March 8, 20242 yr Hi, I have started to use Solar Assistant in my 4 parallel inverter configuration, just connecting de Rpi to one inverter, and the readings are wrong except for the inverter directly connected to the Rpi. solar Assistant guys asked me to check the firmware version, and 3 of them have 81.06 and the last one 81.03. Is this the last version available? Here can I get it to flash the different one? Thanks in advance... Jorge
March 8, 20242 yr The latest 81.xx that I have is 81.07. You could update them all to that. I have a vague feeling that it won't fix the problem, but I can't recall why, sorry. I can't recall where I found this; use at your own risk. MAXII_8K_81.07.rar
March 13, 20242 yr Author Thanks! I have just found it here: https://ftps.voltronic.com.tw/V/Voltacon-7FCA9E24D07246188EAD/MAXII_8K_81.07.7z It looks like it is from 2024/2/20
March 16, 20242 yr On 2024/03/13 at 8:56 PM, jdeep said: I have just found it here: https://ftps.voltronic.com.tw/V/Voltacon-7FCA9E24D07246188EAD/MAXII_8K_81.07.7z Boy, didn't you cause me a lot of work with that post. But thanks for the valuable pointer!
April 28, 20242 yr Hi, I see firmware 72.72 for Max 8k, is the upgrade worth it from 72.66 (272.66 modified by @Coulomb) If it is the case Can you fix premature float bug in order to test it I also see remote panel 12.28, Can I upgrade ? For what panel chip is it intended ? Thanks a lot !
April 28, 20242 yr On 2024/04/28 at 3:24 PM, sharkut said: Hi, I see firmware 72.72 for Max 8k, is the upgrade worth it from 72.66 (272.66 modified by @Coulomb) Well, 72.72 does have the full QDOP command, meaning that with the right display firmware (12.21 is enough, I believe), you get SoC% for battery settings 12, 13, and 29 (back to utility, back to battery, and low DC cut-off). These seem to be popular with owners that have a Pylontech or other battery with a BMS that the inverters or monitoring software can talk to. I also see that 272.66 is one of my early minimalist patches that didn't do the full suite of Georg's MPPT patches. That makes it PV voltage independent, but it seems that the full suite is still the best. Would there be demand for a set of X72.72 patches, all with the premature float bug fixed, and several minimum PV voltage options? I haven't done a patch set in a while, and I'd like to not have the rust set in too badly 🤎🤓 On 2024/04/28 at 3:24 PM, sharkut said: I also see remote panel 12.28, Can I upgrade ? For what panel chip is it intended ? If you currently run 12.xx or 112.xx, then yes. Since 12.21, they are all chipset independent (if only they realised they could do something similar with the main firmwares as well!). I don't know what the differences are with 12.28, though I'll take a look tonight. Edited May 29, 20242 yr by Coulomb
April 28, 20242 yr 3 hours ago, Coulomb said: I don't know what the differences are with 12.28, though I'll take a look tonight. As you might expect from seven minor update versions, there are quite a few differences between 12.21 and 12.28. Most of them seem to be concerned with talking to a battery BMS.
April 28, 20242 yr If you have time I'm interested of course (200v PV voltage) maybe other people interested too ?
June 18, 20242 yr On 2024/03/13 at 11:56 AM, jdeep said: https://ftps.voltronic.com.tw/V/Voltacon-7FCA9E24D07246188EAD/MAXII_8K_81.07.7z It looks like it is from 2024/2/20 It must be older. I have been running that version as of october 2023. I have been away for almost six months now, and I wonder if a new firmware version has been developed for the Max II - 8K. Maybe Coulomb has an idea, or even has it in his collection. Thanks beforehand for any info. Kurt
June 19, 20242 yr I'll post this here for ease of finding, having discussed it slightly a few posts back. This is factory display/communications firmware version 12.28 for the Axpert MAX E non-twin series. It may be usable with other models IF the existing firmware is version 12.xx or 112.xx. This version is not chipset dependent. Do not use with models that don't come with display firmware version x12.xx. Use at your own risk. Firmware upload instructions for models with a removable display. Remote Panel_Reflash_MCU(12.28).rar Edited June 19, 20242 yr by Coulomb
June 19, 20242 yr Thank you for the info Coulomb, but I was merely enquiring if there are more recent versions above 81.07 for the Max-II 8K and 20.22 for the display. It seems extremely hard to find such info over the net. (But I seem to remember that there is a place where you compiled a library of the firmware. Only, for the life of me, I cannot find it anywhere... But thanks anyway. Kurt
July 11, 20242 yr On 2024/04/28 at 5:53 PM, sharkut said: If you have time I'm interested of course (200v PV voltage) maybe other people interested too ? @Coulomb Did you have time to take a look ?
December 3, 20241 yr Hi @Coulomb, did the firmware work for my Axpert Max 8Kw 48V (the Big Yellow One) i have bought recently ? My firmware is quitely older. Information in attachements. Best Regards
December 5, 20241 yr On 2024/12/03 at 10:46 PM, fhocorp said: Will the firmware work for my Axpert Max 8Kw 48V (the Big Yellow One) i have bought recently ? My firmware is quite old. You can use any of the 90.06 based patched firmwares. But I suggest that you use 46.71 now, available here. It should work the same with any panel configuration, and I believe it will work almost as well as the patched firmwares. It's almost 2 years old now, but it should still be better than your existing firmware, which I believe is about 15 month older again.
