December 10, 20232 yr Anyone using any sort of comms hack from their JK BMS to their inverter? There are a few projects out there but most of them are not free. I found this opensource solution and am busy setting it up to test. https://github.com/ArminJo/JK-BMSToPylontechCAN Bought all the bits and pieces yesterday from communica. Completed the hardware assembly/setup and loaded the software and it works great out the box in demo mode. Will change the can board crystal today and then connect it to my JK BMS for initial test to see if it pulls the data correctly. If that goes well then I will connect it to my Sunsynk and see what happens 🙃
December 11, 20232 yr Author 32 minutes ago, Chris_S said: Very nice. I see Andy is testing a neat little CAN device for the JK bms Yeah, I watched that too That is a very neat project which is great for the DIY community, but unfortunately they have not open-sourced it and buying those modules from Aussie land is a bit of a schlepp. They based it on some of the work done on this github project I am testing, so maybe I will give it a shot too and port it over to esp32 with some modbus comms to allow multiple batteries. Baby steps though, 1st need to make sure it is working nicely on my setup using the default code and hardware.
December 11, 20232 yr I tested that one a month ago and moved further with that already. I have injected with new can id for providing data to the inverter (0x373): max/min cell voltage. Still struggling to find what ID shall be for the charging cycle as shown on the inverter data that battery with Mod-Bus connection can communicate. I also discovered that there is also a can Id of 0x405 captured during my sniffing of can bus between the battery and the inverter. [Additional data captured by the inverter - LUXpower, sill CycleCount missing) Relaxed charging worked from 80% of SOC with gradual reduction of charging voltage Also, I modified a bit on charging scheme when the SOC reach 80% the inverter will start to reduce charging voltage gradually to float voltage (Voltage at SOC 100%). However, I found out that JK BMS SOC calculation is inaccurate. As the result the inverter working incorrectly as well. On some older JKBMS, there were not anything named as SOC at 100% and SOC at 0% in the mobile Bluetooth App so it is a real hard time for making the BMS to estimate the SOC correctly. Anyone have hint on how to make the BMS to do this SOC calculation better? In the mean time, I am thinking of an alternative so that: + SOC announced by JK will be omitted. The arduino nano will calculate the SOC using voltage using the range from 3.2-3.4 V (3.2=0% and 3.4 = 100%). This is also the safe range to prolong battery life. + At 80% of the recalculated SOC (if charging), Nano will tell the inverter to stop charging shortly every 5 minutes to wait for cell voltage to stable and remap the recalculated SOC. Similar option will be applied for the 0-20% SOC at discharging. This thing will have the SOC closely linked to the actually SOC of the battery and make the Inverter work correctly. + Nano will inform the inverter via CAN using this SOC. + All non-neccessary data will be skipped such as alarm, SOH ...etc. How do you think about this option? Ngoc - from Vietnam Edited December 11, 20232 yr by Ngoc
December 12, 20232 yr Author I am getting wayyy too old to solder 🤣 that dam crystal pins are soooo small. Anyway followed the steps on the github page connected everything up to my JK BMS and Sunsynk5k inverter and BOOM it works as described.
December 12, 20232 yr Author Now to test and see if it keeps my batteries as healthy as they were when using voltage settings.
December 13, 20232 yr Author Finally got around to start testing this jk bms comms project. Circled part in red is with the new comms to inverter running. It has settled down nicely now ready to run through the night and tomorrow daytime. So far it is behaving as expected and controlling the inverter nicely.
December 13, 20232 yr 2 hours ago, WannabeSolarSparky said: Finally got around to start testing this jk bms comms project. Circled part in red is with the new comms to inverter running. It has settled down nicely now ready to run through the night and tomorrow daytime. So far it is behaving as expected and controlling the inverter nicely. Nice work i like 👌 Edited December 13, 20232 yr by TaliaB
December 13, 20232 yr Author 1 minute ago, TaliaB said: Nice work i like 👆 Thanks @TaliaB it is a nice little project, and if my testing inspires other diy folk to give it a bash then that's a bonus. I had a small glitch when I hooked it up this afternoon. I have been using voltage settings ever since I installed my sunsynk and totally forgot that if I change to Li comms it would change my work modes to % 🤪 I had to go reconfigure all my work mode settings, but again, everything still working perfectly 🙃 Next I will see if I can do some photos of the hardware I put together for this testing... And if all the testing goes well I will put together a prototype of the final hardware setup to make it a more permanent setup.
