Solar Installation Advice - Off grid, small house
11 hours ago, dax021 said:
Chris, so what batteries would you recommend?  My needs are very similar to this and I already have an Axpert 3Kva Plus 48V and 4 x 295W panels.  At the moment my Trojans (T1275) are poked and I need to buy something soon. Thanks
I have found the OmniPowers to work quite well with Axpert inverters. Sacred Sun and Vision batteries also work quite well.
  • Replies 66
  • Views 16.6k
  • Chris Hobson
    Chris Hobson
    I see you already have been made aware of the 3kVA Plus version which can handle 1500W of panels. I would not use Trojans with an Axpert. There are hassles with the Trojans high charge voltage and nee
  • I will trust in what the manufacturer of the batts say This is key, add balancers and look after the things and you will be fine. And if my gravity readings go out of spec, I will use the cha
  • SilverNodashi
    SilverNodashi
1 hour ago, plonkster said:
You cannot do an equalisation charge on Trojans with an Axpert. That's the low-down. They cannot push the voltage that high on their own, and if you do it with an external charger with the Axpert in circuit you will either pop a capacitor or two or at least severely shorten their life. That means that for this once in a lifetime event (or two, or three) you need extra equipment and you're without power while you're doing it. I think it's an acceptable trade-off to those who know what they are doing, but unacceptable for an end-user system. Humble opinion of course :-)
@plonkster this makes me wonder: How difficult would it be to build a buck booster / limiter that could work with 100A / 54V? i.e. if you could put a buck booster in between the batteries and the Axpert, then you could use a Victron (or other favorite) MPPT charger and always ensure charging is to speck?
I think it would be way more effort than it is worth. Buy different batteries and be done with it :-)
You should check out the EEVBlog on youtube, that guy had a complete field day with a product called the "Batteriser", essentially a little sleeve insert that boosts AA or AAA batteries to an exact 1.5V so they "last longer"... :-)
50 minutes ago, plonkster said:
I think that is why the Axpert cannot run with a <200Ah battery, or at least it is not advised. You need some bulk to absorb the overshoots :-)
I would love to see that thing on something small, like a 50Ah battery perhaps. That should be fun.
that can be arranged. Will you sponsor the goods? ;)
Ok, but how much more effort would it be, for it not to be worth-while?
Well, this thing would have to be bi-directional, init? It has to look like a battery to the inverter, accept charge from it and put it into the batteries, and at the same time supply charge to the inverter, doing a voltage level conversion both ways. I think it would be so much trouble you'd be better off buying a proper inverter :-)
True, but if it cost say R2K, or even R5K to build, a "proper inverter" would be way out of budget still. Especially since your "proper inverter" (aka Victron) still needs it's own MPPT charger. But at R5K it would mean that I have it and can add Trojan batteries, or even other batteries in future, at no additional cost. But this is all just curiousity more than anything else. Does something like this even exist? On this scale, I mean? Or is it possible to build such a circuit? a 60V level shifter is fairly easy to build, but to handle 100A as well, that's a whole different story. That's a LOT of power / energy to dissipate. So I guess it's cheaper to upgrade the DC components inside to 80V capable components?
Lol. Yes I was being a little cheeky there :-) I'm not qualified enough to tell you what it would take to build such a thing. I'm just a hobbyist with a middle-of-the-road understanding of buck and boost converters. I'd say 5k is optimistic, it would take more. It would cost at least as much as two MPPTs of the same sort of power level, because that's what it would be, two cooperating converters. It also adds another +-10% drop into the chain, a chain which is only about 91% efficient as it stands. The right answer is to buy another inverter, or to upgrade the components in the one you have. I believe some Ausies have done it.
The idea of such a converter did briefly cross my mind when we discussed super-capacitors. You may recall, the issue with those is they discharge linearly and to get all the energy out you have to go as low as possible.
On 1/16/2017 at 6:47 PM, DeepBass9 said:
Got some info about the existing system. A Steca Pr2020 charge controller, 2x 100Ah Stride batteries.
And an Omnipower 300W 12V inverter. So all in all, hopelessly inadequate for the loads required.
Looks like she is in for about R20-25k for a big enough system, i.e about 1000W of panels, 4 x  +-200Ah batteries, 2-3kW inverter and MPPT.
3 minutes ago, Johann1982 said:
Im not sure it will pull a fridge starting up. Id rather also go for a 24v system.
4 minutes ago, Johann1982 said:
How about this one?
Be careful for too small an inverter that will stop working if the Fridge comes on when rest is powered. Been there, done that.
According to Microcare, having your panel voltage <4 times your battery voltage is better as that is where the buck converters are most efficient.
Another think I just realised is that lots of LED lights work on 10-30V, so on a 24V system you can easily run LEDS directly for lighting (ant they will still run no matter how pap your batteries get!). Like these for example (the first that google came up with) : https://www.superbrightleds.com/cat/recessed-led-light-fixtures-10-30v/
I think that will help with the efficiency of the system quite a lot, and your won't need so much 220V wiring (there is no existing wiring in the house AFAIK)
Is anyone familiar with the  Steca Pr2020 charge controller that she has? It is supposed to be 12/24V and 20A. That should still be usable?
It looks like a good piece of kit. Not an MPPT, but you could pay for an extra solar panel with the amount you would lose by selling it and buying another charge controller. : http://www.steca.com/index.php?Steca-PR-2020-IP-en
On ‎2017‎/‎01‎/‎17 at 5:21 AM, DeepBass9 said:
How long did your T1275s last? I have 8 of them that are getting towards 2 years old now, with no problems as yet.
Just wrote you a long reply but lost it somehow.  Short version, they were finished when I got them.  Only running 12V LED's at night and a 350W cheapy inverter when the sun shines
