July 18, 20197 yr As far as I know, there's only Windows version of Pylontech's BatteryView. But from the linux, you can log directly into Pylontech via RS232 console and query it's status manually.
March 17, 20206 yr On 2019/07/17 at 9:54 AM, Valken said: Hi All, So for those that has been running Pylontech's for a while now, how fast does your Total AH drop? I have had my 2X 3.5Kw Pylontech batteries for just over a week now and noticed that my "Total AH" Capacity has already dropped from 148 AH to 147.93 AH? Is this normal? At this rate i will never see 10 years life? Hi @Valken , any update on your reduced AH? My batteries (2 x US2000B) are just over a year old with 96 cycles and the AH drops by 0.1 for every 10 cycles. Started at 100AH and am currently on 99.10AH. I am told that this is normal but at this rate the batteries will only get 2000 cycles before reaching 80% of original capacity. Edited March 17, 20206 yr by francois
March 17, 20206 yr @Valken My 3 x 3000 Pylontech batteries was installed 8 August 2019 and have done 87 cycles . It has not lost any capacity so far . When fully charged it shows AH remaining 221.1
March 18, 20206 yr Falken I see you do a lot more cycles than what I do in the same period . Do we know what influence of DOD have on Total AH over time . Thanks
April 20, 20215 yr On 2020/03/18 at 9:15 AM, Valken said: Hi you are running two batteries only, word of advice you need to add one more. You are sweating the batteries, also I've seen in a configuration of 2 they tend to lose amps. Best is to invest in one more battery, so that when you need cranking amps you will have it on demand.
August 17, 20214 yr I have 2 new Pyrontech batteries and there are always 2 charge lights left on on each battery. Does this mean that the batteries always retain a buffer of 33% or are my batteries not working correctly. Thanks. Ant
August 18, 20214 yr 14 hours ago, Saxelbye said: I have 2 new Pyrontech batteries and there are always 2 charge lights left on on each battery. Does this mean that the batteries always retain a buffer of 33% or are my batteries not working correctly. Thanks. Ant Without more information; I'd say they're working correctly. The manual will also tell you all you need to know about the lights.