December 5, 20241 yr 15 hours ago, Coulomb said: You can use any of the 90.06 based patched firmwares. But I suggest that you use 46.71 now, available here. It should work the same with any panel configuration, and I believe it will work almost as well as the patched firmwares. It's almost 2 years old now, but it should still be better than your existing firmware, which I believe is about 15 month older again. Thanks @Coulomb The upgrade worked like a charm 👍 The patched firmwares add more improvements and stability ? The 46.71 firmware has the premature float bug ? Best Regards Edited December 5, 20241 yr by fhocorp
December 6, 20241 yr On 2024/12/05 at 10:32 PM, fhocorp said: The 46.71 firmware has the premature float bug ? All Voltronic factory firmwares have the premature float bug. It's company policy, evidently. The VM firmwares have the bug implemented completely differently, in a completely different part of the firmware, compared to all the other firmwares. So it's firmly entrenched. For reasons that continue to elude me, people don't seem to be all that bothered by this bug. So I've stopped making noise about it, and just quietly fixing it in virtually any firmware that I patch.
December 6, 20241 yr On 2024/12/06 at 2:16 PM, Coulomb said: All Voltronic factory firmwares have the premature float bug. It's company policy, evidently. The VM firmwares have the bug implemented completely differently, in a completely different part of the firmware, compared to all the other firmwares. So it's firmly entrenched. For reasons that continue to elude me, people don't seem to be all that bothered by this bug. So I've stopped making noise about it, and just quietly fixing it in virtually any firmware that I patch. Ok. @Coulomb Could you recommend me a firmware patch with your improvements inside compatible with my inverter model ? Your custom firmwares seems to be more safer that factory firmwares. Best Regards Edited December 10, 20241 yr by fhocorp
December 9, 20241 yr Hello friends, greetings from Ukraine! I have an Axioma ISMPPT BFP 8000 inverter. I know that the component base is similar to MPPT Solar, Altek, Qpawer, and I have a question, is it possible to reflash it with firmware to the 11 kilowatt version? I looked at the reviews, the power elements of 8 and 11 kilowatts match. Maybe someone has already done this upgrade? Can you tell me which firmware is suitable for my inverter. I would be very grateful if someone gives a detailed comment. Here are photos of the model and the software that it currently has.
December 11, 20241 yr On 2024/12/10 at 12:06 AM, Artur said: Hello friends, greetings from Ukraine! I have an Axioma ISMPPT BFP 8000 inverter. Шановний пане Артуре з України, ніхто вам цей інвертор не прошиє на 11кВт. Edited December 11, 20241 yr by biletskiy
December 13, 20241 yr I have 8 solar panels, each with a capacity of 330 watts, connected to an 8 kW inverter and a 10 kW Felicity battery. Some time ago, I did a software update for the battery and things were good, but after a while I noticed that the charging ampere dropped to 10 amperes, and when I removed the BMC cable, things returned to normal. Is this problem due to the inverter or not? Note that U1 76.04 U2 39.09
December 14, 20241 yr 7 hours ago, ahmad almawal said: after a while I noticed that the charging ampere dropped to 10 amperes, and when I removed the BMC cable, things returned to normal. I assume you mean BMS cable. That could be normal, if the battery was nearing full, or the cells were unbalanced. I'm trying to decide whether your inverter is a clone. The QR code points to ags dubai dot com, and not https. Usually the QR code is "busier" (more dots because more characters). But that might just be a customisation that resellers are allowed to ask for.
December 15, 20241 yr On 2024/12/14 at 6:20 AM, Coulomb said: أفترض أنك تقصد كابل BMS. قد يكون ذلك طبيعيا ، إذا كانت البطارية تقترب من الامتلاء ، أو كانت الخلايا غير متوازنة. أحاول أن أقرر ما إذا كان العاكس الخاص بك مستنسخا. يشير رمز الاستجابة السريعة إلى ags dubai dot com ، وليس https. عادة ما يكون رمز الاستجابة السريعة "أكثر انشغالا" (المزيد من النقاط بسبب المزيد من الأحرف). ولكن قد يكون هذا مجرد تخصيص يسمح للبائعين بطلبه. The battery was not full or close to full. The charge was 70%.
December 16, 20241 yr 13 hours ago, ahmad almawal said: The battery was not full or close to full. Then it might be firmware related. Alas, I have no 76.xx for Axpert Max II 8 kW. But it might be the display/comms firmware, since that firmware talks to the BMS. What is your present U2 (MCU, display/comms) firmware version? Edit: I first assumed it was a non-twin, then realised that the sticker says Twin. If it's 38.xx, then the latest I have is 38.11, which is well over a year old now. Edited December 16, 20241 yr by Coulomb
December 17, 20241 yr 19 hours ago, ahmad almawal said: U2: 39.06 Duh! If course, it's a Max II, so it will have 39.xx not 38.xx display firmware. The latest I know of is 39.27, much more recent than 39.06, and available from the link below. Max II displays use the same firmware as VM IVs.
