6 hours ago, Gary Waterworth said:
Definately looking a lot better after I put the changes in
will wait for it to be pushed to stable before changing anything just yet.
  • Replies 949
  • Views 137.3k
  • randomfool
    randomfool
  • randomfool
    randomfool
Having a few issues in getting v1.1 to work in HA. Have hopefully followed videos but getting errors that looks like HA is not logging in to somewhere - I assume the Sunsynk site.
any suggestions to help me resolve it would be grateful  im region 2 and I can login to https://pv.inteless.com/login
TIA
If you are on V1.1 which is no longer being developed you could look at page 19 if your region is set correctly.
Any reason you are using v1.1 instead of the latest v2.3?
https://powerforum.co.za/topic/16806-sunsynk-logger-integration-into-home-assistant/page/19/
On 2023/12/04 at 12:17 PM, -cK- said:
Just double click the Setup Global Vars, scroll down to around line 87 or 88
It should still be on pv.inteless.com if region 1
just add // in front of line 88 and delete the // in front of api.sunsynk.net.
This should look like this then.
Hit done and hit deploy at the top as well. Both buttons should be red so can't miss it 😉
I tested my region on the sunsynk login page to confirm I was able to log in on region 2 first though.
https://sunsynk.net/login
@Gary Waterworth I updated to V2.4 a bit earlier today and just noticed that my AC and DC temps wasn't pulling in.
Could you just confirm on your end this is working?  I've reverted back to a V2.3 backup and the temps are pulling in on it.  Just trying to pin point if it is user error on my end or on the update.
V2.4
V2.3
V2.4
V2.3
All good my side on 2.4
Any debug messages?
No changes on ac DC that I am aware of.
Will do a clean load on my test vm tomorrow and check.
Those are 2 where I have to get graph data and take last 2 figures. So if you can see the graphs in the app it should work
Edited by Gary Waterworth
I've re-imported the flows a few times now and kept getting no data and could see the below on the flow diagram and then like magic and fairy dust it went away and temps are up for now 🤔
I'll keep and eye on this and check if this happens again as it just pulled another 0 reading on me as I was typing and then came back again.  Might just be the sunsynk servers being its usual 💩.
EDIT @Gary Waterworth
I am observing that there seems to be a delay in processing the last flow, these 8 will start at the same time but won't always finish at the same time. The first 7 works like clock in sync but the last one for the temps will linger and then sometimes returns with a no responses from server and 0 readings on the ac and dc but the batt temp is still given.
Edited by -cK-
Yeah that is teh actual web api request taking its time. I added in a 2 second response timeout to help with the sunsynk "crap".
So what is different on these 2 readings is that I have to request graph data as those 2 reading are just not available anywhere ( that I could find ) as a point in time value.
Stupid I know, but that is what it is.
This has been a cause of a lot of the energy "0" readings nonsense
  - sensor:
      - name: "SunSynk Config"
        state: "Config Sensor"
        unique_id: "sensor.sunsynk_config"
        attributes:
          login: !secret sunsynk_user
          password: !secret sunsynk_password
          region: 2
          invertor_list_opt: 0
          return_items: 10
          sn_data: !secret sunsynk_sn_data
          sn_flow: !secret sunsynk_sn_flow
          unit_cost: 2.37
          force_short_delay: "false"
          timeout: 2000
Okay makes sense as I'm observing the same delay behavior in V2.3 except I don't get the no response error.  I suspect this no response error has to do with the added error checking and timeout that was added and this is missing the deadline sometimes.  I'm guessing I should just try and increase the timeout in the config to allow for a second or 2 more and see if this might not help.
Will update to 2.4 this afternoon again when I get home.  My inverter fans are linked to the temps so if it keeps dropping to 0 they will turn off when it should be on.  Hopefully a bump in the timeout delay solves this.
2 hours ago, Gary Waterworth said:
Dont go past 5 seconds.
Once you have a temp, failed requests shouldn't put a zero but keep the current
Noted, will do 500ms interval increases to try and find a sweet spot.
Will report back on where I end up 👍
Installed v1.1 from an old link !
thought I would do a clean installation so wiped it clean ready for latest version, hence question.
however, after reading the forum I now realise that I have the Sunsynk dongle. Will this code still work ? Or do I need to go down another route?
when googling I found a HA code that would pull in values from web and I can then put the power flow card in HA to view the data. Not too worried about writing back to the inverter.
just need to remember who did the other code !
TIA
TIA
Hello There JTJ,
I believe you may be a little confused. This thread is purely for the E-Linter (SUNSYNK) dongle.
The dongle with the external antenna is the Solarman dongle and works with KellerZA integration and supports local polling.
Gary has done some amazing work here for the people that do not have the ability to connect to their RS-485 port and still need their dongles to be connected to retain warranty/SLA support.
If you are using the Sunsynk Application or connect to the sunsynk.net website and using region 2 for the login, then you are in the correct place to get your data into Home Assistant via the Node-Red flows and HA templates.
Regards,
Wazza
Looks like things settled down with a 3000ms timeout
If this is true Im going to get real grumpy.
May have to start looking at another method to get decent data from the inverter
Looks like the 60s gateway updates arent enabled or even if they show as 60s they arent
Was wondering why on the sunsynk website it shows last update 4 minutes ago etc.
Our app has been down most of yesterday and most of today
its looking like the only robust way to control this is via a direct integration like Solar assistant or directly into HA
a real shame. We shouldn’t need to do this but seems their tech team have theirs heads up their asses (technical term as I’m a CTO)
@Gary Waterworth
Good day,
I'm really battling to get my SunSynk Max on HA.  I have watched numerous videos and just can't get it done correctly.  Is there someone who can please assist me ?
Even better if you can log onto my system and show me how to set it up correctly with the most data possible as often as possible.
Thank you for your time and effort so far.
Jannie.
On 2024/02/24 at 9:19 PM, JTS said:
@Gary Waterworth
Good day,
Jannie.
Is your home assistant accessible from the internet ?
Ok some good news at least.
I have been testing for the last few weeks on changes I have made.
The energy data now seems to be stable regardless of API errors , rebooting/updating of HA and Node red.
Looks like teh error checking and filter sensors are behaving properly. I havent had to "massage" the energy data at all.
As far as the 60s and 300 second datalogger update story, I am busy watching the sunsynk forum and others to see what more comes of it.
I suspect their outages are a badly designed/implemented infrastructure when they took it over from e-linter and they are limiting the number of accesses a client makes. Where that will lead to further things that can affect us ~shrug~
Hallo @Gary Waterworth,
I'm a total loss here so hopefully I answer your question.
My pc (laptop) do speak to a sonoff switch and see my inverter.  However the details or data I can see on HA and on the inverter screen itself is not the same.
I did watch several videos and tried really hard to copy it to the "T" but ja im under the bridge and don't see me surviving this one.
My laptop is on anydesk or teamviewer would you like to see what I see.
Kind regards,
Jannie.
On the 60s topic on the one template card there is this:
Is that the data logger update?
Reason I'm asking is that though the sunsynk website looks to only update their data every 5 minutes, from my data it would seem to be pulling data every minute still. 🤷‍♂️
Yeah , sunsynk have disabled the 60s updates .... Probably due to issues they have , but yeah no idea. I also seem to get data every minute as well
