August 30, 20224 yr Hi, posted on facebook, but need some more input. After reading above post, I am little worried. My 5.5kw hubble is about a year old, normally it last till around 3am, when only using about 0.4kw/h during the night. But this last 2 months the battery drops very quick, does this look normal?
August 30, 20224 yr If your base load is around 400W an hour that would be 4kW in 10 hours. Looking at the graph you start using battery around 17:00 and at around 21:00 your battery usage would have been 400W X 4 = 1600W yet it's down to 20%. Have you had your firmware updated? There were updates by Hubble to address problematic battery comms and behaviour with certain Inverters. What Inverter is this coupled to and do you have BMS comms set up? Edited August 30, 20224 yr by zsde
August 30, 20224 yr Author 20 minutes ago, zsde said: If your base load is around 400W an hour that would be 4kW in 10 hours. Looking at the graph you start using battery around 17:00 and at around 21:00 your battery usage would have been 400W X 4 = 1600W yet it's down to 20%. Have you had your firmware updated? There were updates by Hubble to address problematic battery comms and behaviour with certain Inverters. What Inverter is this coupled to and do you have BMS comms set up? Have a SS 5KW inverter, BMS is connected. Thinking of disconnecting the BMS until until I can get a cable for the update.
August 30, 20224 yr If it is a SS then you definitely need the latest Firmware update from Hubble and possibly a Firmware update for your Inverter too.
August 30, 20224 yr Just a sanity check, to see whether you are not exporting battery power to the grid. Do you have solar selling and the time-of-use settings activated at the same time, or have you modified these settings recently? (Just going on Deye functionality, don't 100% know if SS is similar, but may well be.)
August 30, 20224 yr Author 13 minutes ago, GreenFields said: Just a sanity check, to see whether you are not exporting battery power to the grid. Do you have solar selling and the time-of-use settings activated at the same time, or have you modified these settings recently? (Just going on Deye functionality, don't 100% know if SS is similar, but may well be.) Set to zero export. Haven`t changed anything, will double check tonight.
August 30, 20224 yr 3 hours ago, zsde said: If it is a SS then you definitely need the latest Firmware update from Hubble and possibly a Firmware update for your Inverter too. This is perhaps the 1st thing to do. No I would not run the SS without cable if possible. It does not seem like battery power is exported as per the calculation of @zsde
August 30, 20224 yr 3 hours ago, zsde said: If it is a SS then you definitely need the latest Firmware update from Hubble and possibly a Firmware update for your Inverter too. Removed double post. @zsde Edited August 30, 20224 yr by Scorp007
August 30, 20224 yr Author 46 minutes ago, Scorp007 said: This is perhaps the 1st thing to do. No I would not run the SS without cable if possible. It does not seem like battery power is exported as per the calculation of @zsde Thanks, will make a plan for the upgrade as soon as possible.
August 31, 20224 yr Author Last night I did a full discharge/charge cycle without BMS connected, and only got 2.19Kw out of the battery. Going to do another cycle today, but dont think it is an firmware problem.
August 31, 20224 yr Try this procedure: https://hubblelithium.freshdesk.com/support/solutions/articles/151000003441-how-to-reset-comms-at-100-soc
August 31, 20224 yr Author 4 minutes ago, YellowTapemeasure said: Try this procedure: https://hubblelithium.freshdesk.com/support/solutions/articles/151000003441-how-to-reset-comms-at-100-soc I have done this yesterday, going to try another cycle, if still the same I will log a call and see if they can do a firmware upgrade and test.
August 31, 20224 yr 15 minutes ago, JohanM said: I have done this yesterday, going to try another cycle, if still the same I will log a call and see if they can do a firmware upgrade and test. It's important that the battery is at full charge for a reasonable amount of time to allow the internal cells to balance.
August 31, 20224 yr Author 4 minutes ago, YellowTapemeasure said: It's important that the battery is at full charge for a reasonable amount of time to allow the internal cells to balance. Ok thanks, Last night its was charged for about 4 hours, maybe I must keep them charged for a day or two?
August 31, 20224 yr 1 hour ago, JohanM said: Ok thanks, Last night its was charged for about 4 hours, maybe I must keep them charged for a day or two? What was the voltage? Once the inverter stops charging at 53.6V, you can connect CAN and enable Lithium comms.
August 31, 20224 yr 3 hours ago, JohanM said: Ok thanks, Last night its was charged for about 4 hours, maybe I must keep them charged for a day or two? I would suggest charging slowly when calibrating by limiting the current to 10-20A and let it take its time. If you charge too quickly the cells may become unbalanced and trigger a cell overvoltage alarm when reaching about 98% and the bms will either throttle the current or cut charging completely. I'm pretty sure the hubble uses the seplos bms which has some flaws when top balancing and also with SOC calibration.
August 31, 20224 yr Author Just now, jumper said: I would suggest charging slowly when calibrating by limiting the current to 10-20A and let it take its time. If you charge too quickly the cells may become unbalanced and trigger a cell overvoltage alarm when reaching about 98% and the bms will either throttle the current or cut charging completely. I'm pretty sure the hubble uses the seplos bms which has some flaws when top balancing and also with SOC calibration. Thanks, will give it a try
August 31, 20224 yr 1 minute ago, JohanM said: Thanks, will give it a try Oh, also when discharging make sure you discharge till the battery bms cutoff, not inverter cutoff at the 'back to grid voltage' if you have something like that on your inverter.
September 1, 20224 yr Author 20 hours ago, YellowTapemeasure said: What was the voltage? Once the inverter stops charging at 53.6V, you can connect CAN and enable Lithium comms. Left it on charge whole day yeterday, this morning Volts was 53.1V, still leaving it on charge for the day. Will test discharge tonight again. Think the best thing is to log a call with Hubble and ask them to do a firmware upgrade and test.
September 1, 20224 yr 21 hours ago, JohanM said: Left it on charge whole day yeterday, this morning Volts was 53.1V, still leaving it on charge for the day. Will test discharge tonight again. Think the best thing is to log a call with Hubble and ask them to do a firmware upgrade and test. It sounds like it still has a bit to go then to reach 53.6V. You are welcome to contact Hubble support to validate though, and I would suggest that you do so. Edited September 2, 20224 yr by YellowTapemeasure
September 11, 20223 yr Author Giving up now. Did the firmware upgrade, did a discharge with BMS disconnected. Battery charge normal until 48% then jumps to 100% (53.6v) and don't take any charge. Plugged CAN in, battery discharge 2.6kw soh=20% volts 48.8V
September 11, 20223 yr 25 minutes ago, JohanM said: Giving up now. Did the firmware upgrade, did a discharge with BMS disconnected. Battery charge normal until 48% then jumps to 100% (53.6v) and don't take any charge. Plugged CAN in, battery discharge 2.6kw soh=20% volts 48.8V Have you had a look at the individual cell voltages? Sometimes runaway cells can also cause this sort of behavior.
September 11, 20223 yr Not sure how the SOH is calculated, but I would definately check those voltages when the charge cycle is near the top end (almost finished) and then see the highest and lowest cells. Currently on your screenshot the deviation is quite large. But will have a better view once you get to the top of the charge, and if the deviation is still so high then you may need to get the cells top balanced again.
