Posted December 26, 20222 yr Hi guys would really appreciate some advice. Is the synapse 1000w and 600w models compatible with lithium batteries. Cant seem to get a answer.
December 26, 20222 yr 48 minutes ago, JpTheron said: compatible with lithium batteries I doubt it, none of the cheapies usually have enough settings to allow Voltage control of Lithium batteries and none, that I've seen have any BMS comms options... best to avoid these, unless you love wasting money on lead acid type batteries...
December 26, 20222 yr 2 hours ago, Kalahari Meerkat said: I doubt it, none of the cheapies usually have enough settings to allow Voltage control of Lithium batteries and none, that I've seen have any BMS comms options... best to avoid these, unless you love wasting money on lead acid type batteries... Spot on. The only setting of note as per the manual is the cut out voltage adjustable 10-12V. The 3kVA Synapse does have charge settings and Bluenova seems to OK it for use with their 12V drop in batteries. Edited December 26, 20222 yr by Scorp007
December 26, 20222 yr Author Thanks for the replies appreciate it. So what about these 7ah lithium batteries for house alarms and gate motors how will they charge?
December 27, 20222 yr 10 hours ago, JpTheron said: Thanks for the replies appreciate it. So what about these 7ah lithium batteries for house alarms and gate motors how will they charge? All lithiums will have the same problem being charged by the inverter. Although it seems it will charge a lithium up to 13.7V but will never be able to balance due to the low bulk voltage. 14.2V at least is required. Edited December 27, 20222 yr by Scorp007
January 16, 20232 yr Hello. This might be a stupid question but am a newbie to this new world of inverters, thanks to Eskom. Someone gave me a synapse 1000w inverter and when I plugged the inverter into the wall socket and pressed the on button nothing happened. I came across some info about a Meccer inverter where if the inverter is not connected to the batteries, the unit won't switch on...is this the case with the synapse 1000w inverter or is the inverter just not working? I wasn't given the manual and cannot find it anywhere on the internet. Please help this newbie.
January 17, 20232 yr Yes you most connect the inverter to a battery.Check on the side of the inverter if it is 12 or 24v.
January 17, 20232 yr That inverter can't provide backup power without batteries. It will charge the batteries when there is grid power, and discharge the batteries when the grid goes down.
May 30, 20231 yr Hi..after I replaced both batteries to 220ah X2 on my synapse 1000w inverter my inverter doesn’t want to charge anymore
May 30, 20231 yr Hi all…I have changed batteries on my synapse 1000w inverter to 2 X 220ah batteries but now my inverter doesn’t want to charge
May 30, 20231 yr Hi…I have changed batteries to 2X 220 ah batteries on my synapse 1000w inverter but now it won’t charge
May 30, 20231 yr 3 hours ago, John Pauls said: Hi…I have changed batteries to 2X 220 ah batteries on my synapse 1000w inverter but now it won’t charge What kind of battery make and type did you buy.
May 30, 20231 yr On 2023/01/16 at 11:19 PM, Ang said: I wasn't given the manual and cannot find it anywhere on the internet. Please help this newbie. This might help: Synapse-cataloguepages.pdf
