their hubble's are newer or just newer firmware. Think I'm scratching an itch that doesn't itch. My setup works 100%
August 16, 20214 yr 15 hours ago, swazz99jhb said: Funny how these Hubble's differ. Mine is sitting at 125A yours at 95A. I thought you could see the HOC? I've seen some of the guys posts showing it. Not sure if their hubble's are newer or just newer firmware. Think I'm scratching an itch that doesn't itch. My setup works 100% It gets those values from the BMS, so it's dependent on the SoC, SOH etc.
