Splicing connectors
I saw them at ACDC lately, I have used similar with great success in other applications, but personally I would be skittish to use them in a DB.
If forced, I might do the light circuits, but would steer clear of Plugs and other heavy hitters.
Edited by Riaanh
38 minutes ago, DeepBass9 said:
So what is the best thing to use in a DB?
I think this is very much an open ended question, there are so much to consider, what is currently in the DB, how much space, amount of wires to be "spliced" Current draw etc, etc.
If some space is available, I would use Distribution blocks, If less space available in DB, but some space on the DIN rail available, I would opt for the DIN Bars, Vertical, alternatively Single Pole Distribution Block in relevant size/connections.
Just my 2c
28 minutes ago, Jaco de Jongh said:
A normal ferrule. Crimp the wire and tape it up. This is the safest and most secure way of doing it.
or put some heat shrink on it, I guess.
I think this post was born out of an issue @plonkster picked up in of a previous post by @Shockin where he had joined wires behind the new DB with  normal connector blocks. Suggestions were made to redo the joints for reliability and safety purposes. I guess he is now looking at the best ways re-join those wires.
I agree.
37 minutes ago, DeepBass9 said:
A distribution block are those blocks of connectors with screws to attach the wires?
It's a bit better than those "chocolate blocks".
You can also use these (they stack end-to-end with a cap on the last one, so the terminals are not open):
with a busbar:
Edited by plonkster
Can work as well... Electricians dont normally run around with heatshrink, we are so use to Insulation tape, that we dont think about the other stuff out there.
8 minutes ago, plonkster said:
... Tape ...
9 minutes ago, Jaco de Jongh said:
... Insulation tape ...
Question: I find that insulation tape gets "gummy" after a few years. Is it cheap tape or what?
I think it is supposed to do that. Otherwise it's not sealing the connection properly (from moisture ingress and corrosion). The really nice heat shrink also has a glue lining, and on the really serious (aka expensive) kinds you can submerge that stuff under water!
Ok, that makes sense but then the end starts peeling. I hate that.
5 minutes ago, Jaco de Jongh said:
There is cheaper ones available lately, Cr%@$# to be honest.
Ok, that makes more sense. Geez my OCD / ADD gets flapping when insulation tape starts peeling. And then when you peel it all off, to make the OCD / ADD to away, it gets worse.
You are left with a sticky connector after removing the tape after the removed tape got stuck to all your fingers and the floor and the roof and the walls!!!
Man, I cannot stress how much I abhor that!
Edited by Guest
I was going to terminate all the neutrals on a busbar behind the db board and just feed one neutral cable to the neutral bar on the front of the db board. Electrician said that in order to get a coc all the neutral need to be easily accessible on the front of the board,
Okay, that makes more sense now, then i will go with the ones RiaanH suggested, I assumed it was for joining.
Correct, but fault finding might be a mission in the future, you will need to swing open the new DB in the event of a neutral fault.
My last thoughts on this, If you use the correct tape that has the correct degree of Elasticity and you have mastered the correct way of applying insulation tape, without over or under stretching it, you will not see any "peeling".  As a matter of fact, you will struggle to even find the end of the tape after I have applied it, and if you find it, good luck in removing it. If I ever have to remove the tape from a joint I have to cut it off.
YES!!! I have seen such - had to cut it off. Now I know the difference. Thanks for that titbit.
6 minutes ago, DeepBass9 said:
LOL, tape and then put some heat shrink over the top! (For the OCDs amongst us)
Nope. I have seen how heat shrink started smoking on a UPS battery cable. Battery tested perfect, but had a internal short and under load, bad moyo. Me and Murphy again.
Now I crimp lugs so that you don't need to put on tape nor heat shrink ... OCD's sorted ... IF I get the crimp right that is. 🤦‍♂️
Edited by Guest
Next best think after warm bread with butter is HEAT SHRINK . I head shrink everything and only use tape if i need to. When i started to go in High end audio stuff, and you want to make something look good, then you use Heat shrink and Breaded sleeving. Best place to go is https://www.three-d.co.za/#!items/cable-protection. They got a off-cut bin there where you sometimes can get something for free to if you buy some stuff. "the one in Montague Gardens". There prices is really good compare to other places. You buy of a roll so you pay met meter.
The stock the Crimping ferrules that Jaco is talking about  https://www.three-d.co.za/contactus.html#!items/cable-terminals
And that thing where people just "tear" it off at the end, that's a recipe for a bad tape job. I actually cut the tape with my side-cutters (good enough and scissors are just overkill), and then I'm careful to not touch that end piece so there's no putting fatty residue or interfering with the stickiness on that last bit (that always peels).
