48v DC smart switches
12 hours ago, Scorp007 said:
What load do you want to switch and do you need energy monitoring?
I want to switch 900W load and energy monitoring will be great to have but not really necessary
I have not yet seen SAFE dc relays with power monitoring available in SA.
You could do a DIY switch/relay/monitor using a good wifi/rs485 coulomb counter and DC Solid State relay.
And you would most likely need to get this direct from china.
100 AMP Solid State DC Relay with DC control
Heatsink
Coulomb Counter with RS485 Comms to control and read
That should work nicely with any or most home automation systems.
Edited by WannabeSolarSparky
Heatsink
Yep, something like this will definitely work. I just need to get one with Out-put as DC,  the control can be AC. The plan is to be able to switch ON and OFF DC load
Why not just use a relay with AC coil for control and DC rated contacts. You can even use contacts in series but a 900W @ 48V is above most 11 pin relay ratings.
AC coil and atleast 21A DC rated contacts will do.
45 minutes ago, TimCam said:
If you are looking for "old style" contact relays have a look at the one below:-
https://www.dc-contactors.com/dh50-high-voltage-dc-contactor/high-voltage-dc-contactor-dh50c
It's (only) a 50A, but is good enough for 2.4 kW DC.
Using a nano, ESP32 or Pi pico and a shunt you could make up a nice DIY solution. :)
this is perfect, where can I get this locally? 😀
Buy any 3 phase contactor with 30A rating. Wire the 3 contacts in series. They normally come with 230 or 400AC coils. Get from an electrical wholesaler or Voltex branches
3 main contacts at the back and 2 signal contacts on the front.
  • 9 months later...
only seeing now that I never updated this. I did manage to get my DC supply of the geyser element working, thanks to @Scorp007 and the contactor works perfect for switching on and off the supply. This install has been running for nine months now. I use a SONOF to remotely control my ON and OFF and there is also a program or timer that switches it On every day at midnight and off at SUN rise, for the morning shower. Then my batteries gets charged till mid day to 100% and then I use both AC and DC supply to power the geyser again. Depending on the weather and loadshedding. When we have loadshedding or poor weather, I only use the DC to power the element for the rest of the day.
On 2022/08/10 at 10:42 PM, TimCam said:
Haven't sourced one myself, but aliexpress might have one, just the courier charges are high, as the Post Office is now dead.
https://www.aliexpress.com/w/wholesale-48v-200a-dc-contactor.html
Strangely enough, I actually managed to pick up an Aliexpress package last week from the Post Office!!
No reply from either their customer service email address or phone number so i took a chance and stopped by the post office cause the tracking said it was ready for collection. Feel sorry for the people working there, they are the last passengers on a sinking ship.
