June 6, 20215 yr 6 hours ago, sanchuka said: @Achmatsorry to bother, but I've read/watch two methods for battery balancing. 1) Charge 100%SOC existing Battery Bank and charge separately new Battery(s) at 100%SOC, then connect together with BMS, cables, others. 2) A youtube procedure, which I assume to Discharge my existing Battery Bank to similar %SOC (Green Led Lights) of new Battery(s) and then connect them together as youtube video, before connecting to Inverter. I'm an Off-Grid user with no AC-Input, so would like to confirm if can be done option 2), or is mandatory follow option 1) procedure (Very Good Sunny Day). I did not find a Pylontech Official Procedure. Regards! and Thank You! I did option 2. Two new batteries came about 50% charged on delivery. Set DoD on my inverter (luckily I am on-grid) to discharge my existing two down to 50% over night. Inverter left batteries on around 49% though. Connected the 4 batteries together the next morning. Took less than 15 minutes to balance. Then hooked them all up to the inverter.
July 6, 20224 yr On 2021/05/25 at 9:46 PM, Anonymous_Llopi said: BatteryView_us_series_3.0.24.zip.7z 2.65 MB · 229 downloads Pylontech Low Voltage Battery Mornitoring and Maintenance Tool Guidance(1).pdf 980.03 kB · 161 downloads us_c_v2.1_Crc.bin 222 kB · 135 downloads us3000a_V2.8_Crc.bin 201 kB · 118 downloads US_C 2.1 is for US3000C US3000A 2.8 is for US3000B Cheers I have a question...I have 4 batteries in my bank...Must i disconect each battery before the update and reconnect it back to bank...Or can I upgrade firmware even if batteries is still connected as bank?
July 6, 20224 yr On 2021/05/27 at 11:14 PM, wolfandy said: Just wanted to say thanks for this - really appreciate it 🙂 Ever since I added my last Pylon US3000 to my pack, I have been having comms problems (e.g., cycles not reporting for the older ones). Turned out my older 3 were running v1.3 and the latest one v2.4. Upgraded all of them to v2.8 tonight without problems - and now all data is reported as should be I have a question...I have 4 batteries in my bank...Must i disconect each battery before the update and reconnect it back to bank...Or can I upgrade firmware even if batteries is still connected as bank?
July 6, 20224 yr 1 hour ago, vwykj said: I have a question...I have 4 batteries in my bank...Must i disconect each battery before the update and reconnect it back to bank...Or can I upgrade firmware even if batteries is still connected as bank? I would disconnect each battery and upgrade them individually.
August 4, 20223 yr On 2022/07/06 at 6:42 AM, vwykj said: I have a question...I have 4 batteries in my bank...Must i disconect each battery before the update and reconnect it back to bank...Or can I upgrade firmware even if batteries is still connected as bank? Don't know the answer to that I did the firmware upgrade when I was making changes to my system. I disconnected each battery and ran the update on each separately
January 16, 20233 yr On 2021/05/25 at 9:46 PM, Anonymous_Llopi said: BatteryView_us_series_3.0.24.zip.7z 2.65 MB · 274 downloads Pylontech Low Voltage Battery Mornitoring and Maintenance Tool Guidance(1).pdf 980.03 kB · 200 downloads us_c_v2.1_Crc.bin 222 kB · 161 downloads us3000a_V2.8_Crc.bin 201 kB · 137 downloads US_C 2.1 is for US3000C US3000A 2.8 is for US3000B Cheers Good Day I would like to check has anyone successfully installed "US_C 2.1 for US3000C" Firmware on their US3000C's I am planning to load this firmware, but I do not want to Brick these. Regards