December 14, 20232 yr Author Discharged overnight down to 15% without any issues Now to see how it handles charging back up to 100% Really looking quite good so far.
December 15, 20232 yr Author This works so well, I have decided to try my hand at PCB Proto-typing 🤪 This is my 1st ever attempt at this so don't be too harsh... Top View
December 15, 20232 yr Author Special shout out to ArminJo for the code and and clear instructions on how to put this all together. https://github.com/ArminJo/JK-BMSToPylontechCAN And @Ngoc for the idea for the protoype And for the clever electronics folk here on the forum, let me know if I am on the right track 🙃
December 16, 20232 yr Author After some received advice I made some changes to the prototype board. Added status LED's for the 2 comms ports so you don't have to guess if it is working. It is now also a lot smaller, the same footprint as my cigarette box 🙃
December 18, 20232 yr Author 3 days now with out any issues. It feels like I have more solar available in the mornings now as the charge algorithm sent to the inverter throttles down the amps the closer the battery gets to full. I will have to do some capacity tests to check that.
December 18, 20232 yr 1 hour ago, WannabeSolarSparky said: charge algorithm sent to the inverter throttles down the amps Probably not, since the cells themselves would allow less current to flow the closer they're getting to being full... Anyway, dude, I need some info from you, I'll be needing to setup something similar, I now have a JK B1A20S15P with 16 cells connected and would need to make up a translation interface to get data from the JK and give dope to the Sunsynk 5k... The serial comms cable from the BMS plugs into the GPS port, I guess, is this connector with some wires attached available locally? (probably not locally to me, but maybe around the Cape Town area)
December 18, 20232 yr Author 14 minutes ago, Kalahari Meerkat said: Probably not, since the cells themselves would allow less current to flow the closer they're getting to being full... Anyway, dude, I need some info from you, I'll be needing to setup something similar, I now have a JK B1A20S15P with 16 cells connected and would need to make up a translation interface to get data from the JK and give dope to the Sunsynk 5k... The serial comms cable from the BMS plugs into the GPS port, I guess, is this connector with some wires attached available locally? (probably not locally to me, but maybe around the Cape Town area) https://www.communica.co.za/products/hkd-micro-jst-1-25mm-4pfem-15cm?variant=44762822902060 I have not gone to communica yet to see if that is the correct one... Edited December 18, 20232 yr by WannabeSolarSparky
December 18, 20232 yr Author 15 minutes ago, Kalahari Meerkat said: Probably not, since the cells themselves would allow less current to flow the closer they're getting to being full... Anyway, dude, I need some info from you, I'll be needing to setup something similar, I now have a JK B1A20S15P with 16 cells connected and would need to make up a translation interface to get data from the JK and give dope to the Sunsynk 5k... The serial comms cable from the BMS plugs into the GPS port, I guess, is this connector with some wires attached available locally? (probably not locally to me, but maybe around the Cape Town area) Give this project a try it works perfectly and you can set it to your battery's number of cells. /* * Software serial for JK-BMS stuff */ #if !defined(MAXIMUM_NUMBER_OF_CELLS) #define MAXIMUM_NUMBER_OF_CELLS 24 // Maximum number of cell info which can be converted. Must be before #include "JK-BMS.hpp". #endif #include "JK-BMS.hpp"
December 18, 20232 yr Author 25 minutes ago, Kalahari Meerkat said: Probably not, since the cells themselves would allow less current to flow the closer they're getting to being full... Yeah, I checked and the same amount of amps went into the batteries as before. Just my graphs now look slightly different. I am so used to what my graphs looked like before when I used voltage settings 🙃
December 18, 20232 yr Author Final prototype ready to send to jlcpcb to fabricate. Should be here 1st week January then I can test fully
December 18, 20232 yr 2 minutes ago, WannabeSolarSparky said: Final prototype ready to send to jlcpcb to fabricate. How about using the Vbatt from the JK connection and a switch mode module to not require an external power source? One of these may be a good option... then I may ask you to have a few more boards made... I'd probably want 3 or 4 of them...
December 18, 20232 yr Also, why not use a PCB mount micro JST 1.25mm spacing on the PCB with these in reverse you could not accidentally plug the BMS into the CAN bus port etc...
