13 minutes ago, Gary Waterworth said:
Yeah , sunsynk have disabled the 60s updates .... Probably due to issues they have , but yeah no idea. I also seem to get data every minute as well
Do your systems display 300s for the gateway module on the website or do they still show 60s? Both sites I have sorted out are still listed as 60s on the gateway settings.
  • Replies 949
  • Views 137.1k
  • randomfool
    randomfool
  • randomfool
    randomfool
Is daar 'n manier wat ek met een van julle slim mense direk kan kontak maak of julle met my om hierdie aan die gang te kry asb
They show as 60s
Going to be doing some more tests to try see what exactly they are doing. It may just be the website that has the delay
Edited by Gary Waterworth
I know the easy solution is just to get someone to do it for you, but for myself I have fairly hectic schedules for work and kids, so don't always have the time.
Maybe explain what problems you are having so we can try help.
HA and node red can be a bit of a learning curve
Morning Gary,
PV3 is not updating / showing true values (it makes use of something else), SOC on card is not updating but stand alone it does update, utility use is not showing correctly so can not determine if there is eskom or not.
I understand what you say about time, I just thought for you who understands this it would take a minute or two seeing that you know exactly where to look than me also with limited time working through videos and still don't understand how and what.
Come to think of it my data is not currently coming from node red but from sunsynk sensor. The code which is available to download is updated by you to version 2.4 (take it to sort out Region 1 and Region 2) BUT the latest video I could get was posted 10 months ago when the regions was still in play. Therefor the "instructions" to apply and incorporate your solution went well above my head and I can not monkey see monkey do to get the correct code for me to make use of node red.
So most probably I must start with the correct code/script to implement node red. If it is in the folder V2.4 it just shows you how little I really know and will then need even more assistance to get back on the wagon than I thought.
Thanx again
Edited by JTS
Additional information
52 minutes ago, JTS said:
Morning Gary,
Thanx again
Version 2.x was a complete rewrite and methology change as V1 had severe limitations due to the logic flow framework used.
The video was created by someone else and quite frankly I don't have the correct software or time to do a new one.
The short guide is available on : https://github.com/gdwaterworth/Home-Assistant---E-Linter-Logger---Sunsynk/wiki
It does not make sense for me to try work remotely on someone else's system as you are not setup for me to look at the real data coming in and to set you up for that is time consuming.
My solution is a 2 pv string , so there may be something incorrect with the code for pv3/4. The only way i can check that is if someone "lends" me their login details or share their plant to [email protected]
That way I can setup my test environment and check with those details.
I know I did put in some fixes for pv3/4, and again this morning but again I cant test them.
Utility use, we would have to look at as I am not sure where it is shown or even if it is shown on sunsynk.net, but again I cannot use my system to check as I dont use that or aux power.
People must remember this is not a paid product and I am doing this free and gratis, so it get looked at when I have spare time and it takes LOTS of time. Sometimes it may go for 2 or 3 weeks where I dont look at it.
Sunsynk recently has been particularly painful with their changes to Region 2 and they are still having fairly major teething problems.
There is no API manual from sunsynk ( that is anywhere near up to date and that what is available is wrong/incomplete in a lot of places), so everything is reverse engineered and that takes time.
ATM my focus is adding in some of the extra settings to be changable , but having some issues around it. Also being focused on is the bad data coming from Sunsynk and their API response time challenges  although the current fixes appear to be handling that correctly ( if not very smartly )
Further on the data gather time.
Mine still seems to be on 60s gather times, so all good. It may just be the website that is only updating every 5 min
Edit : Put in a graph covering last 12 hours
Very interesting :)
Who knows.... I have been building in some more error checks and fixing some logic bugs while this has been going on.
Professionally I am in the business of enterprise high availability server and applications. They seem to be run on a string and have no experience
Trying to make the node red more tolerant of their nonsense
The web calls are actually successfully being completed, just no data in the results
@Gary Waterworth filters seem to be working really good. I can see my return to grid sensor which I did myself that does not have the filters goes wonky while the others stay good and does not show thousands of KWh.
Anything I can do to have the filters work on that as well such as just copy pasting in the config yaml or is it more complex than that?
@slipx I was wondering if the logger last updated sensor could be added to the card similar to how it is in the card of Gary showing how long ago it was updated.
Was thinking it could maybe be added here:
and here:
I do have the logger card on a separate page but it would be more convenient to have it in the card.  No real space left on my dashboard to add it on as a separate card and having it on my front page will help a bit.
With all of the down time from Sunsynk lately the inverter doesn't always show offline so having this on the card you can at least easily see if it is up to date or not and not get false data from 3 hours ago like I did this morning giving me a false indication of my battery level 🤦‍♂️.
Hi @-cK- Thats a very unique requirement for a specific integration method and inverter combination and would not really benefit all the other users of the card. Why don't you see if you can use the  energy_cost_buy: or prepaid_units: entities to show this data
36 minutes ago, Benseb said:
@Gary Waterworth how do we update this integration to take advantage of your changes?
I’ve not seen anything in HA to say there’s an update available
You update manually but re-importing the flows. Don't forget to update the template entities as well for the filtering.
Will look at this later.
On teh other topic I will have a look at teh code to force offline the online indicater if teh logger hasnt been updated in the last x minutes
Just busy with work stuff , so may take a few days
@Gary Waterworth That would work as well 👌
@slipx Unfortunately using the suggested slots only returns 0 not a time stamp.
So was playing around with altering my dashboard but if the online status can incorporate the logger last update as a check this would be the better solution and I can revert back to my normal dashboard.
Just wondering if you should make the check linked to a configurable value or fix seeing not everyone is on 60s and having the option to fine tune this might be a bonus (but not a necessity), I'll leave that in your capable hands Gary which will work best for you when you get round to it. 👍
Hi Gary I see you have added the export filters thank you!
Quick question which one do we use? My guess is the filtered sensor but just making sure.
Hello @Gary Waterworth,
With you the ignore plant list, I assume that your new system can poll data from multiple sites.
How does it handle this and will there be information for each site identifiable in the consolidated data sensors?
Also, in theory would it be possible to programmatically generate all the appropriate sensors via Node-Red and have them published through MQTT with auto-discovery instead of using the templates, sensors and inputs?
Theoretically possible. But I'm not doing it :)
if a plant is on the ignore list it will not fetch any inverter data at all
Thanks for the response. So if a plant is not on the ignore list then all the data pulls through. Does your system sum all sites together or would there be identification between sites in the consolidated data?
It woulkd be summed together, but that is all in the export node. So fairly easy to change the logic
Same one as before total_export. Did it that way so you didnt lose history
pre -> filtered -> total_export
Thank you. Will have a look at customising the export node.
Might even be able to look at implementing mqtt from there.
@Gary Waterworth any idea what this means.
I've noticed my HA was stuck and didn't update for 2 hours (thought the app was down but logged in to the web portal and saw it was running)
I've restarted my HA instance remotely to see if it resolved it but no luck.  Will try a reboot when I get home this evening after work but everything was working fine until about 12:00 today.
Anyone else getting this error as well perhaps?
EDIT:
Seeing this as well
Edited by -cK-
EDIT:
Seeing this as well
Same here, looks like sunsynk changing things again.
